Docking connector for sonic impact if2
I have a sonic impact if2 and the problem is tha the 30 pin docking connector has come loose and the ipod cannot be used in the docking station. Apparently this is a design defect in the unit which is common. When I went to the Sonic Impact help desk, they told me to send it in for repair for $75. My question to them (and also to you) is how do I remove the bottom of the unit containing the Ipod docking connector from the hard shell. I am reasonably sure if I can get it out of the shell, the connector can be fixed.
  • 3 more comments
  • Anonymous Apr 29, 2008
    My sonic impact i-f2 has a loose docking connector. The ipod will not stay docked. I am sure that if I could get inside the unit that i could repair it, but I have no idea how.It is a defect that was admitted by sonic impact, but they will not do the service as I have lost the original purchase receipt.
  • jlejman Jan 17, 2009
    I have the same problem except no one answers the phone or replies to emails at Sonic Impact.
  • Anonymous Mar 03, 2009
    same issue and no response from Sonic. I wont be buying anything from them again.
  • Anonymous Mar 30, 2009
    Just called Big Rich & he said there is no more sonic impact. Out of business. Good Luck
  • Anonymous May 03, 2009
    same problem cant get it open anyone figure it out yet??
    New Friend:
Had the same problem for a while, not been able to find any useful info anywhere.
Got a little bored today and decided to have a go myself.
First remove the battery.
The exterior zipped cover is glued to the plastic electronics compartment, careful prising (the cover is fairly flexible) can loosen the glue enabling you to remove the compartment.
Unscrew the plastic cover under this you will see the the pcb that the dock connector is attached to, along with lots of glue holding the wires for the speakers.
Unscrew the pcb and remove all the pcb connectors (all glued secure), then you will have access to the side you need to solder.
Now all you need is a hawk-eyed soldering genius as the tabs on the connector are extremely fine and closely spaced.
After testing I'd also recommend gluing the dock connector to the pcb for added future security.
Hope this helps.
Posted on Oct 01, 2010
I found a website that had the phone # of their head of Technical Support (http://www.waves.com/objects/pdf/press/press_sonic_impact01.pdf ) It appears his name is “Big” Rich Bracke and his # is (760)944-0274.
Posted on Mar 05, 2009
SOURCE:
I have a new docking stationbut am unable to connect it to my old apple ipod canyou help please
Probably your new docking station is equipped with the new Lightning connector used by iPhones and iPads instead of the 30-pin connector used by old and newer iPods. Search on Internet to see if you can find a Lightning-to-30-pin adapter. Do not get a 30-pin-to-Lightning adapter; you will waste your money.The latter adapter is more readily available, but is used to connect an iPhone or iPad to and OLDER docking station equipped with a 30-pin connector.
Dec 25, 2014 | Apple Audio Players & Recorders
Does this work with the ipod touch 4th gen
Here are it's features
Product Features
  • Portable speaker/display system designed for all "dockable" iPods**
  • Crystal-clear, 7-inch widescreen LCD display with 480 x 234 resolution
  • Pair of aluminum cone neodymium drivers and Class D digital amp
  • Built-in iPod docking station; 3.5 mm auxiliary input for other devices
  • Measures 8.7 x 1.7 x 6.5 inches (W x H x D); 1-year warranty
Notice
Notice it say ALL iPods, as long as its not the 5th gen ipod with the new dock connector it should work fine.
Oct 14, 2012 | Sonic Impact 5090 Video-55 LCD Video and...
Need replacement battery for I-pod docking station Model#5084
I have a battery from my if-2 by Sonic Impact. My ipod connectionwent bad. Battery and charger available.
Jul 23, 2010 | Sonic Impact Technologies IF22 Docking...
Need Replacement Battery for Sonic Impact i-F2
If you're still looking for the i-f2 battery, I can get you one. Email me at [email protected].
Jul 21, 2010 | Sonic Impact Technologies IF22 Docking...
Sonic impact i-f2
There is no sound when I place my IPOD in the Sonic Impact F2 docking station. I can power on and off the Sonic Impact system with the remote control, however cannot change track on Ipod or nor sound? any idea as to why this is happening?
Apr 28, 2010 | Sonic Impact Technologies IF22 Docking...
Can any ac adapter be used with sonic impact IF2? Or does it have to be the charger made just for that device?
Just make sure that the VOLTAGE and MILIAMP input rating match what it says on the Sonic unit itself, and that the connector is the correct size. More importantly, make sure that the polarity of the plug is correct. Some are inner connector = positive and outer connector = negative or vice-versa. That also should be on a sticker on the Sonic unit or embossed into the case near the connector. DC voltage is UNFORGIVING when the polarity is reversed. The unit itself doesn't care WHAT is supplying the current to run it AS LONG AS ALL THE ABOVE FACTORS ARE MET. If this has been helpful, please rate it accordingly. Thanks and good luck. FYI: check eBay for universal power supplies that include different tips. One should fit your unit. $15-$30
Jul 15, 2009 | Sonic Impact Technologies IF22 Docking...
Sonic Impact iF2 Not charging
Hey how do I find a replacement battery for the Sonic Impact I F2?
May 07, 2009 | Sonic Impact Technologies IF22 Docking...
How do I get a manual on a Sonic Impact Technologies iF2
I kept "attacking the internet" until I found their home page and down loaded the manual. Bill Geist
Mar 02, 2009 | Audio Players & Recorders
IPod is not charging when docked.
my 6 generation nano will not play on my i-f2 sonic impact portable docking station, can any one help?
Jan 07, 2009 | Sonic Impact Technologies IF22 Docking...
900 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
