Question about Dryers
The tumbler is not turning; need to know how to open it up
  • Dryers Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please rate me,
Thank You
Posted on May 13, 2010
Three Tips on Choosing Pin Tumbler Locks
Recently, break-ins happened in Harbin City and the burglars broken into houses with the help of tinfoil. This kind of technology is aimed at unlocking the pin tumbler lock which is widely used by residents. It has the high unlocking rate and a pin tumbler lock can be unlocked within about ten seconds.An investigation showed that the two suspects stole cash and anything valuable from high-rise residences by tinfoil and unlocking tools when householders went to work or went out. Their targets mainly were residents whose doors were equipped with cross-shaped or line-shaped security door locks. However, the two suspects said that they could also unlock the crescent-shaped (arc-shaped) locks.It is hard to prevent the pin tumbler lock from being unlocked by the tinfoil. Recently, a reporter visited several stores and markets and found that there were a variety of locks on the market. When the reporter asked about the theftproof performance of the lockers, owners of these stores continued to introduce the locks' features such as the high technology. However, when they were asked whether the locks could prevent security doors from being unlocked by tinfoil, no one could make a commitment. A person who once was a thief told the reporter that although there are various locks on the market, the most commonly used locks can be generally divided into pin tumbler locks, blade locks and electronic locks.Because of the low prices, pin tumbler locks are widely used for security doors. For now, the pin tumbler lock's usage is around 70%. Due to its design structure characteristics that the tumbler end is exposed and the working stroke is short, the tumbler can be touched directly by foreign bodies like wire hooks so as to be technically opened. However, the quality of pin tumbler locks on the market also vary from each other. If people do not know the methods of choosing the good pin tumbler locks, it is likely that their doors with the inferior pin tumbler locks will eaily be broken into.Here are three tips for you to select the pin tumbler locks with the superior quality.OpenInsert the key into the half of the lock's keyhole, then gently turn the key and push it in at the same time. If the key can be pushed in the keyhole successfully, then the pin tumbler lock has good security performance.LookWhen buying a pin tumbler lock, people should choose pin tumbler locks that have brand authentication and excellent theftproof performance. Do not buy pin tumbler locks from less known and less creditworthy hardware stores just because of petty gains.AskTo know whether the pin tumbler lock you buy has good security performance or not, you can call a lock company and ask how long it will take to unlock a certain type or brand of pin tumbler lock. If they tell you that it is easy to open it, then do not buy it.
Vending Machine Lock Manufacturer China Vending Machine Locks
Aug 16, 2017 | Locks & Locksmithing
I forgot the combo for my Kryptonite bike lock US PAT 593412/6422051, can you please help? Thank you
Another way is to pull apart the ends till you have tension on the tumblers. As you place tension try to turn the tumblers. As you feel each loose or tight tumbler is how you can find your combination. I open this type of combination lock like this all the time. First look for the tightest tumbler, turn it until it feels looser and next look or feel for the next tight tumbler. All the tumblers do not block the release at once. You are looking for the first tumbler to adjust, the tightest one, then the next, continuing until you find you have released all the tumblers. This has worked for me with any brand of inline tumbler release system out there. Good luck, usually takes me about 10-15 minutes to find the code. This method can be used on regular locks with a changeable combination as well. It will just take a little time to get to know how much tension to use as you go through each tumbler. Similar as to how you pick a regular lock system. Good luck, definitely doable.
Jan 24, 2013 | Kryptonite Cycling
How replace a lock tumbler on a 1995 Mercedes benz c220
If the key does not turn at all in the ignition tumbler then your going to need to drill a hole in the side of the steering lock in order to manually release the steering lock and remove it complete with the ignition tumbler attached. If you get a new steering lock you can examine it to see exactly where to drill the hole and how to manually release it. If the key does turn at least to position 1 then all you need is the removal pins that slide into the small holes around the face of the tumbler. If there are no holes then once the key is in position 1 all you have to do is turn the tumbler housing to the left until is unscrews. Let me know if you need any further assistance on the removal if the key is stuck.
Sep 26, 2012 | 1995 Mercedes-Benz C-Class
2003 cavalier key won't turn.
very common failure on chevy's. You will need to replace the key tumbler. Even if you got it to turn chances are you would end up stranded if it happens again.
