Take down cover of laptop G550
Take down cover
I receive an error when I open my computer. It says " This product is covered by one or more of the fllowing patents:Us5,307,459, Us5,434,872, Us5, 732, 094, Us6,570,884, Us6, 115,776 and Us6,327,625"
please help me
Posted on May 28, 2011
  • 942 Answers
Check on this link to follow this guide for teardown of Lenovo G550
http://consumersupport.lenovo.com/us/en/UserGuide/Guide_list.aspx?CategoryID=600154
select lenovo user guide's 1.0 & 2.0 versions. It will tell you how to teardown the laptop...
Posted on May 11, 2010
I NEED TO REINSTALL THE DRIVERS FOR THE TOUCHPAD AND POINTERS ON MY LENOVO G550
Goto start system, control panel device manager scroll down to human input devices right click and reinstall drivers.
Aug 18, 2012 | Lenovo G530, G550, G560...
Replace broken usb port on lenovo g550 laptop
broken usb on lenovo g550
you will have to remove the covers and the keyborad and the keyboard base plate. on lenovo g550, the single usb on the right side is replaceable easily since it is conneted with a flat cable to motherboard,but, the two usb ports on the let side are soldered on the motherboard and hence you have to remove the motherboard and desolder the broken ones and solder new cnnectors in their place. need experience in getting to e motherboard and remove it. see the youtube link for lenovo g550 laptop disassemble and assembling.mp4.
Jun 07, 2012 | Lenovo Computers & Internet
Lenovo g550 turns off when power supply is disconnected ,battery shows fully charged
Replace the battery, it's faulty.
Batteries only have a useful life, then they have to be replaced. Sounds like yours is doing like the ink cartridges, where they register as being full of ink when actually there is no ink in the cartridge.
May 18, 2012 | Lenovo G550 Notebook
My lenovo g550 keeps on shutting down like every 5 or 10 minutes.
sounds like it's overheating and getting a memory error. try to clean out the case. run with the case open to see if if that helps. blow out the dust on the CPU heat sink
Aug 10, 2011 | Lenovo G550 Notebook
The display of my Lenovo G550 Laptop goes shoot down after short time. How to prolong the display time on my computer
Change the power settings. Under power settings you can set how long before monitor ' hard drives turn off.
Jun 22, 2011 | Lenovo G550 PC Notebook
My lenovo G550 appears not to charge when the charger is plugged in despite turning the mains power on and off to see if power is getting though and the blue neon light showing on the mains...
Hi m529,
I see you are having issues with you G550 charging.
You mentioned that the light on the charger is lit up but then it suddenly switches Off, and you also mentioned that the charge still has a light but the power is somewhat low despite of a fully lit up charger Light.
Have you tried draining the power from the system?
  • Remove the battery and the Charger or AC Adapter as well call it from the G550 then press and hold down the power button for 10-15 seconds to drain power from the system motherboard.
  • Once drained connect the AC adapter but do not connect the battery yet, then turn the Laptop ON to see if the system will power ON using the AC adapter/Charger if it powers up then there is no problem with the AC adapter/charger.
  • After testing the AC adapter if it is working power down the Laptop doing a normal shut down.
  • Once shut down or turned Off insert the Battery back in the Laptop then turn the Laptop ON using the battery only without the AC adapter/charger see if the system will turn ON using the Battery only.
  • If the Laptop powers On using the battery alone with out the AC adapter then the battery is most likely working as well on the issue.
  • Now power down the Laptop then connect the AC adapter to the Laptop with the Battery in the Laptop as well then turn the system ON again see if the problem will Occur again having the battery and the AC adapter/charger if the Problem happens with both Battery and AC adapter on the Laptop then the problem is the Motherboard, most probably the motherboard is having issues relaying power from the AC adapter to the battery and may be sent to the Depot for repairs.
I suggest that you call Lenovo for further information about your system, if you still have warranty and is still in the one year period then your system will be covered for any repairs needed - you can call @ 1 877 453 6686 for troubleshooting, you will be asked for a serial number Located underneath the Laptop on a small white sticker that states s/n meaning serial number.
I hope that this Helps.
Have a nice day,
mvincentc
Jun 18, 2011 | Lenovo G550 PC Notebook
Laptop model Lenovo G550. Where's the cmos battery located on the motherboard and how to get to it? Thank you in advance.
Laptop model Lenovo G550. Where's the cmos battery located on the,i need to remorve my supervisor password i forget it.
Apr 24, 2011 | Lenovo G550-29583AU Notebook
I ve problem when i try to shut down my lenovo G550 2958 laptop.Pls help...
Hi knabeela86,
What is the problem that you are encountering when shutting down the computer?
Try also to perform power drain it might help.
How to perform power drain:
1. Turn off the computer completely.
2. Take out the battery from the system and remove the AC adapter.
3. Press and hold down the power button for 10 - 15 seconds.
4. Put back in the battery and AC adapter then try to power on the computer.
Hope it helps,
Thank you for using FixYa.
Dec 17, 2010 | Lenovo G550 (2958ACU) PC Notebook
Computers & Internet Logo
250 people viewed this question
David Payne
David Payne
