Xerox Phaser 3125 & D-Link DP-301U - printer sill sleeping
Xerox is attached to the Print server d-link via usb. There are 3 computers in the network. All of them ''see'' the print-server. I print a document. This document is printed correctly. Then I wait fo 5 minutes and print another document. Error message ''the document cannot be printed'' occurs on my screen. After that I open and close the printer's cover - document is printed immediately. It seems like when the printed is in ''sleeping'' mode the print-server is not able to wake up it. Can anybody help me?
PCBuilda
  • 101 Answers
SOURCE: Scanner
This is not a solution just a possible fly in the ointment. I have often found that scanners only work when attached directly to a computer. Scanning over the network is not a solution I have found. You can always share out the printer from the attached pc.
Posted on Mar 14, 2008
SOURCE: D-Link DP-301U Problem
i cannot get my ip address after i press the reset button at the print server DP-301U. How can i get?
Posted on Oct 30, 2008
MooseMe
  • 30 Answers
SOURCE: HP LJ P1008 can be used as network printer ?
I have one of theses D-Link PD-301U. It does NOT support a printer like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1008 is NOT in the list):
LaserJet
  • 1200
  • 1500 (USB 2.0)
  • 2200
  • 2200D
  • http://support.dlink.com/faq/view.asp?prod_id=2135&question=DP-300U%20/%20DP-301P+%20/%20DP-301U%20/%20DP-311U%20/%20DP-G310%20/%20DP-G321
    Posted on May 22, 2009
    MooseMe
    • 30 Answers
    SOURCE: problem with scan from print server
    This unit does NOT officially support Samsung printers... but it will allow printing with some. It does NOT support multi-function printers features like scanning for any brand of multi-function printers.
    Posted on May 25, 2009
    • 5 Answers
    SOURCE: D-Link DP 301U Print Server not continuous print from vista
    Make sure you have byte counting enabled if you are printing through LPR.
    Posted on Jul 31, 2009
    I am using DP-301U print server and wanting to attach with hp 1020 plus. However the printer in not printing. what is the root cause and give the solution please...
    Hello and welcome to fixya.
    First off, I would like to provide you a link with the print server's manual to download it directly and have it as spare.
    The printer you are trying to install is a laser printer (black/white only) and probably a bit old model.
    Therefore, if you are trying to print from your computer over ethernet, and you have windows vista or 7 (64 or 32bit accordingly) you might have the inappropriate drivers for either the print server or the printer. You can find all of the HP printer's drivers HERE. Select carefully based on your OS.
    As a SIDENOTE: If you just need the drivers installed and there are only larger setup execut. files available, you can use 7zip or winace to open up the *.exe file and navigate to the appropriate folder and extract only that one to your computer and install the driver(s) from there.
    The D-Link DP-301U print server drivers are available HERE. Default username and password for the management console of the print server can be found at pdf manual page 25. The url to access the administration console is dlink-******,where the asterisks stand for the last 6 digits of the print server MAC address.
    Overall, not to make things over-complicated (150+ PDF user manual pages) you need to do the following:
    1. Install the appropriate drivers of your hp printer on the computer that will have also print serv. softare installed.
    2. Install the appropriate software/drivers of the dlink print server on the same computer.
    3. Plugin the usb cable of your printer to the print server's USB port.
    4. Plugin the ethernet cable of your print server port to the ethernet port of your home router/switch.
    5. Setup Fixed IP settings for your print server configuration (page 20 on the manual).
    Let me know how that went. I believe you will manage to do it that way quite easily.
    **Don't Forget to vote how helpful this was.**
    Thanks.
    Regards from FixYa.com
    Apr 22, 2011 | D-Link DP 301U (DP-301U) Print Server
    I am able to configure the print server and configure printer but not able to print
    try this.
    i got my dp-301u to work fine with my hp1020 on 2 different workstations with the following steps.
    1. install printer locally via usb and test.
    2. create a second printer as per the dlink manual creating a port. don't worry about the name as we will delete it.
    3. once created go into the properties of the 2nd printer and change the port to something local - anything will do to free up the port.
    4. go into the properties of the printer that was created in step 1. and change the port to that of the print server.
    5. test print. should work fine.
    cheers!!
    Sep 17, 2009 | D-Link DP 301U (DP-301U) Print Server
    Printing Problem
    cheers!!
    Aug 11, 2009 | D-Link DP 301U (DP-301U) Print Server
    Print command accept but not printing
    cheers!!
    Aug 10, 2009 | D-Link DP 301U (DP-301U) Print Server
    Print server DL-301U setting
    I have one of theses D-Link PD-301U. It does NOT support a printer like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1006 is NOT in the list):
    Apr 14, 2009 | D-Link DP 301U (DP-301U) Print Server
    Hp 1020 dp-300u
    dont' worry about what the d-link site says. its because they haven't tested it. i got my dp-301u to work fine with my hp1020 on 2 different workstations with the following steps.
    cheers!!
    Apr 13, 2009 | D-Link DP 301U (DP-301U) Print Server
    LaserJet
  • 1200
  • 1500 (USB 2.0)
  • 2200
  • 2200D
    Feb 10, 2009 | D-Link DP 301U (DP-301U) Print Server
    Problem with scan from print server
    Jan 06, 2009 | D-Link DP 301U (DP-301U) Print Server
    It should be fine as long as it is in the range that the router can recognize and that it doesn't conflict with another IP address used on another device. Usually on the networks I design I keep the printers on higher IP address so that they can be managed on a certain range.
    Is this the wireless print server?
    What specifically do you mean by PJL printer block?
    Aug 04, 2008 | D-Link DP 301U (DP-301U) Print Server
    Scanner
    Jan 09, 2008 | D-Link DP 301U (DP-301U) Print Server
    Computers & Internet Logo
    David Payne
    David Payne
