Question about Thermador SGS36GS Gas Cooktop
Hello I have a kenmore elite gas cooktop with only one burner lighting normally. The rest we have to use a match. Can I change a part to fix this?
  • Thermador Master
  • 43,501 Answers
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Posted on Aug 30, 2010
2 Suggested Answers
seanpwright
  • 2030 Answers
SOURCE: Hello I have a kenmore elite gas cooktop with only
Yes the ignitor can be changed out. If you give me the model # of your unit I can get you the part number you need to replace.
Posted on Mar 17, 2010
Will not light
Have you removed the burners covers and top to see if the PILOT LIGHTS may have blown out? Hold a stick match or fireplace match (long stick) down in the area of the circular burner after turning on some gas. The burner should light and the pilot light should stay on as well. You local gas company provides service for this type of problem. Call them and have a gas company representative make a home call (free service) in most areas.
Oct 08, 2010 | Kenmore 36 in. 33212 / 33214 / 33219 Gas...
No matter which burner I try to turn on, the same one tries to light - I thought the gas was turned off, but the fact that just the one burner tries to turn on makes me nervous. thanks
Hello- On modern gas cooktops and ranges when you turn on one burner ALL the burners will click, spark, until that burner is lit. I would ask if the other burners are lighting ok or do you have to use a match? Do you smell gas when all the burners are OFF? Feel free to reply and if you could provide the Model number of the unit that would be helpful. Best regards.
Sep 27, 2010 | GE Cooktops
My GE gas cooktop keeps making a clicking noise and one of the four burners doesn't ignite unless I light it with a match. What should I do?
the burners use a sw on the gas shaft of each burner to make the igniton work. i belive one of the sw are shorted or housing broken . replace it . / tip when I replace one i do them all .. saves time later . falure caused by spills ect and normal ware .. mm
Jul 16, 2010 | GE Profile JGP636 Gas Cooktop
Gas stove burner will not turn on
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 29, 2010 | Gaggenau 23 in. KG 260 Gas Cooktop
Mar 17, 2010 | Thermador SGS36GS Gas Cooktop
We have a thermador 5 burner gas range top and the pilot light seems to have gone out. The burners don't go on but we smell gas. How do we re-light it?
Most gas range tops no longer have pilot lights but use an electronic ignition (sparker) to light the burner. Normally when you turn the burner on you should here a snapping or sparking sound, at which point the burner should ignite. Here is a link to the user manual for 36" - 5 burner Thermador rangetop...maybe this will help: http://dl.owneriq.net/a/ac64ae7b-1ed3-44a3-9235-e4dbd8fe4628.pdf
By the way, in the short term you could always use a match to light the burner. JUST BE VERY CAREFUL THE YOU HAVE THE MATCH LIT AND OVER THE DESIRED BURNER BEFORE YOU TURN KNOB TO START THE BURNER!!!!
Jan 15, 2010 | Thermador 37 in. SGSX365 Gas Cooktop
New cooktop-1 burner does not light automatic
find the spark module. Follow the spark wires to the module . unplug the one that doesn't work and plug in a working wire. If it sparks it the wire if it doesn't spark change module
May 16, 2009 | Kenmore 30 in. 32384 / 32385 / 32389 Gas...
Kenmore Elite 30" gas cooktop installed. Large right front burner
There are a series of holes in the burner leading down from the main flame area to the pilot tube, ensure the holes are not plugged/restricted.
Feb 11, 2009 | Kenmore 30 in. 42701 / 42702 / 42709...
Cooktop burner problem
Your plumber should know that the pipe service your cooker must be of a suitable size. Normal half inch pipe is only good for a couple of small burners. Most installations require one inch! There is a simple formulae for working out the flow rate of the gas. Your gas installer will know it.
Apr 18, 2017 | Cooktops
Thermador SGS36GS Gas Cooktop Logo
169 people viewed this question
Top Thermador Cooktops Experts
Dan Webster
Dan Webster
jasbo
jasbo
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
