Question about Sony KDS-R60XBR1 60" Projection HDTV
I'm getting the 4 red light blink on my sony R60XBR1. What should I do. I've read to just clean the fan. Is this legit?
Yes this is legit. There's 2 fans and take out the big fan and clean it using a brush or something. I just did yesterday when my TV would not turn on with 4 red blinking light. Now the TV is working like new. Make sure you put everything back including the casing before you turn on the TV.
Posted on May 17, 2010
Red standby blinkig light 4 time on a sony 60 in wega
4 Blink 9 out of 10 times is your lamp fan. Check and make sure it clean and free of debrey. Spin it and see if there is any grinding noise. If after you clean and reassemble and the set still shuts down, either replace the lamp fan or check your outher 3 fans as well.
Apr 26, 2012 | Sony KDS-R60XBR1 60" Projection HDTV
What do i do if my sony sxrd power light starts blinking red
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly
Jun 17, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
Sony tv red light blink 4 times on 60" WEGA
When your red light blinks four times on the Sony KDS-R60XBR1 60 inch HDTV, this is an error code for a stopped up fan. You will need to check the ASU board to verify Fan1-4 power to the fan is supplied, next check the fan connector to make sure it is properly connected, and finally make sure the fan is not caught in the wires or harness.
Feb 27, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
Sony 50 inch 3lcd when turn on it goes on then turns off. flashes red and blinks 4 times in standby.
4 blinks is fan error. Just clean the fans near lamp compartment by a vacuum cleaner and check the fan connectors if they are attached securely.
Oct 19, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
The power LED is blinking red 4 times on my sony 60XBR2 TV. I've read that this indicates that the right fan in the rear is clogged with dust and can easily be fixed by clearing the area around the fan...
4 times blink is a fan error. I suggest to use a vacuum is better than using a Long screw driver when cleaning those fans. Screw driver can damage the fan..
Oct 18, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Tv won't turn on 4 blinking led
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly.
Thanks.
Jul 18, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
KDS R60XBR1 Red Light blinks 3 times when turning
on my xbr tv there is a little *** that sticks out on the lamp cover. the wrapped and it wont work light flashed 3 time with a new cover it worked fine. there was a t. s. b. for an over heat problem new fan and sensor and door. go to sony.com its there
Mar 22, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Replacing the exhaust fan on a KDS-R60XBR1
4 times blink shows problem of fans not running or connector of fan is not attached properly.
Please recheck the things what you removed during fan replacement and make sure all that is mounted and connected securely.
Feb 13, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
KDS-R60XBR1 60" SXRD HDTV
I had the same problem if it is blinking 4 times like I think it is... it is a problem with one of the fans (there are 4) in your TV.. It is a simple fix... try using an air canister to clean them. It will require some disassembly though.
Sep 12, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
Sony KDS-R60XBR1 60" Projection HDTV Logo
496 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
