Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Light will not function. Replaced light bulb but
Light will not function. Replaced light bulb but no light. Door opens so I know electric supply is good.
    President:
  • 3,197 Answers
Unplug the opener and remove the light bulb. Using a small screwdriver pull out on the center connection in the light socket.
Posted on May 11, 2010
I have a 2 year old Kenmore HE3 electric Dryer. Model 110.8708. The drum light never worked. I opened up the door and found a broken bulb. I replaced the bulb. the light stays on all the time,...
the door switch has something wrong with it,it's keeping the bulb on all the time and that's why it burnt out the first time,also you're missing the last four numbers on the model number
May 15, 2011 | Dryers
My light blew out I changed the bulb but it is still not working
I suppose you should have checked that bad bulb and the new bulb in a working table lamp. If they work there then the door switch for the light may be defective or a connection has opened in the supply voltage. 90 percent of electrical problems are not shorts -but opens.. OPPS! something is missing. The voltage is not getting there
Jan 28, 2011 | Refrigerators
Unplug the unit and then using a small screwdriver pull out on the center contact in the light socket.
Mar 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
Security light will not work
You must have a three function wall switch. This means in addition to a button that opens and closes the door there are two other buttons on the same wall switch. One is marked LIGHT and the other is marked LOCK.
To have your lights come on automatically when you walk into an open garage you must START with the lights ON. To turn the feature on, turn the lights on manually with the wall switch, then press and hold the LIGHT button for about 10 seconds until the motor unit light bulbs flash. Now, if the light bulbs are on, manually turn them out and then walk out through the open door. The light bulbs should come on.
To disable this feature, start with the light bulbs OFF and everything else is the same.
Aug 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Main light on will not come on when door is opened/closed
For some reason, the bulbs I tested that worked somehow didn't work correctly when inserted into the door opener. We opened another set of bulbs we purchased and what do you know, the light now works. I don't fully understand as the other bulbs did work just not in the garage door opener.
Apr 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
1/2hp Craftsman Garage door opener light bulb
If you are getting a click the relay on the board sounds like it is working. Sometimes the contacts in the light socket gets burn spots on them. Try unplugging the unit, unscrewing the bulb and with a small scrapping tool (small flat screwdriver) scrap the bottom contact and the contact on the threads. Bend the contact on the threads a little too make better contact with the bulb. Screw the bulb the bulb in completely. If this does not solve your problem the only the left to do is to replace the logic board.
Jan 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain door opener--Door opens but light will not come on
We had he same issue and changed our bulb from a CFC back to a traditional bulb and the problem was solved!
Sep 22, 2008 | Chamberlain Powerdrive PD422D 1/2 HP...
Oven lights
i don't know your brand but ive read service bulletins on bad light sockets in ranges id try another bulb first then replace the socket
Feb 13, 2008 | KitchenAid KEBC107 Electric Single Oven
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
240 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
