Question about HP LaserJet 1100 Printer
Hp laserjet 1100
My HP look good. Start -> load-> pulse diode (big, small, small. etc. some sound) at last stop: Big-dark, small green-bright, small orange-dark. When I try print somethink small green-pulse, when should start printing device switch off. I must turn off main switch device, wait a moment, and I can try one more time. HP don't printing anythink (test site)
When the paper gets low in the storage tray the printer starts pulling several sheets at one time.
Posted on Nov 07, 2008
SOURCE:
Hp cm 1312 stopping after five copies. Is my memory too small?
Check what is the size of the documents you print, if the memory is not decent and documents big, it may clog the memory temporarily. Regards, Mike.
Jan 18, 2016 | HP LaserJet CM1312 All-In-One Printer
Error lights
  • Big Green light on = Beam error
  • 1 Check the laser/Scanner cable if OK and still having the same problem
  • 2 Recommend replace the laser/scanner assembly
  • P/N = RM1-0524-000CN
BBe
B
May 07, 2013 | HP LaserJet 1300 Printer
HP laser jet 1100 will not print
Error indicating that:1.Paper jam.2.Cartridge missing or not seated properly.3.Cartridge access properly closed?action: Refix cartridge properly, check any paper jams in side. No result.. ***remove Formatter & power supply & clean as shown in snap shots.. 11_29_2011_4_30_29_pm.jpg11_29_2011_4_31_09_pm.jpg11_29_2011_4_31_33_pm.jpg11_29_2011_4_31_56_pm.jpgCarefully observe the snap shots..and do the trouble shoot.Best of luck.
Nov 28, 2011 | HP LaserJet 1100 Printer
Printer stops after the first paper
while all 3 lights lit up hold go button and different light pattern if big and middle light are on fuser if just big light scanner if anything else post light pattern
Jul 27, 2010 | HP LaserJet 1100 Printer
When installinghp laserjet 1100 printer, it was not listed,. what is a compatible pinter sofware?
If your running windows VISTA or Windows & no it is not compatable with your computer
Its a big headache I know for I have the same prplem
I hope very soon an upgrade will be offered
Jun 30, 2010 | HP LaserJet 1100 Printer
Hp1100 printer keeps dragging in more than 1 sheet at a time
This is a big issue with these printers, as the pads get worn out it starts feeding multiple pages. HP used to offer free kits to repair this issue but they are no longer offering them but a lot of people are selling these kits now. The link below is one place you can get the kit or you can look on EBay for HP 1100 repair kit, they are usually a little cheaper.
http://www.fixyourownprinter.com/kits/hp/K35
Jan 05, 2010 | HP LaserJet 1100 Printer
The orange light keeps blinking and won't go back
This could be signaling that the toner is empty. Replace the toner and see if the light goes back to green. Hope this helps.
Oct 16, 2009 | HP LaserJet 1100 Printer
I Have a HP LaserJet 3030 Printer works Copier works Fax and scanner do not work
Have you loaded the drivers and set up your fax ie name number etc tone pulse. fi you have done this. then you will need to delete driver and reload.
Oct 10, 2009 | HP LaserJet 3030 All-In-One Printer
Hp business inkjet 1100
Hold the power button for 5~10 secs. Once the green light start flashing, remove your finger to the power button.
Jul 23, 2009 | HP LaserJet 1100 Printer
Compaq power supply HP212 (old)
If connector have two big brown wires (pins 1 and 11) and a small brown wire (pin 2). then short circuit the small brown wire with a big brown wire (pins 1 and 2).
Also short circuit the small black wire (pin 16) with a big black wire (pin 17).
Ps. The Power Supply needs a minimal load ex: 1A.
Dec 04, 2007 | Dell HP-150SS (HP150SS) 150-Watt Power...
HP LaserJet 1100 Printer Logo
Clive
Clive
Ekse
Thomas F. Schneider
