Question about Sewing Machines
My Toyota constantly breaks the top thread. It just looks like the thread slips off somehow from the needle hole. Before it happens it starts making some ''funny'' noise as if it needs some extra power to turn. I regularly oil my machine and keep it free from lint and broken pieces of thread. I really have to finish my skirt please help! Natalia.
  • 92 Answers
Loosen the tention a bit. wcbotha@yahoo.com
Posted on May 12, 2010
Kenmore mini ultra The top thread breaks off from needle after a few stitches. The bobbin seems to Be catching the top thread. Thank you. ??
If the top thread sews a few inches and then breaks, something is catching the top thread and holding it until it breaks. Usually, this will happen when using the old style thread cones with the slit in the edge to keep the thread from raveling off the spool. To prevent the thread from hanging up, turn the thread spool over so the slit is at the top instead of the bottom. Sometimes top thread breaks will happen if the thread becomes looped around the thread spool pin.
Remove the thread, ALWAYS RAISE the presser foot and then rethread the upper thread. Verify that the thread path is correct and that the thread has not looped around a guide.
If the thread is fraying at the needle eye, the needle/thread are not compatible. Also, the tension may be too high.
Check that the upper tension disk is clean--no gunk buildup or thread pieces stuck.
If the thread is actually breaking when it penetrates the needle plate hole, there may be a burr or nick somewhere below that is catching the upper thread. You can wrap your finger with a piece of fine fabric, like an old pair of hosier, fine knit fabric, etc. and running your finger around in the bobbin area, under the needle plate. If you get snags, then you have a burr or nick. If it is small, you can sometimes smooth it with a fine emery board. If it is a large burr, you may need to purchase a replacement part.
Why Does My Top Thread Keep Breaking Sewing Machine
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Sep 05, 2016 | Kenmore Sewing Machines
My bobbin and thread are constantly breaking. I have the correct thread to needle, but I don't even get one stitch before both break. Tension is on auto; should it be less or more?
is the needle in the holder the correct way ( groove in the needle facing the thread )
Is the needle eye the correct size for the thread in use
remove it from auto tension setting and adjust it your self
make sure that the top thread is between the tension plates and not around the thread behind the plates
the thread tension is close to correct when you need a bit of a pull to pull it along to the needle
is the method of threading to the needle correct as any areas where the thread reverses direction will cause it to break
what do mean that the bobbin is constantly breaking or is it the bobbin thread that is breaking
have you got the thread down the case slot and under the flat spring correctly
the bobbin has to be inserted into the case in such a manner that when the thread is pulled , it flows down the slot freely as the bobbin turns
if the direction is wrong , the thread has to move across the sharp edge of the slot and will cut easily
Dec 21, 2015 | Brother Sewing Machines
I have a Toyota RS2000 the thread from the needle keeps slipping out every time I thread
Is it slipping out of the needle or breaking? If it is truly slipping.... grasp the threads and hold them while you start the seam. If it is breaking at the eye of the needle change it out and make sure the new one is the proper size for your thread.
Aug 15, 2012 | Toyota Sewing Machines
I have a Toyota RS2000 sewing machine. The thread has suddenly started breaking, and I am getting big bundles of thread under the fabric. What is wrong please?
try a top thread tension of 4
change to a new needle
clean under the needle plate & in bobbin area for lint or loose threads
also rethread machine top thread & bobbin just incase thread is catching somewhere
make sure the thread doesn't come off the thread take up lever
check to see if there are any burrs on the needle plate or the bobbin
Aug 10, 2011 | Toyota Sewing Machines
My top thread keeps breaking. I have adjusted the tensions on both uppper and lower threads, changed the needle. It seems like the top thread is getting stuck on something in the bobbin case.
sometimes the needle plate gets a burr on it which will break the thread when sewing. Usually 2 screws hold the needle plate on and remove those and pull the needle plate off. Take a close look at the hole that the needle travels into and see if its a little rough on both side. If so you can use a file on it to smooth it back down.
Tool Belt Diva
Jun 11, 2011 | Toyota SE-06 Mechanical Sewing Machine
Hello, I have a Shark euro-pro sewing machine. I am sewing denim on denim using singer needles that were suggested for denim. The numbers on the package are 2020 110/18 808 R 130/705H 05 un I...
The size of needle is fine for sewing on denim so unless the needle is bent (and even so) I doubt that is the problem. Breaking upper thread typically has more to do with the threading, ie wrapped around some place along the way or misthreaded somehow, of even if you somehow got knots or that it has somehow got thread around the spindle for the spool. So first recheck the threading. Best to do by simply totally unthreading it, looking closely at the spool and winding and then rethreading it again. Make sure your upper tension hasn't been accidentally tightened too.
Next check the bobbin and bobbin thread. First pull on the thread. Is it pulling real tightly or does it flow out readily? Take the bobbin out and look at it. Check the tension also. Is it too tight? That too can cause the upper thread to break.
Is the needle penitrating the material smoothly? Again examine the needle closely to see if it's developed a burr. Better yet just swap the needle with a new needle and try it.
The majority of the time it is one of these things that will cause the top thread to break.
May 18, 2011 | Euro-Pro Shark 80 - 7133
MY BROTHER MACHINE NO. LS-2125i THREAD BREAKING WHEN SEWING?
Thread brekage can be caused by several things but start simple by taking off the needle plate then thoroughly clean the sewing mechanism and add a few drops of oil, then check the threading is correct. replace the needle. Always use quality threads and make sure that the thread is not to heavy for the size of the needle (it should pass easily through the needles eye). check that the needle hole in the plate is not bent or damaged and peppered with needle marks, a damaged plate will cause many problems. Finally, make sure that the tensions are not too tight this can be a major cause of thread breakage especially if poor quality thread is used. ( check thread by breaking it by hand, it should offer good resistance to breakage, if it breaks easily then discard it. hope this is useful, best of luck.
Apr 14, 2010 | Sewing Machines
Thread breaking on Simplicity Denim Star
Hi, when your thread breaks or frays right before in goes through the eye of the needle:
  1. Change your needle - after awhile, the eye can wear down and cause your thread to break or fray, eventhough it looks like the thread isn't even going through the needle. When you change your needle, make sure to install a needle that is compatible with the thread you are using (see below).
  2. If your thread still frays or breaks, make sure you've threaded your machine correctly. Most machines have a hook or bar right above the needle that your thread need to pass thru before you put the thread thru the eye of your needle. Sometimes that spot above the needle is really hard to get to, and sometimes the thread slips out. Always a good idea to double check. If you are still having problems, the needle you are using is probably the wrong size.
There are lots of needles on the market, and lots of threads. You need to make sure your needle is compatible with the thread you use for each project.
The most common needles are size 80 and 90 universal needles, which are fine for most sewing projects. But if you are using a specialty thread, you need to use a needle that is designed to work with that particular thread. For example, top stitching needles have a larger eye than a universal needle, because top stitching thread is thicker than sewing thread. The same is true for metallic thread - needles made for metallic thread an eye designed to allow the thread to pass thru without fraying. Further, if you using fine thread, you need a small needle.
FYI - unfortunately, thread sizes do not correspond directly with needle sizes. Small needle numbers indicate a needle with a small eye. But the smaller the thread size, the larger the thread. For example, size 50 thread is very fine and would usually be used with a size 70 needle. Size 30 thread is fairly thick and would probably be used with a size 90 top stitch needle.
Hope this helps, and remember, you should always change your needle after about 10 hours of sewing, no matter what size needle you are using. If you have more questions, please post again. Thanks, Ginny
Dec 16, 2008 | Simplicity American Denim SA1100...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
