Question about E-Machines eMachines Desktop PC
I have a 2003 or 2004 emachine that I am trying to start up to get my old info from however I have two issues. 1. No signal from monitor and I have checked all cables. 2. When I turn on the cpu there is a repeated beep noise. Any suggestions? What I was hoping to do was to just restart it to a previous date?
  • 64 Answers
When a computer starts up it runs Power On Self Tests (POST). When it finds a problem and can not continue it beeps out a code of long and/or short beeps. Run a web search for beep error code or POST beep errors. Most likly issues are memory or a video card that is not fully seated / making contact.
Posted on May 11, 2010
2 Suggested Answers
SOURCE: I have a 2003 or 2004 emachine that I am trying to
one of your ports is not working or your ram is not seated. thus beeping. On mine once I seated my ram the beeping stopped and I could continue.. If you say there is no signal to the monitor maybe the video card is bad. do you have a spare to throw in and try. Then hook it to the internet, either with an ethernet or wireless adapter and have it find your driver and maybe that will work.
Posted on Mar 17, 2010
White screen
test your computer with another monitor, if same issue occurs, problem is on video card/cables of your computer, if it runs good on another monitor, old monitor has problem.
Mar 22, 2014 | eMachines 15 inch Monitor
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
No signal to monitor
Check ALL cables, connections, try another monitor/cable. You didn't provide the Model of eMachine? Does it have a PCI Graphics Card? Reseat Card.
Jan 05, 2013 | E-Machines eMachines Desktop PC
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
Jan 03, 2013 | Computers & Internet
I have a emachines amd athlon 64/ 512mb memory / 160gb hadr drive dessk top. when i turn it on the monitor displays no signal and goes off. ihear the prossessor motor running constantly which normally goes...
Please check the cable that connects the monitor to the video card. Reseat the cable, the issue might be a loose connection. You can also try a known good monitor to isolate if it's the video card or monitor that is causing the problem. Something is preventing the monitor from receiving signals from the video card, hence the "no signal" message.
May 19, 2011 | eMachines Desktop / AMD Athlon Processor /...
My emachine desktop monitor keeps cutting on and off by itself. What should I do?...it's really aggravating.
There are three possible reasons for the issue:
1. Monitor power cable is loose
2. Video Adapter is faulty
3. Monitor capacitor is gone bad
Please try the below steps to diagnose the issue:
1. Check the power cable on the back on Monitor, if connected properly, like connect the power cord on a different Wall outlet
2. Unplug the signal cable from the video adapter and replug it. Also, check a different monitor (if any) on the Tower.
3. If the above steps fails, then the issue is with the monitor, it is going for repair.
Thanks and regards,
Jitha
Nov 23, 2010 | Computers & Internet
No signal to monitor. No beeps at start up. Fans running. New video card installed (after issue began) monitor & cord are working fine (have checked both with other computer)
There might be a problem with your RAM you may check your RAM and clean it with a cotton cloth and fix it again or change your RAM and see
Or the problem can also be with your moniter
thanks
May 14, 2010 | E-Machines eMachines Desktop PC
When I start my computer, the monitor shows the message "No Signal R G B" The colors are off. I get Blue, no red and a distorted green. Sometimes the colors are perfect. It's a 15" TFT LCD monitor
If all connections are tight. See if someone has a laptop or another PC to hookup to the monitor to pinpoint if its a video card issue or a monitor related issue.
Apr 26, 2010 | E-Machines eMachines Monitor E15T4
I have a 2003 or 2004 emachine that I am trying to start up to get my old info from, however I have two issues. 1. no signal from monitor and I have checked all cables. 2. when I turn on the CPU, there is...
Mar 17, 2010 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
154 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
