Question about Sony SLV-D300P DVD Player/VCR
Clock Setting problem Sony SLV-D300 DVD/VCR
When I try to set the clock in the setup menu, I get the following:  "For this setup, TV connection should be to DVD&VCR output
  • Anonymous Jun 06, 2008
    sony
  • Anonymous Mar 10, 2009
    I have the same problem, and it's absolutely infuriating. Why is it that the player can display the menu and handle other configurations, but when you want to set the clock, the "TV Connection" has to be set some way. And what exactly are they referring to? This is the last time I ever buy a Sony product as obviously their programmers are idiots.
I had the same problem at first as well. After an hour of frustration, I broke out the manual (imagine that! :) Come to find out, you cannot set the clock when in COMPONENT or SVIDEO mode. When I got the "For this setup, TV connection should be to DVD&VCR output" message, I can immediately switch the TV to RF mode (coax input mode) and voila!... the clock setup screen is available. I think it has something to do with the auto time sensing through the cable tv input. So, my advice - always be in RF mode (CH3 or CH4 depending on what you have the SLV-D300 set to) if you want to set the clock.
Note*** Yes, I agree it was idiocy on the part of the programmers in choice of wording for that error. A simple "Must be in RF mode to set clock" would have been much more helpful.
Posted on Jan 12, 2010
ABV511: how do you set the clock...
1. Switch your TV to Video mode (the one you use to watch VCR tapes)
2. Press VCR on the Allegro remote control.
3. Press Setup/Menu button.
4. The top item in the main Menu on the screen is Clock.
5. Follow the instructions on the screen using the gray triangular buttons on the remote to navigate
May 17, 2010 | Allegro ABV511
Set clock on sd-kv550-su
There are two ways to set the clock on your machine, firstly by using the 'auto clock' feature and also a manual setup, if the auto setup doesn't work then you will need to setup your machine manually. the 'auto clock' feature will atempt set itself up and will take approx 4 mins for the machine to adjust itself. There is also a daylight saving setting which you can either have set to on or off. The auto and manual steps that I have added below have been taken from the user manual for your your Toshiba SD-V295 pages 24 - 26.
Hope this helps,
James
Auto Clock Adjustment
Preparation:
• Turn ON the TV and select the corresponding video input.
• Press VCR DVD selector to select the VCR mode.
(The VCR mode indicator will light.)
1. Connect the Antenna or Cable system.
If you use a cable box, turn it on.
2. Plug the AC power cord to the AC outlet.
3. Make sure the DVD/VCR is turned off.
If you press POWER, the Auto Clock set is not programmed.
4. Wait at least three minutes and press POWER.
5. Press CALL DISPLAY to check the clock setting on the on screen display.
6. If the clock is not set, check the antenna
condition. The AUTO CLOCK may not function properly if the reception condition
is not good.
Manual clock setting
1. Press VCR MENU.
2. Press SET + or – to select “SYSTEM SETUP”, then press ENTER.
3. Press SET + or – to select “CLOCK SET”, then press ENTER.
4. Press SET + or – to set the month, then press ENTER.
5. Set the day, year and time as in step 4.
6. After setting the clock, date and time starts functioning automatically
Apr 25, 2010 | Toshiba SD-V295
Will not stop auto
This particular Unit will blink Auto while it's trying to set the internal clock using your cable signal. Make sure your antenna or cable source is connected to the unit before you plug in the AC power. When it is done setting the channels and time the blinking will stop and display the local time. Please refer to page 16 of your user manual.
Jul 13, 2009 | Sony SLV-D360P DVD Player/VCR
User manual how to set clock on Sansui dual dvd vcr player.
Go into SYSTEM SETUP. thats where the clock settings are.
Mar 12, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
Vcr clock setting
Probably you can't. That's a big pet peeve of mine with A/V equipment these days- so much of the control is by remote only and if it dies your machine is almost useless
Mar 05, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
How to set the clock on vcr/dvd.
Make sure the antenna//cable TV connections are correct. Channels are set. If this unit is connected to a cable/satellite box, select the local PBS station on them to set the clock automatically.
There's an Auto Clock Setting. "This Unit can set the time and date automatically by reffering to a PBS station.". But I never had to do that, I just went to Setup and it already knew what the date and time was.
"Note: The clock may set itself automatically after you connect the antenna/cable signal and plug in the power cord. Only the analog PBS channel signal is effective for auto clock setting. The unit receives the clock data at 12:00 A.M./P.M. from the PBS channel when the power is off.
1 Press [SETUP] and use the up and down arrows to select "General Setting", then press OK.
"General Setting" menu will appear.
2. Use up and down arrows to select "Clock" then press OK.
"Clock" menu will appear.
3. Use up and down arrows to select "Auto Clock Setting", then press OK.
4. Use up and down arrows to select "Auto" then press OK.
5 Press SETUP to exit.
6. Press STANDBY-ON to turn off the unit.
This unit will search for the time only when the power is off. Leave it off for several minutes to give this unit time to set the clock.
If the unit chooses an incorrect PBS channel, set the PBS channel manually by following the steps below:
1. Select "Manual" at step 4, then press OK.
2. Use [the number buttons] or up and down arrows to enter your PBS channel number, then press OK.
3. Press SETUP and turn off the unit.
If this doesn't work, let me know and I'll type up the instructions for what to do if you need to actually set the clock manually.
Mathis...
Feb 17, 2009 | Philips Magnavox DVD/VCR Dual Player
How do I set the time on my Pioneer RT500?
Hi!
Please follow the instructions given below... =)
Setting the clock
The clock is set to the correct time automatically, but it
can also be set manually. The clock can be set for
daylight saving time and time zone.
Preparation:
• Turn ON the TV and set it to the video input mode.
