Question about Copystar CS-1500 Copier
CS-1500 Copier: error code A-400...
Error code A-400
  • 3 Answers
If you are a little mechanically inclined you can remove the exit inner cover, remove the laser unit and the on the laser unit remove the screw's that home on the top cover, then remove the 2screws that hold the laser mirror in place and use a q-tip to clean the hole that the mirror floats in, I use a scotch brite pad swatch wrapped around the q-tip with a little bit of laquer thinner on the swatch and twist the q-tip in the hole. Then use a piece of scotch brite on the shaft of the mirror and clean it up then put 2 drops of oil in the hole and abit of oil on the shaft and reassemble, it should spin super freely and reassemble the whole thing and fire it up, this will work for a long time and it's a real money saver for your customer.
Posted on Aug 31, 2014
  • 113 Answers
This is similar to c400, laser unit related error. replace laser unit
Posted on Sep 22, 2010
I had error code c-6 400 and fixya solved it but immediately i finished the procedure, it brought error code c-6 000
Hi, the fuser unit will have to be replaced if several resets have been performed, or your electricity is not constant.
May 11, 2017 | Kyocera Mita Toner For Kyoceramita...
What does the error message OP mean on my Kyocera mita KM-1500 copier?
From what I remember on this copier...... The software in the copier may be from another country.... OP or AP most likely the copier needs a new toner installed or could be a paper jam in the doc feeder. The codes were a bit messed up between different countries, I did not biuld them.... Good Luck
Dec 19, 2012 | Kyocera Mita Toner For Kyoceramita...
Has a error code on display C-6 and then 400 blinking
press and hold Stop key start key and left exposure or light key. Release them then press stop. machine will show U000. Enter 163 using the scroll up and down keys. Press start key twice. the machine will initialize.
Jan 24, 2011 | Copystar CS-1500 Copier
I HAVE A CODE C-6 ON COPIER AFTER POWER WENT OUT
have a copystar#GS-1500 and after power went out, have flashing error code C-6 and 400. Worked perfect just prior. please help!
Oct 13, 2010 | Copystar CS-1500 Copier
After a power surge, the machine is flashing 400 and C-6. Unable to reset it.
if you are unable to reset the error using simulation U163 remove the fixing unit and check the continuity of the heater lamps and thermostat. if lamps ok. replace thermostat
Aug 09, 2010 | Copystar CS-1500 Copier
Error c-6 keeps appearing
codes that start with c6 are caused by a problem in the heater. blown thermal fuse,
or bad heater lamp. you can access from the rear of the machine
Jul 15, 2009 | Copystar CS-1500 Copier
C-6 ( 400 )
KEY IN 1087 TWICE N PRESS START, ENTER CODE ERROR EG.400 N PRESS START. ONCE IT SHOWS CLE, ENTER 163 N PRESS START. WAIT FOR IT TO RESTARST. LALI.
May 18, 2009 | Kyocera Copystar CS-1620 Black and White...
I'm getting c-6 400 code
This is a fixing error.But it can be caused by a power dip aswell.
Try to reset it,if the error presist then there is a problem on the fixing.
To reset-Switch the machine off,open the front cover,switch the machine on again.If it shows "open cover",press the system menu counter button.press the arrow up ones to display system settings,hold the start and # button in and press "ok"or"set"
go down with the arrows untill maintenance mode is display,press ok,then enter the number 163 and press ok.
set it for exeuteand press ok.
Then the error will be cleared.
Jan 22, 2009 | Copystar CS-1500 Copier
Error code C-6 for kyocera km 1500
c6-400 code error is poor connection (power supply)
press start and clear/stop button
the code is inizialized
Mar 02, 2008 | Kyocera KM-1505 Copier
Copystar CS-1500 Copier Logo
135 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
