Question about Mag Innovision InnoVision LT 765S 17" Flat Panel LCD Monitor
I dont know about capacitors or regulators i just need to know how to turn this thing on.
I have a MAG innovision 762s monitor. i didnt get my answer from the other two resolutions to the "no power cord" problem. is the power source coming from what looks like a cable jack? i need power!
    Genius:
  • 1,554 Answers
On the specs from ebay I see you need a 12v dc 5 amp ac power adapter .
normally they have an led , but if you can't get power you will have to verify that you have the 12v at the tip, you will need a multimeter or 12v bulb connected to the end.
if your getting power then the panels circuit is at fault.
talk to a local geek about checking it out.
Posted on May 12, 2008
When I turn monitor on, it stays on only 2 seconds, then goes dark. When I turn the monitor on, it lights for another two seconds, then goes dark. It is a MAG Innovision TCO 03 display. Thank you!
It could be two things. 1). The video card is set to a resolution the monitor does not support. 2). The monitor's power supply is bad. You can try to boot into rescue (or "safe") mode, and adjust the video card to a resolution the monitor supports. OR, power supplies usually go bad because capacitors bulge or otherwise go bad. Most monitor power supplies are hard to get, so people typically repair them. If you disassemble the monitor shell, you can see the power supply (where the AC cord goes). You can look at the metallic, cylindrical looking things with minus signs down one side, and if they look bulged on top, you can replace them. You can get replacements at mouser.com.
Mar 30, 2013 | Mag Innovision 19" LCD Flat-Panel Monitor...
Where to plug the power cord in the back of MAG TL765s Monitor
There should be another hole next to the speaker connections that says DC in, it goes in that hole.
Oct 29, 2009 | Mag Innovision InnoVision LT765 17" Flat...
I need a power cord for a mag innovision lcd monitor
You can buy a power cord at any Lowes, Home Depot, Radio Shack or Best Buy. The power cord is not unique to the monitor.
Dec 26, 2008 | Mag Innovision lt456s 14" Flat Panel LCD...
Mag Innovision LT982s 19 inch flat screen monitor
Often the plug of the power cord and its mate, the jack in the monitor, would have to conform with the region/country of its intended use. Having said this, then it is possible that your particular version is meant for another country but is likewise sold in your country. A picture of the monitor's connector would help narrowing the selection and possible source/supplier. Pls post if able.
Alternately, you could try viewing the different types here, here or here to get the specific part number or model of the AC cord.
Incidentally, most electronics shops/stores sell a variety of power cords, perhaps a visual check would further assist you.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 02, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
Mag Innovision 765S Screen Flashes on and off.
It sounds like it is trying to re-synchronize it self and not going back the the default setting. Compare the resolution of the game to your monitor capabilities.
Jerome
Dec 29, 2007 | Mag Innovision InnoVision LT 765S 17" Flat...
Mag Innovision LT776s Model 780
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Nov 23, 2007 | Mag Innovision LT776s 17" LCD Monitor
Mag Innovision InnoVision LT 765S 17" Flat Panel LCD Monitor Logo
124 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
