Question about Tech Solution TS-4500 Shredder
I have a tech solutions shredder. Envelope got stuck. I cleared it out. Now it will go backwards but not forwards...although the green light does come on when I press the forward button.
  • 1,219 Answers
The stucked envelope may move the sensor or damadge it. You should check the sensor.
Posted on May 11, 2010
2 Suggested Answers
JackHeath
  • 1049 Answers
SOURCE: I have a tech solutions shredder. Envelope got
There is probably paper, dust, or something still in the shredder somewhere obstructing the sensor. Run it backwards for a minute or so, then turn it over and blow it out, and after unplug the shredder and plug it back in. Then see if it runs forward.
Posted on Mar 17, 2010
Suddenly stopped. Power source is good.p Had been working ed. Does not go forward nor backward. Power source is goog.
It could be there is still some material in the cutting wheels. We have had this happen to our shredder a few times, do your best to get stuck materials free.
Good Luck
May 07, 2014 | Fellowes Powershred Personal W11C Shredder...
I have a paper jam with only two inches hanging out, and it won't nudge backward or forward. Any solutions? Thank you.
If it wont go back or forward then your only recourse is to open it up and "manually" attempt to turn the motor and/or gears untill you can clear the paper. Dont put so much in at a time; and make sure you regulaly oil the machine.
Dec 29, 2010 | Royal 1280MX Shredder
I have a tech solutions shredder. Envelope got stuck. I cleared it out. Now it will go backwards, but not forwards...although the green light does come on when I press the forward button.
Mar 17, 2010 | Tech Solution TS-4500 Shredder
There is paper stuck in the shredder how do I get it out. I have tried the reverse and forward several times.
IF YOU GET A PIECE OF THICK PAPER OR AN ENVELOPE AND FEDD THAT THROUGH IT SHOULD CLEAR IT FOR YOU YOU COULD OPEN THE DOOR AND FEED THE PAPER UP FROM THE BOTTOM BY CHEATING THE DOOOR SWITCH BY PUTTING A PIECE OF PAPER IN THE SLOT FOR THE ACTUATOR THAT WILL LET THE MOTOR RUN FOR YOU...hOPE THIS HELPS a
Jul 30, 2009 | Royal VF1012mx Shredder
GREEN POWER LIGHT ON RED LIGHT BLINKING MACHINE WILL NOT GO IN FORWARD OR BACKWARD
Common reasons for this is dirty or blocked sensors on top and under the cutter asm.Also, the waste basket door sensor or switch is activated.
Jun 03, 2009 | Achiever CCS-1500 Cross-Cut Shredder
Tech Solutions shredder Only powers in reverse w/ green light
Their are sensors on top and bottom of cutter asm. Good chance one or more are dirty, blocked with paper shreds or just bad. Clean with compressed air and lightly moistened cotton swab.
Jun 01, 2009 | Tech Solution TS-8000 Cross-Cut Shredder
These are made by Winsource Industries http://www.winsource-hk.com/ The contact information is Hong Kong. I haven't had any luck getting a replacement for one with a Limited Lifetime Warrany.
Good Luck -
Jan 25, 2009 | Tech Solution TS-8000 Cross-Cut Shredder
Unjamed, but jammed light remains on and won't shred
Most likely the PC board has gone bad. It will cost over 100.00 from fellowes.
Sep 06, 2008 | Fellowes Powershred 480 Shredder
Tech Solution TS-4500 Shredder Logo
184 people viewed this question
Top Tech Solution Office Equipment & Supplies Experts
Jim Keysor
Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
