Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door works but light does not - Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
    President:
  • 3,197 Answers
Unplug the opener and remove the bulb. Using a small screwdriver pull out on the center contact in the light socket.
Posted on May 11, 2010
The dome light will not come on when driver door opened. Door jamb switch is fine.
Have you tried a little squirt of wd40 or graphite in the door jam switch and then hand manipulate it a few times?
Feb 14, 2015 | Cars & Trucks
F 150 DOOR AJAR WILL NOT GO OFF AND INTERIOR LIGHT STAYS ON! HOW DO I FIX IT
If only the door ajar light and interior light is not working it is probably the door ajar switch located on the door latch inside the door. sometimes a little WD40 sprayed towards lower side of the latch will work, frees the piston in the switch. if not the switch must be replaced. If also the outside mirror control does not work, the door lock switch also does not work, it is a bad ground to those three systems, the Electric windows have a separate ground wire and still work. You must feed a new black wire from a good ground on the body thru the door accordion tube and connect it to the larger black wire on the plug that goes to the door lock switch. The door lock, the mirror control, the door ajar light, and the interior light problem will be gone.
Jan 20, 2011 | Ford F-150 Cars & Trucks
My passenger door sensor is not working right. It shows that the door is open when it is not. I did not think it was a big deal until the other night we were driving and the interior lights started to...
I'm not sure which passanger door you're taking about, but i'll assume it's the front passanger door. What I think is happening is that the passanger door's not pushing the Door Switch all the way down when it's close cause the light to stay on.
First check to see if the door switch(to see the switch, open passanger door and it located lower left coner. see picture below) is work by push on. The interior light should go out when push down and on when release.
k42282_35.jpg -If switch is not working, replace door switch.
-if switch is working, adjust passanger door inward by loosing the door striker(A) bolts(B) and tipping it with a hammer. Adjust until door open/close proplery and light stay off when door is close.
Jan 19, 2011 | 2004 Honda Odyssey
When i open the door the light does not come on
Most likely the button on the door jam for the closed door maybe bad. Make sure the selection switch by the light is on DOOR. Then if the button is working, the open door symbol on your dash display should light up with the door open.
If it doesn't light up on the dash display with the door open, then the button on the door jam is bad.
Oct 11, 2009 | 2003 Toyota Corolla
Drivers door power window control stopped working.power mirrors won,t work interior lights want come on when you open drivers door but the other three doors interior lights come and the power window...
Since it is only happening on the drivers side door to multiple switches and lights on that door only, I think the problem is the wiring harness as it enters the drivers door by the door hinges.
May 04, 2009 | 2000 Ford Taurus
No check on opening door
you may have a defective door jamb switch
Apr 18, 2009 | Toyota Corolla Cars & Trucks
2001 Mazda Tribute, V6, 4wd..........Door ajar light on, but door
The door switch is stuck on or the wire is shorted to ground.
Jan 19, 2018 | 2001 Mazda Tribute
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
73 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
