Question about Panasonic Panafax UF-585 Plain Paper Laser Fax
Panasonic Panafax UF-585/595
The fax machine seems to be in working order;
However I do not recieve any faxes - the machine rings - says on line recieving then the memory button lights up - there is no code to indicate any wrong - I cannot retrive thefax from the memory why?
An answer to this problem would be most appreciated.
  • Stuart Gorman May 26, 2008
    I have the exact same problem as STANN, I can send Faxes but not receive.
  • 33 Answers
Could be a number of causes, most common someone fiddling with settings, secondly adsl internet und unfiltered lines so put filter on fax and any ext. ph. lines also contact your telecomunnications co. (and waste hours of time, be put on hold 25 times, told your account number isnt valid, theyre having a glitch in the system, its not their problem, youll have to ring back later, confirm your adress, D.O.B.- Ph no. -credit card no.- tax file no.- and your third cousins 2nd wifes stepsons- ex girlfriends- brothers 4th grade teachers middle name) and ask to have the line checked
Posted on Jun 15, 2008
Panasonic uf 4000 fax not answering
Sounds as if your Fax is set to Tel Mode.Change to Fax as follows.
Function 7,then no 4.
Will show fax parameters? on screen.Press Start arrow up to recieve mode.Arrow across to change to Fax or Fax Tel.Press start to lock in.Press cancel button to return to raedy screen.
Sep 01, 2009 | Panasonic PanaFax UF-490 All-In-One Laser...
Panasonic Panafax UF-550 not receivng faxes
Check your line for static, should sound a clear tone. 95% of communication problems are related to line quality (phone company fix this). The other 5% is the modem PCB of the fax machine
Feb 12, 2009 | Panasonic Panafax UF-550 Plain Paper Laser...
Panafax UF-880 - volume of phone ringer
1- incoming volume press the down arrow till you want the desired level
2-outgoing volume. press monitor you will hear a dial tone. press down arrow till desired level and press monitor again your done
Dec 04, 2008 | Panasonic Panafax UF-880 Plain Paper Laser...
Phone and fax recieving on the one phone line.
Hi Brad,
Press fuction 64 set.
Look at the print out for MANUAL MODE setting
Press fuction 74 set 1 set to enable MANUAL MODE
Now to receive a fax you must press START when the fax rings.
I don't think you're going to find a free manual. Check eBay.
Nov 14, 2008 | Panasonic Panafax UF-880 Plain Paper Laser...
Telephone rings only twice
No. Fax machines are designed to have their own dedicated fax lines.
Some newer models, tho, allow you to set NUMBER OF RINGS.
Oct 30, 2008 | Panasonic Panafax UF-550 Plain Paper Laser...
Paul,
Seriously, fax machines are designed to have their own dedicated analog phone line.
You can get a fax/phone switch from Radio Shack to hanle this problem.
May 09, 2008 | Panasonic Panafax UF-550 Plain Paper Laser...
Panafax UF560 - how to set so confirmation page is automatic ?
Function 7 4 set.
07 (Header Print)
Setting number 1 (Inside copy area) 2 (outside) 3 (none)
Set.
You can also set the header format with Parameter 08(Header Format) 1 is for your Logo and fax number. 2 is for From: to:
Feb 01, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Panasonic Panafax UF-585 Plain Paper Laser Fax Logo
171 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
