Need an copy of a wiring diagram for z660.
Trying to run my rear channels in my theater with an elan z660. However having trouble getting the amp to put out any sound and i believe its because i dont fully understand the remote trigger. It is different from my other amps. How do i get a copy of an installation manual to help?
Duncan
  • 218 Answers
SOURCE: Rotel RA 9808X Amplifier
I'd suspect that one of the two output transistors on that channel has gone bad. If you are unsure how to test or troubleshoot this, then you might try replace both the NPN and PNP outputs and catch the bad one that way. If your amp uses an output module then you would of course have to replace the module which would replace all the output transistors on both channels. Good luck. Another thing to look out for, is the emitter bias resistors. They are the large white ceramic ones near the outputs. Sometimes one of those will open up too. They will be of a very small resistance value like .5 ohms (point five ohms) or something in that general ballpark, and have a wattage value of typicaly 5 watts. So they are pretty big resistors. Be sure to check them all even if you do find a bad output transistor. They will often go out with the transistor. Good luck.
Posted on Jan 18, 2007
SOURCE: Wiring Diagram
First, try looking here: http://www.crutchfield.com/learningcenter/car/amplifiers_movie.html If that helps, be sure to leave feedback or I don't get paid. Look all over the cruchfield page and you can find guides for every type of installation.
Posted on Oct 03, 2007
Siliconchip
  • 52 Answers
SOURCE: GEM SOUND PA-750 POWER AMP
Hello plumer,
Locate a small slide switch at the back panel of your amp.
3 terminal and if you've snapped one of the wire, you'll see where the wire goes. But if it is 2 wire and using a ribbon type, follow the arrangement of the wire. No harm to the amp if you make a mistake. if bridge, all power will be shifted ti the left channel.
Good luck,
Posted on Apr 29, 2008
Duncan
  • 218 Answers
SOURCE: How to connect the amp,too many inputs and outputs
I'll try to help you step by step from your question. My answers will be in all caps. Here we go.
I really hope u can help me,i have 2 basic speakers with connections in the back for the amp leads to go into,but i am really struggling with what wires i put into the amp and in which connections and then really, really struggling with which connections i need to come out of the amp to go to my speakers.
I have a Carlsbro 150w power module
(THIS SOUNDS LIKE A PA AMP AND NOT A CONSUMER STYLE AMP, IS THAT TRUE?)
and it has an Output hole of which im guessing is where the speaker connection goes
(IF IT IS LABELED OUTPUT THEN IT IS INDEED A SPEAKER OUTPUT CONNECTION)
,but on the front of the amp i have 6 channels,each with a hole which is black that says HIGH Z,and also a red hole that says BALANCED LOW Z,
( THESES ARE MICROPHONE AND OR GUITAR INPUT JACKS AND MOST OFTEN YOU WOULD USE THE HIGH Z (meaning impedence) INPUT FOR A MICROPHONE
and next to it i have two buttons with REV and FX
THESE ARE FOR REVERB AND EFFECTS CONTROLS OR INPUTS. YOU DON'T NEED THESE FOR JUST A VERY BASIC SETUP.
.At the other end of the amp ,ive got another red hole that says REMOTE SWITCH
DISREGARD REMOTE CONTROL SWITCH JACK
and 2 black holes that say EFFECTS ,SEND and RETURN.Do i need these?
DISREGARD THESE TOO
I just dont know where to put my output line from my mixer to the amp.
IT WILL GO INTO THE BALANCED LOW Z INPUT, BUT IT MAY ACTUALLY BE TOO HOT A SIGNAL(signal strength too high), LOOK FOR SOMETHING LIKE A TAPE INPUT OR SOMETHING LIKE THAT ON YOUR FRONT PANEL. IF YOU DON'T HAVE ANYTHING LIKE THAT THEN YOU MAY NEED TO USE AN ADAPTER DEVICE THAT WILL KNOCK DOWN YOUR SIGNAL STRENGTH TO THE RIGHT LEVEL FOR A MICROPHONE INPUT AND THEN PLUG IT INTO THE BALANCED LOW Z INPUT.
PLLLLLLLEEEEEEAAAAASSSSSSEEEE HELP.Im tearing my hair out.
HOPE THIS HELPS. GOOD LUCK
Posted on Jul 31, 2008
LVT7857
  • 116 Answers
SOURCE: jensen uv8 and amp hook up
Remote wire from Jensen is blue or blue/white. Use Blu/white if there is one. . RCA's, for subs, use the rear if no subwoofer pre-outs are available. If unit has sub pre-uts, use them as the head ubit (stereo) would have a level that can be raised or lowered thus giving you more control over the input to the sub amp.
