Question about Olevia LT32HVE 32 in. LCD Television
Dark picture on composite inputs ?
When I'm using the composite inputs (both of them) I get dark picture, really ugly :(. At the moment I switch to analog input the picture is good, but I dont have the HDTV quality anymore.
The technician from Time Warner come and we tried brand new set-top/decoder box. He unpacked it in front of me.
That is why I think it has something to do with my Olevia ?
Is this easy fixable... send an email to Olevia nobody bothered to answer.
What could be the problem.
thanx in advance
  • 979 Answers
Are there any other components connected to your set?
There could be a conflict with those devices is the reason I ask..
Posted on Jul 01, 2008
SOURCE:
How to connect dvd player to LG RZ-32LZ55 in LCD TV
This 'TV' is really more of a video monitor. It has one DVI input, 2 SCARTS (1 RGB); component video input; composite video input; S-video, and stereo audio and RF inputs. Best picture would be using the component inputs if your DVD player has the outputs. If not you'll have to consider the S-video or composite (yellow) plugs. (Neither is HD capable....)
Jan 20, 2015 | LG Televison & Video
Power went off a moment now back on TV sound and words on but no picture at all black screen?
Try another input like DVDs player or game station something other than normal. For example if using the cable input. Try the HDMI port or componet or composite ports. If none of those work the then your GPU is blown. And if that is the case you will most likely be better off getting a new TV.
Dec 28, 2014 | Samsung Televison & Video
Sony Bravia kdl-42ex443 I have no picture (just blank, dark grey-ish screen) but can hear the sound. I have tried changing the channel but the problem remains the same, I have also tried the classic 'turn...
Have you tried changing inputs on the tv? on the remote there should be a button called "input" that will cycle through the plugs on the back of the tv. If you are using the "Green, Red, Yellow" that is composite, if u are using a single flat-end cable, it will be called HDMI. Cycle through all the inputs and when you land on the right one, the picture should show.
Short Version:
Press input button on remote, until you see picture.
Aug 29, 2013 | Televison & Video
Television picture is black and white
Check how things are connected to it. If you are using the composite inputs they may not be hooked up correctly.
Try another source if you can to see if there is any difference. In some cases just switching has been known to reset this condition.
I don't believe a Black and white picture is really a symptom of the TV but rather what you are putting into it.
Hope this helps.
Mar 02, 2011 | Maxent MX-42HPM20 42 in. Plasma HDTV
TV will turn off then turn back on by itself the input shows up at the top when it comes back on. The start up sound does not play when the picture restores. Has happened when watching TV (HDMI) and play...
The first thing to do is disconnect ANYthing that is connected via HDMI and then use the component, composite or s-video inputs and see what happens. If it works ok then most likely what ever is connected to your TV via HDMI is causing the issue (it does happen). The second thing if that doesn't solve the issue is replace the lamp if its getting really dar and has never been done before. If the emmisions of the lamp are low (darker picture) the set thinks the lamp is not on and will force a restart..Please take a moment to rate my answer...Thanks
May 18, 2010 | Samsung HLP5067W Television
Sanyo DP46849 composite video input malfunction
Sounds like a damaged port or related circuitry. You could take it to a repair shop if you really want to use that port, wouldn't cost too much
Feb 06, 2010 | Sanyo DP46849 46 in. HDTV
Cant get picture or sound...Proscan 27113
You can tune to 90 for input 1 S-video, 91 for input 1 composite and 92 for input 2 composite only.
Most RCA and GE brand replacement remotes will work using code 000, or 001. I use code 237 for my 5 in 1 remote and can get PIP and the setup displays to work.
tom
Jun 15, 2009 | Proscan PS27113 TV
Composite a/v and s-video picure look like hell.
I want my computer photo to see it on cd/dvd players
Jan 12, 2009 | Yamaha RX-V663 Receiver
Component Video Inputs/Outputs Not Behaving as advertised
I have had this problem in the Field with a Client. I had fixed it by going into the ADCOM menu and Resetting ALL of the Inputs and output for the Devices. You have to select everything you need, then exit out of the Menu, SHUT OFF the ADCOM, WAIT about 10 secs, then turn it back on. Or Else it Does Not SAVE Properly! Weird. If you can not see the Menu on the TV Screen then try to hook up a Composite (Yellow) cable from the ADCOM to the TV and select the TV input to make the Changes. I really hope this helps out it sounds like an Evasive problem which is hard not being in front of the Equipment!
Nov 29, 2008 | Adcom GTP-860II
Olevia LT32HVE 32 in. LCD Television Logo
59 people viewed this question
Top Olevia Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
