Question about Fujitsu LifeBook E8010 Notebook
I have a Fujitsu Lifebook LBS6120 notebook
17 Mar 2010 I have a Fujitsu Lifebook LBS6120 notebook computer. When I press the power on button the cooling fan begins to run immediately yet there is no display or any indication that the notebook is booting up. The display remains black and the cooling fan continues to run. This condition occurs when using the main or battery supply. I must remove the main and remove the battery to turn the notebook off. The notebook has performed very well for many years until this issue occured today. Yor advisement will be appreciated. Thank you.
  • Abdulhakim
    Abdulhakim May 12, 2010
    Try to to see if the LCD screen is too dark but not off? sometimes you can have that , because of inverter board failure.
2 Suggested Answers
  • 341 Answers
SOURCE: I have a Fujitsu Lifebook LBS6120 notebook
Turn on as you did before and leave on for 10 minutes. Then, try turning OFF the computer by keeoing the POWER button pressed for 7 secons. If the computer goes off, then your screen is fried and the computer is actually booting up normally... you just can't see it ;)
Posted on Mar 18, 2010
Good day to you.... I have a fujitsu lifebook c1320d laptop wont turn on, just blink the application led can tell me whats the problem with my laptop please help me..thanks
sound like the battery is shorted, did you let the notebook completely die without recharging?
Tony
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Mar 24, 2014 | Fujitsu LifeBook C1320D Notebook
Fujitsu lifebook s6520 is not comes ON when i press the power button the lifebook comes ON its all LEDs & processor fan sound is listened but then just NUMLOCK led starts blinking after that blinking...
Is the monitor working. If have not checked it try connect it to an external screen. If the screen is okay, try and remove memory (RAM) and after ten seconds you place it backup and start the computer and check.
Dec 06, 2012 | Fujitsu LifeBook S6520 Notebook
My fujitsu siemens lifebook s 7110 is over heating what can ido?
You need to turn the laptop upside down and remove the panels, remove the fan assembly and clear the fluff and dirt from the copper heat sink.
If you don't feel that adventurous you can buy a laptop tray with built in fans that blow cool air into the laptop to help keep it cool and assist the main processor fan.
Jul 24, 2011 | Fujitsu Siemens LifeBook S7110 Notebook
I'm using fujitsu life s series s7211 and could not start up my laptop . the fan is running, the battery icon is showing, but no screen.
Try to unplug the power from the back of the notebook and take out the battery and any other accessories. While no battery and power, press the power button for 10 seconds to drain everything inside. Plug the power back, turn it on w/o the battery. If you have a POST screen then try to go Fujitsu website to see if there's a new firmware for the notebook. If no screen then you need to take it to a tech/repair shop.
Mar 19, 2011 | Fujitsu LifeBook S7211 Notebook
I have a fujitsu notebook model lbs6120-aa029e0b0. At first the notebook would start but not recognise the hard drive. when turning it on at other times it would work normally then freeze. Now the...
If the notebook is not working at all now, you have to test the power supply to see if it is providing enough power to run the system. I would try to put the battery back on, let it charge for at least 12 hours, then try to turn on the system with the battery still installed on the machine. That way we can eliminate whether the power supply has sufficient voltage carrying capacity to operate the system.
If that doesnt work, then its time to call Fujitsu.
Aug 02, 2010 | Fujitsu LifeBook E8010 Notebook
Hello my fujitsu e2010 jusr stop working it will
Hi. Try to remove the battery, unplug the ac adapter and press/hold the power button for 10 seconds then plug the ac adapter in. do not put thebattery back in yet. turn the computer on and see what will happen.
If nothing happens, your motherboard needs to be replaced.
Good Luck!
Jun 06, 2010 | Fujitsu Siemens LifeBook E2010 Notebook
Fujitsu Lifebook does not boot up
Have you tried draining the static on your computer?
Turn off the computer
remove the battery and adapter
press and hold the power button for 1 minute
plugged back in the adapter and battery
turned on the computer
if not resolved:
tried using an external monitor and connect to your computer to check if you can have a video on the external, if yes it is possible an LCD issue
Also, you may try using a flashlight in your LCD and check if you can see any, if none?
I suspect possible LCD issue.
May 21, 2010 | Fujitsu LifeBook A6010 Notebook
Mar 17, 2010 | Fujitsu LifeBook E8010 Notebook
Fujitsu LifeBook E8010 Notebook Logo
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
