Question about Polk Audio PSW150 Speaker
My subwoofer atarted making deep humming sound,
My subwoofer atarted making deep humming sound then stopped working. I changed the fuse and then when i turned it on it blew the fuse. What can i do?
  • Polk Audio Master
  • 5,056 Answers
Some kind of semi-conductor in either the power supply section or the main amp has failed and acting like a piece of wire, which is why the fuse is blowing. You might want to look around for damage or burning. If it's a transistor or diode that has gone an Ohm Meter will show it up well. For when you put the test probes on the terminals of the suspect part, it will be like you had touched the probes together!
Posted on May 11, 2010
Loud buzz in sub woofer, soundbar sounds fine
How to Stop a Subwoofer Hum - HowStuffWorks
electronics.howstuffworks.com/how-to-stop-subwoofer-hum.htm
Would you like to learn how to stop your subwoofer from making a consistent low-frequent hum or buzz? Read this article to learn how to stop a subwoofer hum.
Aug 03, 2015 | Audio Players & Recorders
When I turn the volume control on my home powered subwoofer, it makes a humming sound, then it stop working
check your connections, RCA, Speaker wires, maybe there is grounded. try other wires which you think in good condition..
Aug 10, 2012 | JBL Audio Players & Recorders
Hello. I just purchased these speakers and there is a low static hum in them. Also, if I turn up the bass volume on the subwoofer I get a deep hum and no sound. Any assistance would be greatly...
Double check your wiring again, sounds like something is either not hooked up right or maybe you got faulty speakers. There shouldn't be any hissing or humming in any speakers. Get a flash light and make sure you have it in the right spot on your computer most sound cards have about 5 different jacks you could have simply put it in the wrong jack.
May 15, 2011 | Cyber Acoustics CA-3080 Computer Speakers
There is no sound coming out of the subwoofer
I assume it's an active subwoofer, since it hums. Did you activate sub in the receiver menu? Did you turn up the volume on the sub?
Jul 08, 2010 | Yamaha HTR-5840 Receiver
My subwoofer atarted making deep humming sound, then stopped working. I changed the fuse and then when i turned it on it blew the fuse. What can i do?
The voice coil of your woofer is off centered and shorting on the armture causing the speaker to draw too much current. The fuse blew thereby protecting the output stages of your amp. Replace the speaker.
Mar 17, 2010 | Polk Audio PSW150 Speaker
Carver d12 subwoofer making humming sound
check your rca ground on the woof or the receiver you have a bad ground on one
Oct 09, 2009 | Electronics - Others
Acoustimass Subwoofer has a low "hummm" sound when turned on.
Sounds like an inadequate ground wire in the signal cable. You may have to replace the cable between the reciever and bass module. It also, however, may be IN the bass or reciever module.
Aug 04, 2008 | Bose Acoustimass 15 System
Annoying humming sound coming from subwoofer...
The humming sound usually comes from the DC supply that is not filtered. The a/c converted or changed to DC needs to be "cleaned", before going into the ckt. Usually the capacitor and resistor network go bad, maybe causing the fuse to open. Even if you replace it, u may still have the "humming" because the circuit is still bad.
If you know how to look at the capacitor, resistor,or coils AFTER the diodes & replace the damaged part, u should be good!
Mar 02, 2008 | Boston Acoustics MicroMedia Computer...
323 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
ed_dantes
Level 1 Expert
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
