Question about Saws
Motor tries to start but turns slow. - Saws
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 221 Answers
There should be what is called a "start" capacitor on the motor. You may need to remove the back cover from the motor to get to it or it may be mounted externally. I would replace it.
Posted on May 11, 2010
2005 jaguar VDP 4.0L. Very hard start. Have replaced map and crank sensor, egr valve and intake.
in what way is it hard to start does the engine turn over fast or slow, fast is low compression in the piston chambers slow can be the battery or the starter motor wearing out. ( starter motor has bushes to turn the motor these wear out and cannot turn the engine over fast enough to start.
Aug 10, 2017 | Jaguar Cars & Trucks
My mom's old singer will start sewing then slows down to a stop.
It may need a REALLY thorough cleaning & oiling, Cindy, including the motor bearings. The motor's windings may be getting weak, too, or the new belt may be slipping.
Aug 11, 2014 | Singer Sewing Machines
Blower mtor on 1997 Chevy 1/2 ton 4wd runs real slow or not at all,some times it speeds up to near normal speed.
Yes, the blower motor is bad, replace it. This is exactly what you say, brushes are worn.
Dec 04, 2013 | Cars & Trucks
Reset pcb bosch classixx 1200 express
There is no reset as such, if the motor shorted when the motor brushes went there is a good chance that it blew the motor tracking or relay on the board. Sometime this is indicated by F20 or F21. Unfortunately this will be a new board. You could try to run a motor test as follows:
Hold in the start button while turning the dial one click to the left (30 easycare) wait until the display shows 888 or two indicators light up next to dial.
Release start and turn dial to 60 cotton (WITHOUT GOING THRO THE OFF).
Press start
This should start a motor test
slow turn one way, slow turn the other, pump on then up to full spin.
(some machines will show the rpm on the display).
If this does not work, you probably need to change the module aswell.
Best of luck
Mar 20, 2013 | Bosch Classixx WFO 2866 Front Load Washer
How do you know if the motor is going bad? Sometimes when I start it the motor will hum for a few seconds and them will start real slow. other times it wont start at all. can I isolate the motor to see if...
Three possibilities: the drum bearings may be worn causing hard turning, the motor bearings may be about worn out allowing the rotor to contact the stator inside the motor, and last, but maybe the most likely, the start capacitor, which is mounted near the motor, may be going bad causing weak starts at first, then no-start/loud humming finally. Take the belt off of the motor pulley and start the dryer--the motor should almost instantly be running full speed. You can test the motor bearings (when motor is OFF) by trying to push/pull the shaft in various directions sideways. Any obvious slop is a sign of worn bearings. Try turning the drum by hand to see if it turns fairly freely. Hope this helps!
Feb 28, 2010 | Dryers
Motor runs slow with belt off then will speed up frigidaire dryer
bad motor / holding button will burn it out. ths keeps it on start winding . try blowing the motor out ( delint motor and dryer . ) it will run cooler . motor sounds like it already bad and needs replacement. mm
Dec 03, 2009 | Frigidaire FER231A Electric Dryer
Replaced a blown engine with a used one engine will not start turns slow gets sprk ,replaced coil pak and starter,also sparkplugs and wirers still will not start ,ckecked all wire plugins did not see...
you said the motor turns over real slow have you checked the battery charge, if so did the motor turn freely before you installed it. it could have seized up if it sat a while before you installed it try spraying some starting fluid in the throttle body and starting it
Aug 23, 2009 | 2000 Ford Contour
Dryer drum wants to start turning but goes will slow
sonds liker the motor is overheating oyo can try to open the dryen and look for excessive lint hindering the motors operation causing overheating
Mar 05, 2009 | Whirlpool LER4634J Electric Dryer
Quit
Is this a top loader? Im guessing it is. Try to turn the basket by hand. Is it hard to turn. Sometimes a piece of clothing will get stuck between the inner and outer tub causing resistance. Do you have a model #? thanks dave, www.washermd.com
Dec 15, 2008 | Washing Machines
Saws Logo
81 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
