My laptop is saying plugged in not charging - Computers & Internet
  • 3,530 Answers
Try to perform power drain. Take out the battery and unplug the power adapter. Press and hold the pwoer button for 30 secs. Put the battery back in and plug in the power adapter. Power on the computer and observe.
Posted on May 11, 2010
Dell laptop wont charge battery.
The Laptop charger or the charging point itself is bad or damaged. You'll need to try different charger to take your laptop to any nearest computer repair shop to have charging point repaired or replaced.
Oct 28, 2014 | Computers & Internet
What to do if my laptop says, "Plugged in, not charging?"
A lot of newer BIOS version hardware only charge the battery when not in use. Makes sense really as why charge a battery when not in use? It should charge when switched off, if not maybe the battery is faulty.
May 04, 2014 | Lenovo T41 ThinkPad Refurbished Notebook...
Not charging
The battery is not working as it should. Either, replace the whole lot under warranty or leave the battery on charge until it will accept a charge.
Dec 27, 2013 | Fujitsu LifeBook Computers & Internet
Battery indicator on my acer aspire 5517 laptop is blue what does it mean
Acer Aspire 5517 shows BLUE light when fully charged.
Start it and check battery indicator (tray item) will probably say
plugged in fully charged (with adapter plugged in)
Dec 07, 2013 | Acer Aspire 5517 Laptop
My laptop says its plugged in but not charging, what is the problem?
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 11, 2012 | Dell Computers & Internet
When first switched laptop on tonight I was shown a black screen saying that it needed to be connected to a approved Dell power sources. I plugged it in and the icon at bottom of screeen says that it is...
Usually that error means that your laptop's charging circuit is not charging the battery. Either your motherboard has a problem or your battery. Here's a link for your model's service manual: http://support.dell.com/support/edocs/systems/ins1525/en/SM/index.htm
Jan 04, 2011 | Dell Inspiron 1525 Laptop
Charging issues with a toshiba A215
Check the power adapter with a multi-meter, the voltage of the power plug that plugs into the power socket on the laptop should be slight higher than the voltage that is printed on the label on the adapter.
If it is faulty, there are replacement power supplies available on the Internet or at your friendly computer shop.
If the adapter is OK then the power socket on the laptop is faulty or this socket has a dry solder joint connection on the motherboard.
You can test this by wriggling the power plug when it is connected to the laptop, if the charge LED flickers and if you hold this plug in a certain position the charge LED stays on without flickering, then the power socket is faulty.
This can be repaired, but requires the laptop to be completely
disassembled. I suggest you get a quote first.
Sep 11, 2009 | Toshiba Satellite A215-S7422 Notebook
Battery is not charging in my acer aspire 5052anwxmi
check connections and also try to get another battery and test for the same
May 30, 2009 | Dell Inspiron 1525 Laptop
Computers & Internet Logo
163 people viewed this question
David Payne
David Payne
