Question about Procom QL300TYLA Heater
Doesn't turn off
Everything works great except the heater won't ever turn off when the thermostat is set at the lowest postion. I have to manually turn the heater to pilot cuz it's cooking me out!
  • 109 Answers
Only three options here first check for shorted wires , second bad thermostat (try unplugging thermostat wires one at a time if possible to see if unit turns off, this will also tell you if the gas valve is stuck open if you take all the wires off the thermostat and the thing still reuns, ) good luck.
Posted on Mar 30, 2008
97 Dakota 3.9 Vents let hot air into the cab like the heat is on even when the heat is set to off and the temps turned to cool.
There are flaps called blend doors, they can be ether electronic or manual ( cable operated) and sometimes vacuum, they are the ones responsible for making the HV/AC blow cold or hot air. Just go under dash and adjust the temperature cold/hot and listen carefully for the blend door to move and or an actuator to close or open.. Best thing is just to take out actuator and adjust it manually...
And you probably have a bad thermostat thats why the truck wont reach operating temperature. Previous owner may have taken it out to try to hide and overheating problem. Good luck ??
Jul 31, 2016 | 1997 Dodge Dakota
How to wire a honeywell rth2300/rth221 to a five wire connection
I am not familiar with this particular thermostat; however, here's some general information; I hope this solution will help you troubleshoot.
Multiple Thermostats set in 1 zone will conflict; the one with the lowest setting will be the determining Thermostat. Here's an option you can try yourself; my solution is 'hard reset' the thermostat - afterwards, i'm outta options. invest in external thermometer battery/natural types; & manually turn t-stat ON or OFF; Additionally, keep an eye on how much draw your AC is doing on your meter.
setOFF manual; however do NOT change settings or power-off t-stat. I'd keep it on what you had intended it from day1. However, some may debate to turn everything off beforehand. personally, myself, poweringOFF the switch connected to your t-stat works. Remove battery and reinsert inverted; wait (5sec-1min); remove; wait 1min ('debatable' timeframe 5sec - 1min); reinsert batteries correctly; if you have a programmable thermostat; do the same with the hit 'reset filter' held down & wait 5-sec1min; observe roomTemp reading. May I suggest to keep an extra thermometer around to determine if temperature reading from the thermostat correct? Friendly reminder to turnOFF 'auto' mode during this hard reset. If reset requires reprogramming your t-stat, do whatever required to set your desired setting. cheers. best of luck.
May 11, 2014 | Honeywell Programmable Thermostat Heater
Trouble shooting codes
Code Error 53 is "defective outdoor sensor" error.
source: search engine keywords - Code Error 53
I am not familiar with this particular thermostat; however, here's some general t-stat information; I hope this solution will help you troubleshoot.
Multiple Thermostats set in 1 zone will conflict; the one with the lowest setting will be the determining Thermostat for the group. Here's an option you can try yourself; my solution is 'hard reset' the thermostat - afterwards, i'm outta options. invest in external thermometer battery/natural types; & manually turn t-stat ON or OFF; Additionally, keep an eye on how much draw your AC is doing on your meter.
disable auto & enable manual; however do NOT change settings or power-off t-stat. I'd keep it on what you had intended it from day1. However, some may debate to turn everything off beforehand. personally, myself, poweringOFF the switch connected to your t-stat works. Remove battery and reinsert inverted; wait (5sec-1min); remove; wait 1min ('debatable' timeframe 5sec - 1min); reinsert batteries correctly; if you have a programmable thermostat; do the same with the hit 'reset filter' held down & wait 5-sec1min; observe roomTemp reading. May I suggest to keep an extra thermometer around to determine if temperature reading from the thermostat correct? Friendly reminder to turnOFF 'auto' mode during this hard reset. If reset requires reprogramming your t-stat, do whatever required to set your desired setting. cheers. best of luck.
Apr 12, 2014 | Honeywell Programmable Thermostat Heater
I have a customer who has a Warm Morning direct vent propane heater: model DV.203 AMA. His complaint is the thermostat does not seem to work properly. The dial is turned to the lowest setting and it...
Some thermostats have a default lower limit such as 60 degrees to prevent complete loss of heating. The lower limit is not set by the user.
Nov 19, 2013 | Heating & Cooling
Thermostat is not shutting off heater..... can't adjust....gets room too hot. I keep on pilot only this is a EMpire RH25
Your heater uses a capillary bulb type thermostat sensor. If the small copper tubing that runs from the copper bulb to the control valve ls bent or crimped, it won't work properly or at all. Try setting the temperature at the lowest level, so that the room heats up gradually. Then, see if the Thermostat shuts it off. Also check the air intake on the front of the heater to make sure it's not obstructed or clogged in any way. If all else fails, contact Empire Comfort Systems Technical Service Dept @ 800-851-9396.
Hope this helps you troubleshoot and solve the problem.
May 02, 2011 | Empire RH35 Mid-Size Heater
Refridgerator is freezing everything
This is likely a thermostat failure. The thermostat is no longer shutting down the compressor or sensing the temperature wrong. The thermostat is a module inside most modern refrigerators and is a fairly easy fix except for the cramped quarters. You can order the thermostat from an appliance repair store. I suggest getting the service manual while you are at it if you have no experience taking a fridge apart.
Do not damage or bend the sensing tube sharply at any time. Be gentle!
Mar 22, 2010 | Amana Refrigerators
The refridgerator side is freezing everything.I have turned the knob to the lowest setting and everything is still freezing. what is the problem?
timer might not be working, or the thermostat or the heater. Does the compressor is always on. Compressor works for some hours then it stops
Jul 24, 2009 | Refrigerators
How do you vent thermostat on 325E (1985)? I replaced my upper radiator hose and I have a feeling thermostat will not open. Thanks for input on this matter.
There should be 2 bleeder screws in the system, one on the expansion tank, and one on a thermostat housing. Open both screws all the way. Turn the key to the On postion (but dont start the car). Then turn the heater to max heat, but have the fan set at the lowest setting. Fill the expansion tank til coolant comes out of both bleeder screws with no bubbles. After that close the screws (be very careful not to over tighten them!!). Then completly fill the expansion tank. (dont mind the full mark, if theres air in the system, it will drop the level in the expansion tank) And thats it. Drive the car around then check the level.
Mar 01, 2009 | 1985 BMW 3 Series
Switching thermostat from farenheit to celsius
My thermostat was set on celsius and couldn't get it to change back to fahrenheit. My son suggested pressing both up and down arrow buttons at the same time and it worked. It changed back to fahrenheit.
Feb 16, 2008 | Honeywell Programmable Thermostat Heater
Can someone please tell me what is the lowest temperature setting a Fahrenheat 3000 Watt Large Room Fan-Forced Wall Heater Model FZL3004 will turn on at ?
about the only way I can figure is to let the room get very cool and adjust the thermostat to its lowest setting. now turn on the unit. monitor the heat until the stat just opens. the thermostat bimetal will be closed and will open when the bimetal expands and opens its contacts. another way is to hitch up a chart recorder to measure temperature with its output connected to the heater. [too expensive for you or the DIY to accomplish]
Dec 13, 2007 | Fahrenheat FFH1615 Heater
Procom QL300TYLA Heater Logo
110 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
