Question about Sanyo Xacti S650 Digital Camera
Won't turn on despite new batteries fitted correctly. The camera was bought in 2008 and only used a few times but now it won't turn oni've put brand new Duracell batteries in it and when you turn it on the screen come on for a second then turns straight off again.please help.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Feb 11, 2011
I have a problem with a 2008 Dodge Charger, my battery went bad and I had to jump it off to take it and get a new battery put in but now my new battery won't start my car not even when the new battery...
When you jump started the vehicle, it started as normal and you drove to a shop to have a new battery installed.?? Correct??
1. Who removed the old battery and installed the new one?
2. Did the car start normally immediately after the new battery was fitted? How frequently were you able to drive the car on the new battery before the problem you described appeared?
3. Has anything been done to the vehicle since the new battery was fitted.?
Dec 21, 2012 | Cars & Trucks
CX7300 Digital camera won't turn on. New batteries get hot after being put in the camera after a few minutes.
No. This camera requires service/repairs, the repairs will be more than this model camera is worth !!!!
Nov 12, 2012 | Kodak EasyShare CX7300 Digital Camera
My, 2008 kawasaki ninja 250, gas tank won't open. When I insert the key, it won't turn. I've pushed and fidgeted it as much as possible to the point before breaking the key in it. ...
Hey Simon,
I would haul it to a local (GOOD) locksmith, they will get it open..
Are you 110% SURE it the RIGHT key???
Good luck...
Jul 27, 2017 | 2008 kawasaki Ninja 250R
I dropped my canon powershot SD 4500 IS and now it won't turn on! It's survived countless other falls just fine, and would turn on immediately then. All times, including this time, have been when...
Really!....you've dropped your camera "countless" other times and now you're concerned because this time, it won't turn on!!! You're not sure what else to do?!!! How about not dropping your camera. How about using the wrist strap. Your dropping luck has run out...your camera does not have nine lives.
Aug 23, 2011 | Canon PowerShot SD4500 IS/IXUS 1000 HS...
My Nikon Coolpix s550 won't turn on despite having charged the battery. I went out and bought a new battery from Best Buy today and tried to get information on what might help but, surprise, the guy...
refurbished items sure have hidden defects/problems that later contributes to malfunction. i think, one of its internal chips(techy things inside) has worn out... probably needs replacement.. i suggest look for a technician.. if you're living in the philippines,it's easy to find someone. you can save your lovely camera and lil money of course.
Jun 19, 2011 | Cameras
Cannon Speedlite 270EX doesn't turn on and I put new batteries in
Try cleaning out the contacts where the batteries touch. Make sure the battery door is completely flush with the body and see if you've inserted everything correctly. The type of battery you use also effects the flash recycle time and how it operates too. Have you tried using different types of batteries? Try using NI-MH instead of Alkaline and see if the speedlite will power. There's a test button on the flash and also an off-on switch you can try toggling around. The flash itself is very simple so if it still won't power on after all of that, you should contact customer support.
  • http://www.usa.canon.com/cusa/consumer/products/cameras/speedlite_flash_lineup/speedlite_270ex#ServiceAndSupport
May 17, 2011 | Canon Cameras
My camera wont stay on it bleeps once then turns off
That sounds like your battery could be dead/not hold a charge. If you've charged your battery already and your camera still won't stay off and turns off right away, it's time to purchase a new battery for your Samsung TL105.
You can purchase replacement batteries quite cheap here:
http://www.amazon.com/Samsung-Digital-Camera-BP70A-Battery/dp/B003OEDQBE
May 07, 2011 | Samsung TL 105 Digital Camera
Problem when starting up sony cybershot W55.
Your problem is mainly like above.
If you want to check the other troubleshootings please download the user manual of Sony Cyber-Shot DSC-W55
Feb 22, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Sanyo Xacti S650 Digital Camera Logo
42 people viewed this question
Top Sanyo Cameras Experts
ray gallant
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