Posted on Jan 28, 2009
Yes does anybody know how to run speaker wires from a two channel 750watt amp to two 12" kicker comp 8ohm subwoofer's
Is this a trick question? An amp only has speaker outputs (plus and minus) and the speakers have corresponding inputs. Each channel would probably drive one sub.
Jun 14, 2011 | Pioneer 750-Watt Home Theater System,...
Im trying to install a sony xplod radio in my 1995 Nissan Maxima. im using scorsche wiring harness A/B. i did all necessary installation procedures and the radio works but im not getting any sound out of...
Maxima Wiring Diagram
1995-97 Nissan Maxima Stereo Wiring Constant 12V+ Pink/Blue Switched 12V+ Blue/Black Ground Vehicle Chassis Illumination Red/Blue Dimmer Red/Orange Antenna Trigger Black/Red Antenna Right Rear Front Speakers 6 1/2" Doors Left Front (+) Blue/White Left Front (-) Blue/Yellow Right Front (+) Brown Right Front (-) Brown/White Rear Speakers 6 1/2" Rear Deck Left Rear (+) Red Left Rear (-) Green Right Rear (+) Blue Right Rear (-) Pink
Diagram for any aftermarket head unit
Black: ground
Red: switched 12volt (accessory)
Yellow: 12v Constant
Orange: Illumination (Dimmer)
Blue: Remote
White & White/Black: +/- Front Left
Gray & Gray/Black: +/- Front Right
Green & Green/Black: +/- Rear Left
Purple & Purple/Black: +/- Rear Right
Dec 23, 2010 | Car Audio & Video
I have a problem with my samsung ht-up30 home theather system. When i turn it on it only shows "PROTECTION" and turns itself off right after that. How to fix it? Regards!!!
The amplifier has a bad channel, or is bad itself. It is trying to either output too much current or is not putting out enough. If you have multiple speakers wired to one channel, you will either have to change the wiring to series(unit positive to first speaker red, first red to second BLACK, second red to unit negative) or remove on speaker. (If this is the case, then you might want to look at this. It is a tip/rick to place and properly/successfully run three subwoofers, but the main concept can be used on all channels.) If all channels are wired to he correct speaker, then the amp is in fact at fault.
Jun 22, 2010 | Samsung HT-X20 Home Cinema 600W Theater...
Everytime I turn my on samsung ht-q70 the display screen says protection and the system shuts off. what can i do to get the protection off
Jun 21, 2010 | Samsung HT-Q70 Home Theater System System
Elan home system s12 manual
Only place to get it from is the ELAN dealer site. I have access to that area. Still need it??
May 06, 2010 | Elan VIA!dj-S MP3 Player
I just bout a ProTechnik Pt625 Home Theater System and it doesnt come with a manual, so I was curious on how to go about hooking everything up.
i sell these systems, its quick and simple.. I strongly sujest you get yourself some better thicker wire "16 gage". the 2 front speakers and center channel require wiering, match the bronze wire with the red and the other with the black. the two rear speakers are wireless so you plug one in the outlet and run wire to the other rear speaker you do not need to run the wire to the reciver the wierless router will automatically catch signal.. try not to have to many things interfering with the signal dont put more than 20 feet back...
Oct 11, 2009 | Audio Players & Recorders
Where can I get wiring diagram?
www.pyleaudio.com/manuals/PLMRA220-420.pdf
Jul 22, 2009 | Pyle - plmra220 - Marine 600 Watt 2...
Wiring Diagram for Sony car amplifier XM-554ZR
You can download the installation manual from the link below: http://www.sony.co.id/support/product/xm-554zr?site=hp_en_ID_i It has the following diagram plus other hookup info... Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 14, 2007 | Sony XM-2150GSX Car Audio Amplifier
No sound
Why would the sockets be bad??Is it that you move around the wires and the sound comes and goes?? Most likly it would be the rear channel amp. IC and this is a non consumer serviceable part. Check out the speakers on the front channel by switching the wires. If they come on then you know you have a problem with the rear Amp circuit. Contact a local repair shop and see if they can handle this repair . If not contact 800-211-PANA. Good Luck
Jun 24, 2006 | Panasonic SC-HT900 System
 Grubhead
Grubhead
