Question about D-Link DI-634M Wireless Router (DI634M)
Wireless internet we had the d-link di634m installed to home computer. I was able to access the internet with my notebook wireless connection for a few days then we tried to enter the security codes on-line. Since then we have not been able to access the internet with my portable computer. The page cannot be found. What do I do now?
  • 236 Answers
Hi 4ladyj,
plug your laptop into the router with an ethernet cord, and see if you can connect that way. If you can, go into modem settings via IP (or through the software) and change your wireless settings to default..
If that doesn't work, there is a reset button on the back of the unit, press it in with a paper clip and hold it in for 10 seconds, this will reset the router to the factory default settings.
You will have to change all your settings for your connection again.
Posted on Mar 28, 2008
6ya staff
SOURCE:
WIFI CONNECTION
You may check the firmware on the router by logging into router's web interface (usually it is 192.168.1.1). Check the existing firmware version. Also, verify from dlink website, if any new firmware version exists for your router model. If yes, upgrade the firmware of your router from a hardwired computer. After this step, powercycle the modem, router and your wireless laptop. Check if you are able to connect wirelessly.
Nov 30, 2013 | D-Link DI-634M Wireless Router (DI634M)
Conection wireless dlink di-634m with notebook windows vista no work !! help !
Make sure you have the ipx and spx protocol install on the wireless adapter.
Nov 14, 2009 | D-Link DI-634M Wireless Router (DI634M)
Cannot get new computer to connect wireless
do you have a wep ?Are you able to see what networks are available?Is the D-link one of them?Do you have other computers connected to the network
Oct 04, 2009 | D-Link DI-634M Wireless Router (DI634M)
Can I use a D-Link DI 634M as an access point?
Sure you can! As you can with any wireless router pretty much.
1. Assign the new router (AP) to an IP on your subnet that's not your existing router's IP... i.e. 192.168.0.2
2. Disable the DHCP server on the "AP"
3. Create a new wireless network on the "AP"
4. Plug your existing network/router into a LAN port
DO NOT USE THE WAN PORT
Voila! You have an access point!
Jun 21, 2009 | D-Link DI-634M Wireless Router (DI634M)
Trying to set up wireless laptop. Instructions tell me to input
The wireless connection device on a computer is used to connect to a wireless router that is connected to the Internet via an Internet Service Provider (ISP) and or to your home or the network where you work. You can also use it connect to a wireless hot spot (like an Internet cafe) for Internet access.
Your computer will need a wireless device either a built-in wireless card, or a PCMCIA wireless card that plugs into your computer's PCMCIA slot or a USB wireless device.
If you want to connect into the Internet wirelessly in your home, you need a wireles router that is connected to a cable modem or a DSL modem and to a ISP.
The wireless router needs to be configured (change the default settings) the SSID and encryption (WEP or WAP, WAP is a stronger encryption method) etc.
The wireless card needs to be configured with the same settings as the wireless router so it can communicate with the wireless router.
For configuration information refer to the wireless router and wireless card/device manuals.
Whilst the settings of these devices are similar between the various manufacturers, the methods they use to configure varies and you need to be precise in giving make and model of the devices, your Windows system and computer to assist us to give you detailed advice.
Feb 01, 2009 | Dell Inspiron 1501 Notebook
Wireless dlink
You may need to access the router's setup page and configure it's Internet connection type to SBC's required settings. Usually it's PPPoE.
Nov 08, 2008 | D-Link DI-634M Wireless Router (DI634M)
Router shutting down
you can try to reset the router and reconfigure it again but if it's still giving you the same problem, check if the router is using the latest firmware, if not, then upgrade the firmware
hope this'll help you.
ciao!
Jun 18, 2008 | D-Link DI-634M Wireless Router (DI634M)
Internet connection
hello!
1. what is the model number of your wireless adapter?
2. what is the operating system of your computer?
3. how far is the laptop from the router?
-- try to change channel on the router
-- try enabling wireless security on the router and on the wireless adapter
-- diable other 3rd party firewall on your laptop
Apr 14, 2008 | D-Link DI-634M Wireless Router (DI634M)
My wireless router wont work
Run a cat5 cable from the laptop to a cat5 port on the router, open internet explorer in the address window type http://192.168.1.1 or what ever the IP address of the router once you have accessed the router create your PPPOE internet connection, enter your Internet Service Provider's username and password. Once you have done this, disconnect the cat5 cable and connect wirelessly to the router from the laptop. If all this fails press and hold the reset button on the back of the router for 10-15 seconds this will reset the router to factory defaults. connect to the wireless router and create the PPPOE connection. BPCS
Dec 29, 2007 | D-Link DI-634M Wireless Router (DI634M)
D-link router connection problems
I'm guessing you're saying you've left the security open on the pc's, but what about the router? You can connect to most wireless routers with a TCP/IP cable. Try that and see if you can check your wireless router's settings. It may have some security settings enabled.
Nov 18, 2007 | D-Link DI-634M Wireless Router (DI634M)
D-Link DI-634M Wireless Router (DI634M) Logo
57 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
