Question about Home
Can you just buy a toliet seat base?? - Home
    Scholar:
  • 102 Answers
Im not sure I understand the question so please excuse me. You can buy a toilet seat, and they usually attach to the toilet bowl. If the porceline that the seat is attached to is broken then the bowl will most likely need to be replaced. Most of the time you can replace the toilet cheaper than just replacing the bowl. Hope this helps.
Posted on May 11, 2010
I have a Jacuzzi low flow toliet. Sometimes the water won't shut off after it is flushed
A frequent cause of this is a defective flapper. If the flapper does not seat properly after a flush, the refill water will flow continuously
Feb 19, 2013 | Home
Koler toliet seat split right in front
Aside from the fact you posted a toilet seat
under automotive questions,all you can do
is replace it
If you can't find the model & color you like, go to the
internet & buy online. That is what I had to do
The best seats are actually wood & coated to look like
plastic,so there you go,a bad tree
Nov 13, 2012 | Cars & Trucks
Need to purchase a 124-2000 toliet seat
Go to nearest store it buy it from Online sites...
Nov 12, 2011 | Eljer Toilet Seat Tosca 124200000
Toliet seat lid doesnt drop slowly anymore ( 4 yrs. old )
Either live with it or replace it. The hinge is not serviceable and the soft close action does not last forever. They rarely last more than five years, maximum.
Jun 19, 2011 | Kohler Toilet Seat - Elongated Front Quiet...
When I flush, I believe the flapper is not seating correctly inside the toliet because the pump runs ocassionally!?!? Any suggestions?
Those flappers need to be replaced regularly. They are available at many store like Home Depot or Lowes Make sure to get the make of your toilet and maybe even the number of the tank. It is stamped on the inside of the tank.
Then buy a new flapper and replace it, it is easy!
heatman101
Apr 20, 2011 | Saniflo Home
The tank wiggles/shakes doesnt seem secure. I am worried if I crank down on the bolts the tank will crack. Also my ceramic floor is not quit even there is a crunching noice when you set on the toilet....
you are correct if you overtighten the bolts the tank will crack.
They make rubber spacers that go between the tank and the stool, that can be put in to help the part of rocking or wiggly, try that.
with your toliet making a crunching noise on the tile, my first question is does the toliet rock at all? i would try and tighten the bolts on the base or the next step would be to pull the toliet and put a new wax ring then tighten it down. It makes a crunching sound because part of it is hitting the tile so makes sure it tight to the floor
Jan 01, 2011 | Jacuzzi BK37959 White Era?? Two-Piece...
Toliet won't get rid of solids
first shorten the chain from flush lever to the flapper valve by one or two links at a time until flushing properly
second the flapper valve might need a wipedown as well as its seal (top edge of tube where water goes down into bowl) the leaking is because the flapper valve is not seating properly.. you may need to replace the flapper itself.. easy to do, and a common part at hardware store.
Jul 08, 2010 | Toto Drake ADA Compliant Toilet with...
yes places like lowes or home depot have the bases or lids seprate most come together but if you ask an associate they can usually take you to where there at,
Mar 17, 2010 | Home
Toilet Question
Yes, it will run up your bill! Sounds like the float is hanging up. Take tank lid off and flush, watch the float and if your tank fills quickly but does not stop, bend the float arm to angle the float down further, this should allow your water to stop coming in much quicker. The other possibility could be if the plug at the bottom does not seal correctly after flushing, if so, the water will leak until the plug sits down all the way.
Apr 11, 2009 | Kohler K-4709-96 C3-200 elongated toilet...
Home Logo
159 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
