Question about Ricoh Aficio 450 Copier
Help resetting technician annunciator
Copier running fine. Technician service is blinking. How do I reset?
  • Printer Al Apr 01, 2008
    Toshiba 1550
  • 38 Answers
ANUNG MODEL BA YAN? PARA MATULUNGAN KITA PRA TXT MOKO AT 09275514418
Posted on Nov 30, 2008
  • 30 Answers
Make and model number would be usefull
Posted on Mar 31, 2008
Ricoh 1813. Error code c551
The Ricoh copier error code SC551 / 551 is a fusing thermistor 1 error code.
It can mean:
1. The thermistor is not connected
2. The thermistor connector is bad
To reset this error try the code:
"Clear Mode"+107+"Clear/Stop" hold for 5s.
Turn ON and OFF the Main Switch.
If the problem persists you may need to contact a local service technician to take a look at your copier.
Oct 03, 2017 | Ricoh Office Equipment & Supplies
Our Sharp ARM455N Copier shows "Maintenance
this is message that the copier did certain amount of copies and it needs to be cleaned and ispected. The purpose of preventive maintenace is to stop or reduce problems before they occure. In most cases they occure when you need the copier urgently.
This can be reseted in simulation mode, but I recommend to get service technician to service the copier.
If you want to reset the alarm leave the email and I'll send you the service manual.
Sep 09, 2011 | Sharp AR-M455N Copier
The copier does not start instead has a code Blinking H 4?
H4 means; Heat roller low temperature detection. This is an error in your fuser and you will likely need to get a service technician to take a look at your copier.
Sep 14, 2010 | Toshiba e-Studio120 Copier
My copier is indicating CALL SERVICE MAN, i
you did service the machine or e technician which is trained to do the service because if the machine was service by a technician this would haven't happened, but this is not important now, the call service man is still indicating because after the service in the service mode the pm counter have not been reset, so if you have a good copy then there is no problem
Jan 28, 2010 | Sharp AR-5316 Advanced Digital Imager...
How do you reset the error message : maintenance requred, call a service technician?
You call a Sharp Service Technician and have them reset it. That code cannot be reset by a user.
Oct 08, 2009 | Sharp AR-168D Black and White Copier
SHARP AR-5316 MAINTENACE RESET
To reset maintenance codes requires going into service mode. This should only be done by an authorized trained technician as changing or adjusting something in this mode could create all sorts of problems you dont want to deal with.
Mar 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
Canon NP 6545 - Error E020
E020 try by push reset button until show $ upper left
then press key *4* and you will in service mode.
find code error 1 in LCD then press *
copier will restart.
Jan 12, 2009 | Canon NP 6545 Copier
Problem in Copying and Printing
Looks like it may be a memory communication error. See the clip from the service manual below. May require technician to diagnose.
May 19, 2008 | Sharp AR-M205 Copier
Sharp copier sf 2530
Reset the developer by pressing C-CA-0-C - 83-5
May 16, 2008 | Office Equipment & Supplies
Resetting Error Code
RESETTING CODE E000003-0000 ON CANON IMAGE RUNNER 5000 COPIER
Aug 30, 2007 | Office Equipment & Supplies
Ricoh Aficio 450 Copier Logo
88 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
