Question about Microsoft Xbox 360 Console
It green screens after 10 mins
The screen turn green after 10mins whats wrong
    President:
  • 1,382 Answers
Are you using hdmi cable. If so your hdtv needs to have it's hdmi port reset .First unplug everything even the TV and xbox. Then disconnect everything and unplug every thing from the wall outlets. Then plug the TV back in and hook everything back up. The HDTV even with the power off can have it's hdmi port bumped so you need to unplug it to reset the ports.
Thank you
Posted on May 12, 2010
Hi I have an LG 37LC55 which works fine with scart no problem but when I am using hdmi after about 5-10mins the screen scrambles and goes green, purple, yellow but sound still works when I switch it off...
my freind i think it is not a problem.maybe it is from the device connected with tv hdmi try another device or go to system setting of the device to change the video format(try 1080i)
Jan 14, 2013 | Televison & Video
This is a graphics processor unit (gpu) fault, the console will need stripping down and new heatsink compound applying to the chip,this is basically the same fix as rrod, so there are plenty of free guides on youtube, if you want to tackle this yourself.
Mar 17, 2010 | Microsoft Xbox 360 Console
My converter box will not turn on. The light stays red. i plug it in and it lights red but it wont turn on it stays off and i use remote and i manually push the power button but it wont turn on!!
TRY
Unplug receiver.
Leave for 10mins.
Plug in again.
Wait another 10 mins.
Press the hand control stand by button.
In a few minutes the light should turn green and start options should appear.
Good luck. This works when my HD box freezes.
Feb 02, 2010 | Televison & Video
The screen is all bright blue
I have Model # KP-WS500. The screen turn blue.
May 02, 2009 | Sony KP-57HW40 57" Rear Projection...
Green Screen
Hi, how is the cable box hooked up to the TV? Is it HDMI cable or componet (red/green/blue) ? When you say totally green, do you mean the the picture is only green with the other colors missing or every color looks green ?
Mar 14, 2009 | Protron PLTV-37 37 in. LCD Television
Power indicator only blinks green for several minutes, then...
I had identical problem which continued for months before the screen started to get dim then went completely black with only the audio remaining. This will happen when the lamp and or balast board starts to fail. You can buy replacement lamp off the internet and install it using only a screw driver. Your Sony manual provides instructions. Don't buy any of those cheap off brand lamps; light output might be low.
Dec 03, 2008 | Sony KDS-R50XBR1 50" HDTV
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
MONITOR SWITCHES ITS SELF OFF
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After it turns itself off, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. I used to check my LCD monitor and could see window image using flashlight and found out that Some of CCFL lamps inside were broken. The lamps are very easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Thank you,
Tan
Mar 13, 2008 | LG L1717S-BN 17" LCD Monitor
Microsoft Xbox 360 Console Logo
139 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
