Question about Epson Stylus C48 InkJet Printer
My Epson C48 doesn't print any thing . it just roling the papers
    Scholar:
  • 141 Answers
Make sure your cartridges is not dry ???? If so, replace them!
Posted on Mar 28, 2008
  • Patrick St-Jean
    Patrick St-Jean Mar 28, 2008
    Before that try this....
    Put warm water on a soft clothe....and press gently your cartridge....sometime it's take off the dirt...you'll suppose to see ink on your clothe ???
Epson stylus c48 blurred print
kindly replace the print cartridge.your problem will solved
Aug 30, 2012 | Epson Stylus C48 InkJet Printer
Epson stylus c48 paper not loaded correctly error
@Linzi_mackie
"c48 not loading..."
Check that paper is not curled at leading edge.
Some printers are finicky about exact straightness.
Otherwise check:
Paper not glossy - roller-gripper may be doing a 'wheelie' on the edge.
Rubber gripper not worn down - the pickup roller usually has one or more rubber 'rings' around the roller to grab & feed paper by friction.
If all else fails, open cover and inspect gearing to roller, broken brackets which can cause misalignment.
Try running 'open' and see what happens.
Regards,
Clive.
Oct 25, 2017 | Epson Stylus C48 InkJet Printer
Installed new colour inks on Epson stylus C48 and printer will not respond red light keeps flashing
hewlett packard c48 printer had a piece of paper stuck in it pulled it out, now paper goes through but print head does not print any suggestions
Oct 04, 2010 | Epson Stylus C48 InkJet Printer
Epson c48 red and green lights flashing and not printing
hi c48 cartridge changed ,paper checked static red light on but no one is at home
regards john
Dec 04, 2009 | Epson Stylus C48 InkJet Printer
Out of focus print
check what type of paper you are using if laser paper images bleed and look blurred use good quality injet paper.
Oct 07, 2008 | Epson Stylus C48 InkJet Printer
Print alignment and cleaning heads
this is the utility present on epson printer software itself, go to control panel select printers, then select the c48 right click on it, go to printing preferences, then select maintenance
Aug 15, 2008 | Epson Stylus C48 InkJet Printer
My Epson Stylus C48 Reports Sevice Required , What Should I Do ?
Has the printing head got jammed recently?
Open the cover and look at the printing head (where the ink sits).
Is it located to the very far right or is a couple of inches out from the right?
If it is out, gently push it back to the right as far as it will go, then power it back on, it should do all of its checks as normal and the head will move a few times, but it should return to the far right and then be ready for printing.
Check there is no paper jammed anywhere and reload any paper.
Try to print again
Does it now work??
Aug 11, 2008 | Epson Stylus C48 InkJet Printer
Printer will not feed/accept paper.
Front LCD reads error "Check Paper & Retry" When paper is inserted and loaded correctly and machine is reclosed the printer then initializes then reverses the feed of the paper and is ejected and error continues to reappear.
May 25, 2008 | Epson Stylus C48 InkJet Printer
Epson C48 inkjet printer flashing lights
I can tell you how to fix this if anyone is interested - report back if so.
Jan 13, 2008 | Epson Stylus C48 InkJet Printer
Epson Stylus C48 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
