Question about Water Heaters
I have a 40 gal Whirlpool single element 3500 mobile home hot water heater. I have replaced the element thermostat high pressure valve (because it was leaking) & flushed for sediment. In morning I wash my hair but when my teenager goes to wash hers down the hall in her bathroom the water is already cold. We're not talking 25 minute showers...just 5 minute throw your head over the side of the tub hair washing. What else could it be?
    Scholar:
  • 102 Answers
A 40 gal. electric water heater will give you aprox. 32 gal. of hot water in one setting, since they do not reheat as quickly as gas. So if you are using a newer 1.5 or 2.0 gpm shower head. You could take a 16 minute shower with straight hot water. If you are running 2 new shower heads at once you could get 8 minutes. If you using the tub spout the times decrease. Some of my customers like to turn up the temerature on the thermostat a little so they can mix more cold and get it to last a little longer. Be very careful doing this.
If your water heater has a lot of calcium built up in it the times will decrease.
With out seeing the heater, you mention it is a mobile home heater so I am guessing that it is bottom fed.
I hope this has helped.
Posted on May 11, 2010
No hot water
It is probably the thermostat. I would suggest replacing that next.
Feb 24, 2014 | Reliance & 40 Gal Electric Mobile Home...
Reliant 40 gallon tall electric water heater replaced both thermostats upper and lower elements flushed tank hot water very hot temp turned down lowest possible keeps tripping reset button what else could...
Problem has to be bad element or bad thermostat.
Test elements for short to ground through metal tank wall:
http://waterheatertimer.org/How-to-test-water-heater-element.html
Make sure factory-installed insulation and cover are re-installed over new thermostats so they do not misread tank temperature.
If problem does not show with elements, then replace thermostats again.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 06, 2012 | Reliance & 40 Gal Electric Mobile Home...
Rheem 49 gal model 81V400B - hot water lasting only 5-10 minutes then takes an hour to heat back up.
Ordinary tank-type electric water heaters are fully repairable by homeowner.
A) Basic info on Rheem
Rheem electric water heater website:
http://www.rheem.com/products/tank_water_heaters/electric_water_heaters/
Find age of Rheem: look 2nd and 3rd digit of serial number, for example 06 is 2006
B) Water heater has some hot water.
That says certain things: upper element is working, water heater electricity is working, reset button is not tripped, and heater is not experiencing run-away overheating event.
http://waterheatertimer.org/How-it-works.html
C) That leaves 4 suspects that cause lower amount of hot water.
1) TP valve is running hot water out of tank -or- leaking faucet is running hot water out of tank.
Check for leaks
http://waterheatertimer.org/How-to-replace-TP-valve.html
2) Lower element is burned out.
Test lower element using inexpensive multi-meter from Home Depot.
Replace element with same wattage shown on label, and clean out sediment:
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
2) Upper or lower thermostat is bad.
Replace both thermostats for about $25.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
3) Burned or shorted wire located between upper and lower sections of tank.
Turn off power. Open covers on side of tank. Remove insulation. Inspect parts for signs of high heat and burning. Especially check lower element. Tighten any loose wires. Replace part that shows signs of burning.
Put insulation and cover back over thermostats so cooler outside temperature doesn't cause thermostat to misread tank temperature.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 03, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
No hot water
You may have 2 elements. Make sure both circuit breakers are on.If the heater is old it may be plugged up with sediment. Flush out via valve on bottom. If no water comes out or it is very rusty keep running till clear. If it does not help probably time for a new heater.
Jun 07, 2010 | Reliance & 40 Gal Mobile Home Water Heater...
I have a 40 gal Whirlpool single element 3500 mobile home hot water heater. I have replaced the element, thermostat, high pressure valve (because it was leaking) & flushed for sediment. In morning I...
One thing you will want to check is see if the cold water pipe on this heater is installed on the side or the top of the water heater. A Whirlpool Mobile Home Electric water heater should have the cold water pipe on the side near the bottom of the heater.
If it is not installed on the side of the water heater this can cause you to run out fast.
If the water pipes are installed correctly try contacting the manufacturer at 1-877-817-6750 and they can advise you.
Mar 17, 2010 | Water Heaters
Water Heaters Logo
116 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
