Question about Olympus FE-210 Digital Camera
Won't turn on - requested new batteries so put them in then it said battery empty. Now won't turn on at all! No life - zippo!
    Sergeant:
    Champion:
  • 215 Answers
Use hi power battery (Energiser Ultimate lithium for example). Change position of shooting to Manual and disable the flash. The full power now will be available to unlock the shutter and your camera is back in order.
If still not working keep it at a temperature over 23 Celsius and try the same. It will start Magic and you will be happy you spent 9$ for those batteries that last over 1000 shots
Regards,
Posted on May 11, 2010
Fuel pump cycling long time bike won't fire,has good spark.
Hi, Anonymous and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Security alarm needs a reset.
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
What to do When Your Motorcycle Won Start
1098 won start
Ducati 907 906 Paso Workshop Service Repair Manual 1988 1993 Searchable...
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Mar 14, 2013 | Ducati Motorcycles
I have a problem with a 2008 Dodge Charger, my battery went bad and I had to jump it off to take it and get a new battery put in but now my new battery won't start my car not even when the new battery...
When you jump started the vehicle, it started as normal and you drove to a shop to have a new battery installed.?? Correct??
1. Who removed the old battery and installed the new one?
2. Did the car start normally immediately after the new battery was fitted? How frequently were you able to drive the car on the new battery before the problem you described appeared?
3. Has anything been done to the vehicle since the new battery was fitted.?
Dec 21, 2012 | Cars & Trucks
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
Aug 20, 2012 | Motorola Mobility Motorla MOTXT912 DROID...
Van won't start brand new battery,but acts like a
CHECK THE MAIN FUSES, ON THE FRONT,, AND THE BATTERY CABLE.... YOU CAN REQUEST A SERVICE REPAIR MANUAL FOR FREE AT BESTDIRECTORYSOLUTIONS.COM
Mar 01, 2012 | 1999 Pontiac Montana
Battery life only half
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Feb 24, 2012 | Motorola Cell Phones
ACER ASPIRE ONE D255E POWER CORD WON'T CHARGE BATTERY PLUGGED IN THE POWER CORD WON'T CHARGE THE BATTERY ALL THE TIME ...
Hi: Acer chargers have a very short life time, in the past 2 years I had bought 2. Just buy a new one from amazon they're very inexpensive. Here's the link: http://www.amazon.com/Laptop-Adapter-Aspire-AOA110-AOA150/dp/B0028LK6IU/ref=pd_bxgy_e_text_b
Regards,
Sep 25, 2011 | Acer Computers & Internet
I have a toshiba laptop satellite L-300 that won't turn on. I tried unplugging AC and remove the battery and hold the power button for 30 sec. and plugged the AC back, i can see the green light at the...
THE BATTERY LIFE TIMED OUT.TRY IT ON NEW BATTERY FOR TURNING ON THE SYSTEM.THE CHARGING ADAPTER MAY BR ALSO A PROBLEM TRY TO CHECK IT AC VOLTAGE LEVELS .
Sep 03, 2011 | Computers & Internet
99 windstar van, won't turn over,won't start, headlights won't turn off,
baterr ywas dead changed it-new battery worked-discharged once air turned on-put in 2nd bateer yseems fimne as long as you don't turn on the air-if you do there is a clicking inside radioconsole and discharges battery
Jun 17, 2011 | 1999 Ford Windstar
New battery is considered Empty
Some cameras, even the expensive Nikon professional cameras have the same problem. Sometimes turning it on and off fixes it, sometimes removing and reinserting the battery works. Sometimes, going into the menu and finding "reset" works.
Feb 11, 2010 | Olympus SP-310 Digital Camera
1995 buick regal
hi is it automatic and won,t start that mean won,t turn over or turns over but won,t start ? how occasional yates210456
Sep 16, 2008 | 1999 Buick Regal
Olympus FE-210 Digital Camera Logo
161 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
