i830 camera that powers on, but nothing else. Screen shows a default screen saver like image. Camera is appox. six moths old and has undergone no trauma. No buttons respond. Please help!
Comments:
Mar 29, 2008
- Thanks Panther85,
However I had already tried the remove batteries fix with no success. As far as the first option, it's an impossibility because as stated "no buttons respond". Finally in regard to the Polaroid Tech help site, it's down and states "sorry for any inconvenience".
I do appreciate your effort though, thanks again. Sincerely, =PandaPaw=
Resetting to Default Settings
You can easily change all the settings you made back to the camera default setting by the following steps.
Please refer to "Camera Default Settings" on page 103 for more details.
1. Access the setup menu.
2. Press or to select (RESET ALL).
3. Press the or button.
4. Press or to select "YES".
5. Press the button.
Setup Menu 3/3SelectExitBattery Type AlkalineReset All NoSetup Menu 3/3SelectOKBattery TypeReset AllYesNo
NOTE:
The following settings do not change with this procedure:
• Date & Time setting
• Language setting
• TV out setting
Contact Information Phone: 1-877-388-3779 Email: Click Here Customer Support Hours: (Mon - Fri:) 10:00am - 7:00pm EST (Sat:) 10:00am - 4:00pm EST
Warranty on Cameras 1year parts and labor
There is no response from the camera while pressing any buttons.
The LCD screen is frozen or the camera is hanged.
Remove and re-install the battery or batteries to reset the camera. Your valuable data stored in the camera will not be lost.
I hope some of this helps, if not above is the contact number for Polaroid tech support. You camera seems to be still covered under warranty.
Good Luck
poloroid 534 camera. len won't go in and when you try to take a picture it won't take one. batteries...
(More)
poloroid 534 camera. len won't go in and when you try to take a picture it won't take one. batteries are fully charge
