Question about Panasonic Workio DP-3030 Printer
Thre is a little wrench on the left side of the screen. What do I do?
    Champion:
  • 224 Answers
The wrench or spanner indicates that a service is due. if you are able to use the device continue but call a technician in. if there is an error along with it and you are unable to use the device recycle the power( turn off and on at wall). if the problem returns call in a technician
Posted on May 11, 2010
Im trying to tighten up the screws in my kwikset lever knob in my bathroom but I keep pushing in that little hole on the side and it still wont come off. Is it broken?
There is a setscrew in the hole. Insert a 3/32" hex wrench (Allen wrench) and turn to the left to loosen. The handle will pull off easily.
Jul 01, 2014 | Locks & Locksmithing
Can't loosen arbor nut
Use a block of wood to hold the blade from turning and pull the wrench toward you. Most saws will have the nut on the right side of the blade and will use a right-hand thread. But if the nut is on the left side of the blade, it will be a left-handed thread. In either case, PULL. The crescent wrench should work fine if you place the block of wood in a position where the blade naturally jambs into it and cannot turn. If the washer is correctly placed you do not need to tighten the nut all that much. If it is really stubborn, use a little WD40. Clean it off thoroughly after you get it apart.
Oct 06, 2012 | Bosch 4000 - 07 Electric Table Saws
I am working in Minolta copier machine EP-2080, and have a error code C-0920, WHAT THIS MEANS AND HOW CAN i FIX IT
On the control panel in the lower left do you see a small wrench? if so touch it the screen will change and then open close front door to clear. As for the code its for a paper draw place paper in each draw separately list if the motor raise the paper. The Service manual I have is for the EP2050 ball park but it is a paper draw and the little wrench should be seen in the lower left of the control panel
Aug 09, 2011 | Minolta Office Equipment & Supplies
Minolta cspro ep 3010 code c0924
On the control panel is there a little icon like wrench in the left hand corner of the screen, if so touch it then new screen will appear, once new screen appears open close the front door to reset the code
Mar 16, 2011 | Minolta DiALTA Di520 Laser Printer
Do not know how to remove blade
Take knife cover off.unplug.get a tapered punch about 12" long rotate the blade where as the nut in the middle of the blade has a flat side horizontal.right is tight left is loose.counterclockwise to loosen.Put the punch on the left side of thre flat and hit the punch with a hammer sounds odd but it works well yes it will bang up the side of the nut but it will not hurt anything.If done right it will loosen nut easily.I work on slicers all the time this is the only method I use.It may take a couple of good wacks but it will come loose as you already noticed a socket or wrench will not stay on the nut .good luck.
Mar 15, 2011 | Hobart Slicer Manual 12"
I dont know how to set the time and date
This is for a Nikon Cool Pix Model - Turn your camera on - press the menu button - down arrow to the little wrench picture (select left arrow to get to icons on left of screen) then click down to wrench .. date should be one of your choices click down to date - clik okay or right arrow .. date should appear right arrow and camera will walk you through setting date.
Mar 15, 2011 | Cameras
MY PHOTOCOP IS EP 4050 - I HAVE MESSAGE: selected paper tray has failed coll the customer service
On your screen in the lower left. Do you see a small little wrench?
If so touch it the screen will change, once the screen changes open and close the front door. then check all you draws for paper behind them or extra paper being stored on the left hand side of the tray NOT A STORAGE AREA, store paper some where else. If it comes back the code Number would be helpful to determine the problem draw.
Oct 20, 2010 | Minolta EP4000/5000 CS/PRO Copier
How do i remove the drive pulleys?
you need special tool to hold the water pump puley and long 32mm wrench to brake loose fan clutch.
the thred is left hand , so you brake it loose clockwise.
you can also use just a wrench and hummer.
put 32mm wrench over fan clutch nut and by hitting the end of wrench with a little luck it is possible too
when you put it back you can use same procedure.
you may have enough room to change thermostat , by sliding fan assy. to the side without taking it out.
Apr 16, 2010 | 2003 BMW 325
if there is an error message along with it eg. E3-10 or E2-02, recycle power, that may reset device. if not it means a service error has occured and need a technician.
Mar 17, 2010 | Panasonic Workio DP-3030 Printer
Water dispenser on GE side by side profile refrigerator doesn't work
check to see it the resevevouir tank is frozen up inside of the refrigerator, alspo check the the holse ruunning thru thre left door may be kinked. or the wter solenoid may have stopped working . Hope that one of these works out for you. Thanks for using FixYa and have a Merry Christmas!!
Dec 24, 2008 | GE GSS20IEP Side by Side Refrigerator
Panasonic Workio DP-3030 Printer Logo
44 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