May 17, 2010 | 2003 Chevrolet Cavalier
Frigidaire dryer hums when button is pushed in but won't start
ok can u turn the tumbler freely,
if no well there is something stuck in you blower like a sock or something
if the tumbler turns freely
keep the door open and hold the door switch
try pushing the start button
and tuning the tumbler, yes all three at the same time lol you may need a hand
try tuning the tumbler when you hear a hum
if it takes off bad news your start winding on the motor is bad or the capacitor depending on your model
if it does not turn, but the hum continues longer than 1-2 minutes it could be just a belt
Oct 19, 2009 | Frigidaire Electric Dryer
Safe open but in locked position
I can't tell you how to set a new combination, without you having a tumbler key.
BUT I can tell you how to figure out the old combination.
First remove any armoured plate that covers the back and unscrew the cover plate. You will see wheels with slots cut in them. These are the tumblers. Now just like you know what the numbers are rotate the dial three times counter clockwise...then looking in through the back cover , slowly turn the dial clockwise ... look for the tumbler that is turning and stop where the slot lines up with the drop arm. Now look on the dial and write that number down. Now start on the second number by turning the dial counter clockwise until the second tumbler is lined up with drop arm. and so on
With a little patience you will figure it out.
I hope this helps you.. If you have any questions please ask.
Good Luck,
RSMITH972278
Oct 05, 2009 | Locks & Locksmithing
Put belt on dryerg
While I don't know about your specific dryer, most dryers are set up the same. I just replaced the belt on my Maytag LDE8404ACE. It was easy. The hard part was cleaning out 14 years worth of lint and fuzz that coated everything inside. Here's the instructions:
1. Unplug the dryer or disconnect power.
2. Remove the front panel. There are two screws, each is about 4 inches up from the bottom of the front panel. Unscrew them. Then hold the front panel along the bottom edge and pull it away from the dryer. Once it's away enough, the clamps along the top will pop and disengage from the dryer. Be sure to note the wires connected to the door switch are connected to the dryer. Disconnect them if you need to move the panel away from the dryer.
3. With the front panel off, you should be able to reach inside the dryer to remove the old, broken belt.
4. Remove the tumbler from the dryer. It's held in place by the tumbler front which is secured by 4 screws, 2 on each side. That piece will pull straight out toward you. With the tumbler front out of the way, the tumbler itself will come straight out as well. I recommend taking it out and cleaning the inside of your dryer while it's open. A vacuum hose works great. Also, check the pulley and the back two wheels that the tumbler rests on to make sure they turn easily. If not, you may want to grease them. Also, it's normal for the idler pulley to appear to be loose and wiggle in place. Once a new belt is installed, it's under tension from the spring so any play that exists shouldn't be a problem.
5. put the new belt around the tumbler with the smooth side of the belt against the tumbler. Use the old belt marks on the tumbler to align the new belt. It's easier to hook the belt to the idler pulley and motor pulley from the back. So we'll get to that part in a minute. Just let the belt hang loose for now.
6. Reinstall the tumbler front and secure with the 4 screws you removed earlier.
7. Reconnect the wires to the door switch, if you removed them earlier.
8. Reinstall the front panel, reversing the steps you took to remove it in #2 above.
9. Go to the back of the dryer and remove the access panel along the bottom right hand side.
10. From there, reach in pull the dryer belt around the idler pulley. Then take the belt on the left side of the pulley and move both the belt and the idler pulley to the right, until you can get the grooved side of the belt onto the motor pulley. I've attached a diagram with instructions.
11. Once connected, manually turn the tumbler so that the belt will align and make sure the tumbler turns as easily as it did when you first removed it.
12. If the belt looks good and you've manually turned the tumbler at least one full revolution (to ensure the belt didn't get twisted), then plug the dryer in and turn it on to make sure it works correctly. If so, then re-attach the access panel on the back of the dryer. You're done!
Nov 16, 2008 | Whirlpool LER5636P Electric Dryer
Broken belt that turns the drum
12. If the belt looks good and you've manually turned the tumbler at least one full revolution (to ensure the belt didn't get twisted), then plug the dryer in and turn it on to make sure it works correctly. If so, then re-attach the access panel on the back of the dryer. You're done!0798e0b.jpg
Aug 17, 2008 | Maytag PYG2300A Gas Dryer
2005 honda civic ignition tumbler
Take it to a locksmith. You don't want to risk pulling it down yourself especially where the immobiliser harness is concerned, in addition Honda tumblers are really hard to source, the defectives ones will have to be removed. You need an experienced locksmith to do this.
Jun 28, 2008 | 2005 Honda Civic
Dryers Logo
Top Dryers Experts
