EVOTEL/MATSUI ELCD32USBFHD Television: Scart audio o/p problem
Evotel/matsui ELCD32USBFHD Television: Scart audio output does not follow what input source is selected it remains on terretrial tv. Can't connect to home cinema system because of this. The manual says nothign about any setting to change this. Is it a known fault?
SOURCE: TV, Sky, DVDR, VCR + Wii connection
i cant see any problem with the connections. have you tried to connect the dvdr along with sky to another tv set? and did the same problem occured? if not, try connecting it the same way with another tv. and see if thesame problem would occur. if the same problem appears check if the connections from sky to dvdr scart if it is loose or not. try to clean the solid wire of the cable. if proble still persists dvdr is faulty. if not, defenitely there is a problem with the tv. and i suggest for you to have it checked.
Posted on Oct 06, 2007
Cryptonteki
  • 97 Answers
SOURCE: Connecting a T22 Laptop to a Matsui television
you’ll need two outputs on your laptop that are typically found on most: the first is a small round yellow socket usually found on the back of your laptop, which is the S-video socket. The other socket you need is either a line out (unlikely) or headphones socket (more likely). You also need a TV with the correct inputs, which will ultimately decide which cables you need. The solution you decide on will be determined by your budget, and the prices and codes below are taken from here, so shop around and you may get a better bargain locally or online.
First, you need two separate cables for video and audio: S-video to S-video (£3.60, 35551), and Stereo 3.5mm plug to 2x RCA plugs (£2.80, 35491). Both cables are two metres long and longer cables are also available from the same site. Your TV will require either equivalent S-video and RCA audio inputs or a SCART socket - if it only has the latter, you’ll also need a SCART adapter (£3.25, 35570).
Once done, plug them all in and switch your TV on, switching to the A/V channel. If nothing appears, open the Display Properties Control Panel, switch to the Settings tab and click Advanced. Look for a Display tab or something similar where you’re able to switch on the S-video port to enable the laptop’s display to route through the TV. Finally, when watching DVD movies (you’ll need a DVD player to do so), look for the option to run them full screen, so you get the best possible picture from your TV.
Posted on Mar 02, 2008
SOURCE: Help with connecting home cinema to xbox
if your tv supports this. go to ebay type in "hdmi" buy one for around $10.00 plug into xbox. set your tv to which port you have ,(if you have more then one). bingo,bango ,your done.
"no hdmi"? and you have com. on your tv. plug corrosponding color plugs for component ,L&R audio plugs .
change tv to comp.( not video) your done
Posted on Jan 30, 2009
  • 21 Answers
SOURCE: No picture on TV through Sky, Home Cinema is on but have sound.
do have sound and picture at same time you will need a fibre optical cable, you connect that from your cinema system to your tv. then you need to set your cinema system to digital input or fibre optic or check by pressing aux on your remote and see which is the right one. i am not familier with panasonic as i have samasung.
Posted on Sep 14, 2009
robert157
  • 47 Answers
SOURCE: I have just got a Matsui ELCD32USBFHD 32 1080p LCD
have you pressed the source button on the remote and changed to DTV?
Posted on Feb 20, 2010
Why does my evotel elcd40usbfhd screen only half work??????
Hi Ben
It could be a T-Con failure. There's a loss of part of the signal between the board and the display. A few components could be the culprit. Do the usual turn it off unplug for a while Ect, and see if you can update the firmware and software. Try Support@evotel.com
May 13, 2014 | Televison & Video
Sky remotes code evotel elcd32usbfhd rev 4
Check these sky codes. 072,046,029,037. If you wish to get more codes, check this link.
Feb 14, 2013 | Universal Remote Control 42203 Remote...
I have an Evotel TV model ELCD32USB and I have purchased a new remote control and I need the code do you know it? Thanks
Welcome to FixYa!
Try the Matsui Codes. If I'm not mistaken. Evotel is manufactured by Matsui.
Matsui codes: 003, 004, 009, 013, 019, 025, 026, 027, 028, 030, 051, 062 068, 091, 099, 123, 147, 148, 164, 169, 173, 180, 215.
Note: Sometimes, the code depends on what kind of remote control you have. The codes above works best with Gemini Remote controls.
Thank you for using FixYa.
Have a great day.
Jas247
Apr 28, 2011 | Televison & Video
4 digit remote code for evotel ELCD3210USB
Try using the Matsui codes as that is Evotels old brand name
Jun 01, 2010 | Televison & Video
Cant get code for 40 inch evotel to work sky plus
I've tryed all the codes I can find and still nothing!
Feb 05, 2010 | Televison & Video
Evotel tv codes for sky plus
I need a code for my Evotel tv model number elcd40usbfhd
Jan 16, 2010 | Televison & Video
Mar 02, 2008 | IBM ThinkPad T22 2647 Notebook
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
