Question about Peavey Pv 2600 Power Amplifier
LIGHTS UP THEN TURNES OFF STRIGHT AWAY - Peavey Pv 2600 Power Amplifier
  • Peavey Master
  • 5,603 Answers
It is probablly going into a protect mode. Continued trials MAY cause further damage to the electronics.
Posted on May 11, 2010
My yamaha psrE23 not responding when plugged to electricity what maybe the problem if I put batteries it's just giving me a feedback
Hi
In terms of no electrical power it could be either a faulty power adaptor, broken socket. However the feedback with batteries could indicate a more serious fault. If the batteries are know to be good try a reset. Hold down the highest sounding key while turning the keyboard on. Release once you have lights or a display on screen. Has the noise stopped? If so then try electrical connection again, if still no power ensure you are using the correct power adaptor and see if it works if you wobble the connector - they break away causing an intermittent fault. Report back and maybe I can offer more advice depending on how you progress with the above.
Dan
Becketts Music Ltd
Feb 03, 2017 | Yamaha Psre223 61 Full Size Keys Bass...
When i plugged it in the lights started flickering and some smoke came out. Now when i plug it in it won't turn on
sounds like you blew some resistors, or perhaps melted something. Take it in to a specialist and get a quote for repairs
Jan 29, 2014 | Behringer Vt100fxh Virtube 100-watt Guitar...
My Mackie 1400i thumps when I turn it on
Do the protect lights light up when you turn it on? There is a soft start circuit that should delay for about 3 seconds when powering it up, it sounds as if this is not working. If you don't get the protect lights for a second or so when turning it on then this has failed and you need to get it serviced and repaired before more goes wrong.
Sep 17, 2013 | Mackie Music
I have a Yamaha Clavinova clp 360; it no longer turns on.
Paul, inside of the Clavinpva at the rear where the power cable connects to the board. there is a 124 volt 1.25 amp fuse. the old type that is a glass cylinder with silver ends. it's an easy fix and will cost about $3.00 for a pack of four. You have to9 take out all of the screws on the bottom of the piano in order for the top to slide off, but you can do it in about 15 minutes!
Dec 30, 2012 | Yamaha Full-Size Keyboard
Yamaha dgx-640 display
There is a small turning button on the back of the keyboard to change the screen tone and brightness,happend to me and this fixed it,i thought mine was broken too,till i spotted it
Oct 21, 2012 | Yamaha DGX 640 Keyboard Arranger
Allen and Heath PA 28 is making pulsating sound, lights blink for left and right channels and the sound can be heard throught speakers. It won't go away and it is impossible to use the mixing board. ...
You haven't given us much information... You obviously have some sort of feedback and saturation in process. First thing is to unplug ANY signals into the unit including any inserts and see if problem goes away. If it does, start adding them back in. If it doesn't go away with only the main outputs then VERIFY that you are using BALANCED interconnects to your amps/speakers AND that the mixer AND all of these amps/speakers are powered from the SAME receptacle or power conditioner module. If the BARE mixer with only headphones has the problem, then you have a power supply in the mixer that is squeging.
Nov 03, 2011 | Allen & Heath PA28 Effects Mixer
When i turn it on i get a hum that gets louder then the fuse blows. if i turn on stand by before the fuse blows the hum goes away
Most likely one of the diodes CR6 through CR9 is shorted... Test them with an ohmmeter with the standby switch OFF and no power plugged in either. Slight chance one of the power tubes is shorted but that is rare. A shorted tube socket is another possibility but it too is rare. If one of the diodes is shorted, replace them all as the others are likely degraded. Put a 150 watt lamp in series with the power cord to test to avoid blowing fuses. If the lamp lights and stays on, there i still a short. the filter capacitors may also be degraded if a diode has shorted.
Aug 29, 2011 | Fender Hot Rod Deluxe Guitar Combo...
This problem has to do with a Hartke 3500 bass amp. I recently purchased a replacement UCISC (the part with the female plug and fuse box) and replaced it. I tried to be very careful putting all of the...
Easiest way to check is to measure the resistance between the ground pin of your cord and the chasis of the unit. It should be very low. That is the only critical one... Look at a receptacle. See one bllade is wide? That is the neutral. The other one is the HOT side. The HOT SIDE should go to either the fuse or the switch first in your unit. If you have those right the third wire will be right.
When powering up an amp there often is a noise until the amplifiers balance out. Very high quality and high power amps have a relay that disconnects the speaker until balance is reached... but the smaller amps do noot have this feature.
May 02, 2011 | Hartke Bass Amplifier Half Stack with...
I have a Roland FP-8 that I used for performances. I have noticed some static in the past couple of weeks in the sound. Now it doesn't play at all. The display lights up normal, and the buttons work and...
your sound process digitaliser has burned out the crackling should have warned you as to the fault and had it replaced (fixed) right away this is a simple repair but does need to be done by an electronics tech
Jan 02, 2011 | Roland Digital Piano FP4 Black With Stand...
sounds like your internal protection is being activated. either your speakers are connected wrong, or you have the volume up to loud, or there is something wrong in the unit itself and it should be fixed by someone who knows electronics
Mar 17, 2010 | Peavey Pv 2600 Power Amplifier
Peavey Pv 2600 Power Amplifier Logo
51 people viewed this question
Top Peavey Music Experts
Ben Armstrong
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Peavey Music Expert? Answer questions, earn points and help others