• Select “CLOCK” from “SYSTEM SETUP”. For the
procedure, see steps 1 to 3 in “Using the SETUP
MENU”
1 Press SETUP while the DVD and video tape is
stopped.
The SETUP MENU screen will appear.
TIMER REC SET
SYSTEM SETUP
AV SETUP
REC SETUP
CH SETUP
OTHER
SETUP MENU
ENTER/
SELECT ENTER RETURN BACK SETUP END
SELECT
2 Press  or  to select the desired menu and
press ENTER.
The submenu screen of the selected menu will appear.
TIMER REC SET
SYSTEM SETUP
AV SETUP
REC SETUP
CH SETUP
OTHER
LANGUAGE
PARENTAL
CLOCK
DISC SETUP
OTHER
SETUP MENU
3 Press  or  to select the desired submenu and
press ENTER.
The screen for the selected submenu will appear.
CLOCK (manually)
You can manually set the date, year and present time
with the remote control.
Ex.: Setting the clock to “10:20AM” October, 30th, 2004.
1 Select “CLOCK” and press ENTER.
01/01/04 12:00AM
2 Select the desired items using  or  (month,
date, year, hour, minute and AM/PM) then press
ENTER.
3 Press  or  to set the value of the selected
item.
• For the minutes, press  or  once to set the time
minute by minute, or hold down either of buttons
for several seconds to set the time in 10-minute
intervals.
10/30/04 10:200AM
4 Repeat steps 2 and 3 to set the date, year and
present time, and press ENTER. The SETUP MENU
will close.
This completes clock time setting.
AUTO CLOCK
You can automatically set the clock by turning “ON” the
AUTO CLOCK function.
When you want to set the auto clock function to “OFF”,
select “AUTO CLOCK”, press ENTER and select “OFF”
from the list.
Auto clock setting
Preparation:
You must connect the antenna or cable before connecting
the AC cord to the power source.
Wait 30 minutes with the power turned off, after the
antenna or cable is connected, for the auto clock
feature to activate.
After the clock is set automatically, you may have to set
the time zone and daylight saving time. (See page 26.)
Press STANDBY/ON to turn on the DVD/VCR after the
auto clock operation completed.
• When shipped from the factory, the “AUTO CLOCK”
option is set to “ON” position.
• If you turn the DVD/VCR on during auto clock
setting, the clock is not set.
• After a power failure or disconnection of the power
plug, the clock setting will be lost. In this case, wait
30 minutes before turning the DVD/VCR on.
• With cable box connection, if the auto clock setting
is unsuccessful, select the PBS channel carrying
the XDS information, then turn the DVD/VCR off.
After 30 minutes, turn the DVD/VCR on.
• If the clock is not set automatically, set the clock
manually.
STANDARD TIME (Time zone)
In the rare event that you live within the broadcast range
of two stations in two different time zones, the DVD/VCR
may recognize the wrong station for the auto clock set.
To correct the situation:
Select “STANDARD TIME” and select the time zone from
the list below.
Selectable time zones and correction times
ATLANTIC: GMT – 4 hours
(GMT: Greenwich Mean Time)
EASTERN: GMT – 5 hours
CENTRAL: GMT – 6 hours
MOUNTAIN: GMT – 7 hours
PACIFIC: GMT – 8 hours
ALASKA: GMT – 9 hours
HAWAII: GMT – 10 hours
AUTOMATIC: AUTO SET
Note
• When shipped from the factory, the “TIME ZONE” is
set to “AUTOMATIC”.
• After making the auto clock setting, in some cases
the clock may display another time zone. You can
correct the clock by selecting your time zone
setting above.
• When the clock is not set or you set the clock
manually, the time zone setting is not available.
DAYLIGHT SAVING TIME
You can set the clock to daylight saving time automatically
or manually.
To select daylight saving time, select “DAYLIGHT
SAVING TIME” and select “ON”, while to cancel the
daylight saving time, select “OFF”.
ON: For manual setting (forward 1 hour)
OFF: For manual setting (back 1 hour)
AUTOMATIC: For automatic setting (read XDS in
the signal)
Note
• When you want to set daylight saving time, on the
first Sunday in April you set it to “ON”, and on the
last Sunday in October you set it to “OFF”.
• When shipped from the factory, the “DAYLIGHT
SAVING TIME” option is set to “AUTOMATIC”.
• When the clock is not set, the daylight saving time
• When there is no daylight saving time in your area,
always select “OFF”.
Jan 03, 2009 | Pioneer DVR-RT500 DVD Recorder/VCR
Zenith XBV443 DVD Player / VCR Combo - Set Clock Manualy
I have the Zenith xbv613 model DVD/VCR player and also need to change the clock set up. For the xbv613 I had to switch the player to VCR. The menu button did not bring the clock set up in DVD. When I switched to VCR and hit the menu button the clock set up showed, where I used to right arrow button to change the time. Hope this helps.
Sep 24, 2008 | Zenith XBV443 DVD Player/VCR
Setting clock on older VRDVD4001AC
According to the manual, to set the standard time, you should press VCR MENU, then SET + OR - to select System Setup. Press ENTER. Press SET+ OR - again and then choose STANDARD TIME followed by ENTER to set your own time zone. Press SET + OR - one more time to select your time zone, and then again press ENTER. To return, press VCR MENU twice.
Just a note: The unit is set to AUTO CLOCK when it is shipped. If you leave it this way, the clock will set itself after you plug in the unit provided you do not press POWER for at least three minutes when you first plug it in. Also, your cable box or antenna must be attached in order for it to find the time.
Mar 12, 2008 | Sansui VRDVD4001 DVD Player/VCR
Sony SLV-D300P DVD Player/VCR Logo
256 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
