JVC HD-ILA (HD-55G456) Lamp has to be re-positioned everytime TV starts up
Hello everyone, i have had this TV for about 2 years and just replaced the lamp with a brand new one a month ago. i made sure its the correct lamp and it worked fine for a month.
Now every single time i boot the TV up it flashes error lights that the lamp is not positioned right, so i have to unscrew the lamp and put it back in and then it works fine. turn it off and next time i turn it on the same exact thing happens. this is driving me crazy, i have to do this daily...i make sure screw the screws down snug, but i've tried tighting them super tight, loose, supoer loose...its doesnt matter.
Anyone have problems like this before or maybe have a solution?? thanks!!!!
  • 3 more comments
  • Alkaholik Mar 30, 2008
    anyone?
  • Alkaholik Apr 02, 2008
    no one?
  • Alkaholik Apr 30, 2008
    ok, i found out the problem. Turns out i had a faulty bulb. Even though the bulb was out of the box new, it was faulty. I got a new one and BAM! no problems.
    Anyways that has this issue should look at getting a new bulb first reguardless if its old or new
  • Anonymous Nov 28, 2008
    Same issue as described. Replaced the lamp and now the error lights flash at start up.
  • Anonymous Dec 28, 2008
    How many times did you red light blink? Mine is blinking 8 times
Not the same problem, but I have the lamp light and power light blinking simultaneously and haven't figured out that one yet
Posted on Apr 29, 2008
After fixing a ballast lamp and color wheel how long would a tv last?
I have the same telly for the last six years and i only changed the lamp two weeks ago i think there a very good telly
Jan 20, 2013 | Samsung SP50L6HX 50" DLP HDTV
Problem with sony lcd projection tv kf-60we610 picture color changing
5 Years!!!! Wow...you guys must barely watch any TV for a lamp to last that long. Most people average every 2 Years or so. Just go out and buy a brand new lamp...Approx. $200 plus tax or so. Should solve your problem ;^)
But before you do... just in case... go into your TV Menu and reset your video setting to factory... its very easy to do on screen (no manual required). Cheers!
Nov 29, 2012 | Sony Grand WEGA KF60WE610 60" Rear...
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
We put in a new lamp probably a month or so ago. I'm not sure how to describe it except that some colors are now "brighter" than they should be and flicker while watching TV. This seems to have...
U replacing the tv with a new lamp with the original Toshiba reconmended lamp?Generic lamp might have this problems for some tv and don't last as long as the original name brand lamp.Also the board that call the Ballast board might be dying too.The Ballast board only job it is to ignite the tv projection lamp and kept it being lit.
Apr 07, 2011 | Toshiba 62HM95 62" DLP HDTV
Replaced the optical block a few years ago to correct the yellowish hue problem. Recently I had to replace the lamp. I had bought one new about 2 years ago. I put the lamp in and the TV is much dimmer than...
Lamps only last Between 5,000 hours some last 8,000 hours
So what that means For Every hour TV is Playing it is burning up hrs of lamp. These sets are not like projection that you can run day and night .
Most Lamps need replacing every 2 yrs Depending on how many hours you watch TV?
It could be that the Lamp you have is defective ,Mats has Lamps for $99.00 1-800-628-1118
Get New Lamp then see if that corrects the problem.
Sep 18, 2010 | Sony KDS-R50XBR1 50" HDTV
Screen going dark
Definitely. The lamp often looses oomph before it goes. Think about how long you have had your set. The average life seems to be around 2 years. Eventually your set will indicate the lamp needs replacing, if it hasn't already. I see your posting is about 6 months ago. Are you willing to verify for everyone else?
May 06, 2008 | Mitsubishi WD-57731 57" Projection HDTV
Sony Wega kdf-55wf655 rear projection set keeps turning on and off
If picture quality is poor, be sure you aligned the bulb in the correct manner and be sure the cover for the bulb is not loose. Also, you might want to re check you picture setting as it might have gotten reset when you pulled the plug (I hope you pulled the plug when replacing the bulb).
Heres another solution (maybe temporary) to the problem of no picture and no sound for 30 seconds. I had my tv's power saving setting on "standard" before. After I switched it to "reduced", the problem was fixed. It has been almost two weeks without the problem. I think its a good fix until the new bulb comes in the mail.
Jan 18, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Mitsubishi dlp does not get picture
the plug the connects underneath is not connecting right you have to get at the plug and seat it correctly
Dec 08, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Yellow light through center part of screen
You have a defective light engine and no matter what you personally do to the TV, it will not correct the problem. Hitachi is aware of this and you will need to call their customer relations department (not their customer service). Their Customer Relations Department # is 800-654-7013. When you first call them and tell them that you have a bad light engine,they will act like they've never heard of it but they will give you names of certified techs in your area. Once the tech comes out and confirms the problem, call Hitachi back, at the number I've listed above, and all of the sudden, they will know about the problem...imagine that! The will call and confirm the problem with the dealer and will ship a brand new light engine to the dealer to come out and install.
Here's the kicker...there's always a kicker. Hitachi will cover the part ($1500) but will ask you to cover the install. Our install cost us $400. This was worth it to us being that we paid $3600 for this TV 3 years ago and it's been a great TV up until we had the light engine issue. Once this part was replaced, the TV looks brand new. Again, everyone I've communicated with online has had the same or a very similar problema and have messed around with the TV on their own or bought a new bulb. This will not fix the problem. It is the light engine that will have to be replaced and Hitachi has been good about not giving to much of a hassle over it IF you have a certified tech come out and confirm it! Good Luck!
Oct 17, 2007 | Hitachi 60V500 60" Rear Projection...
Televison & Video Logo
870 people viewed this question
Top Televison & Video Experts
Electro Med Services...
