Question about Pool & Spa
Pilot light wont stay onfor outside pool heater. Gas co made a service call & relit the pilot light it went out again 4 days later.
    Sniper:
  • 52 Answers
There is a thermo couple that keeps the gas on. The pilot light bracket has a small screen where the gas comes through that can get clogged and cause the pilot light to burn away from the thermo couple which would cause it to think the flame has went out and shut the gas off. Or the thermo couple has went bad itself. If you try cleaning the screen use canned air and gently blow it through the orfice once you have taken it off. If you don't know what a thermo couple is or looks like here's a picture of a generic one that will give you an idea. Usually there's a bracket that holds this in place. pilot light wont stay on - f1b528a.jpg
Posted on May 11, 2010
Pilot light wont stay onfor outside pool heater. gas co made a service call & relit the pilot light, it went out again 4 days later.
Thank you for posting your question here on Fixya.com.
Has anyone replaced the pilot generator yet? A millivolt heater (one with a pilot light) requires about .75 volts from the generator to operate. As the generator ages it puts out less and less voltage and eventually gets to weak to even hold the pilot gas valve open. Replacing it with a new generator will usually fix the problem you describe.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Mar 17, 2010 | Pool & Spa
Pilot light went out but will can,t get it relit it only stays on as long as I hold the button down
Is the thermocouple in the pilot flame? & does it get hot [glow red] If not adjust position until it does & make sure it's clean
If thermocouple gets hot but no relight, replace couple
Oct 26, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Can't re-light the pilot light
THIS HEATER DO NOT HAVE A PILOT YOU MUST HAVE A DIFFERENT MODEL. DO YOU GAS? TURN KNOB TO PILOT PRESS. LIGTH PILOT WAIT FOR 60 SEC AND RELEASE IF STAY ON TURN KNOB TO ON. IF TURN OFF PILOT MUST BE REPLACE
Jun 20, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Pool heater won't stay lit
check gas pressure might be running out of pressure gas meter might be too small and heater could be overheating
Jun 03, 2009 | Teledyne Laars Pool & Spa
Wall heater new 07, worked great all last season, turned on this
there could be something stuck in the pilot assembly since you added a new tank to system. Check to make sure flame is hitting thermalcouple. Can you wait for a repair man to come and take pilot assembly out and clean. He will also replace thermalcouple. If you can't wait and you feel comfortable with taking pilot assembly out. Turn gas and electric off to unit then pull cover panel off. Pilot assembly is held in with two screws. Take tube off of gas valve and take off thermalcouple line off gas valve too. take out pilot assebly. Once you have it out take gas line off bottom of pilot assembly. There is a orfice in side make sure you can see through the orfice. You can also clean thermalcouple with a wire brush or sand papper. Reinstall pilot assembly make sure all fittings are tight. turn gas back on and light pilot. If everything looks good turn power on. Turn heat up run heater for a few minutes then turn heater down and let sit to see if it will stay on.
Nov 27, 2008 | Empire GWT-25 Wall Mounted Panel Heater
Pool & Spa Logo
156 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
