Question about Logitech Harmony 550 Remote Control
The power button is not responsive, have to press
The power button is not responsive have to press it down using a finger nails or for long period of time. Anyone else has a similar problem.
I have the same issue with my Harmony 550. Pressing the power button does not work immediately. I have to hold the power button down for about 1 minute then it works. This seems like a software issue and not electrical. I mean, why would holding for 1 minute work. Also it powers items on and off OK when using Activties. Here is what I did to get around it. I added a device to my remote that I do not have in my equipment. Then I added an activity to the remote call "Power Down". The only device on this activity was the new (non-existent) device. Therefore, when I select the "Power Down" activity all other devices (I have and are on) will shut down.
Posted on Jun 12, 2010
    Problem Solver:
  • 9 Answers
Has the remote been exposed to liquid? there may be residue under the pad that makes the electrical connection. If your feeling sure you can take it apart and clean the pad without harming the remote give it a try. I've seen a similar issue with a harmony that was stepped on which cracked parts inside of the remote. In either case it appears your problem is mechanical not software related.
Posted on May 11, 2010
How do you remove the battery from the hotspot elevate 4g?
Here are the steps you need to remove the battery from the Sierra Wireless Elevate 4G.
1. Remove the back cover.
A). To remove back cover, turn the Elevate 4G over.
B). Pressing down on the 4 bars on the left & right hand sides of the device cover push down and away from the power button.
2. With the back cover removed, turn the Elevate 4G so the power button is facing towards you with the battery side visible and facing up.
3. Press along the long edge of the battery, if you do not have finger nails, this will be more difficult. But press the battery towards the 4 gold receptors (towards the power button or press towards you) while lifting up up on the battery. This will release the edge of the battery that is opposite the power button.
4. Once the far edge of the battery has been lifted, slide it away from the 4 gold connectors and the battery will be free.
Nov 29, 2012 | Sierra Wireless At&t Mibile Hotspot...
Tip
HOW TO REMOVE ACER ASPIRE 5710G KEYBOARD
These are the things you will need for this task.............
1 x small philips screw driver,
1 x flat blade screw driver or you can use your finger nails
Clear a flat table or work space,to do the job on.
About 10 min to spare time to complete the job,
FIRST remove AC power pack & battery.
Then turn the laptop upside down & remove x 3 small M2.5x4 screws
Now turn the laptop upright,with your LCD uppermost.
Now use your finger nails or a flat blade screw driver,
To lift and separate the edges of your POWER ON button cover from the base,(I prefer nails because they leave NO scratch marks behind),
Working all the way around from the hinges to the sides eventually ending up by your keyboard,
Lift and remove the cover from that area now exposing the underside of the POWER button and the Speakers will be visible now too.
Now place your finger nails underneath keyboard edge,
Around the center of the keyboard where the power area is,
Gently lift and flex the keyboard so it bows in the middle ,
Now side keyboard one way to the side,left or right,
releasing the little finger that holds the keyboard onto the base of the laptop,
Slide the keyboard in the opposite direction to now free the keyboard,
Lie the keyboard flat on its keys so you can unplug the ribbon now.
You have now successfully removed your keyboard.Congradulations.
Hope this helps,I was going to take photos but i dont think its needed.
Cheers and thanks for reading,Hope this helps everyone,MISTERDJ
on Apr 28, 2010 | Computers & Internet
Have Garmin nuvi 1200 that will not turn on. Was working good stopped for a cup of coffe then would not turn on. Tried with car power and battery power.
You may need to reset the unit by pressing and holding the power button until it reboots.
You can also reset user data by holding your finger on the lower right corner of the screen whilst powering up the unit at the same time.
Keep your finger pressed until a pop up window appears. Touch YES to clear all data and return to factory settings.
If this dont work the try below
Carefully pry off the thin frame around the screen using your fingernail. If you look carefully you will see a little finger nail notch. Under that frame on the right side towards the corner is a reset button. Push it and it should fix your problem.
Jan 27, 2011 | Garmin GPS
How do you replace batteries in freshair remote control . i cant get the back off the remote control.
For the Fresh Air 2.0 or 2.1 remote, its oval shaped.
1. Hold the remote so that that the power button is facing up.
2. Then flip the remote in your hand so you can see the back side.
3. Then with your other hand, side your index finger from the top down the back side of the remote until you finger nail catches the a slot (about an inch from the top of the remote). Right below that slot, is a plastic tab that secures the battery cover. Using your finger nail, pull that tab down about 1/16" away from the remote to unlatch the cover.
4. Lift the cover off the remote, and you should see 2 AAA batteries. Remove the old batteries and replace with 2 new batteries.
5. Align the two tabs on the battery cover into slots on the back of the remote.
6. Gently press the back cover and the latching tab should shap into the remote.
Hope this helps.
Jun 14, 2010 | Ecoquest Fresh Air Air Purifier
I have a cordless nailer but it stop firing or driving the nails not even with a full charge battery
cordless nail guns are very hesitent,they require you to hold safety down on surface with finger on trigger for a period until charge is built up,not the best for big jobs if ur in a hurry.
Oct 01, 2009 | Air Tools & Compressors
About the rust in the silver coated part of the bike
Use Mothers Chrome Polish to get the Rust back down to the Tiny Speck that Started it and Use Clear Finger Nail Polish on the Tiny Spots that cause the Rust and it will stop it. You will need to Replace the Nail Polish every Now and then. Please Rate My Response! Thanks!
Feb 06, 2009 | 2001 Hyundai XG300
DS will not move past aura selection.
Keep ur thumb or stylus COMPLETELY still and DO NOT BREATHE the microphone will sense if u do and make u wait longer it took me a while 2 figure that out
Dec 25, 2008 | Pokemon Mystery Dungeon : Explorers of...
How do you change a battery on the Nokia 7360?
Battery for Nokia 7360 like most phone is at the back...
you got to remove the back panel (back frame) of the phone yo get the battery.. At bottom of the phone above the hands free slot and hole for charger, there is a rectangular shaped button with the provision for your finger nail (preferably thumb) to go in. By holding your phone upside down (camera side facing you) just press the button using your nails and pushing the phone towards you. This should free the bottom lock (the back panel comes off a bit creating a small gap). You can free the side lock by moving your finger nail through the gap to the side. This should free the back panel completely from the phone. You can find the battery of the phone there. If you are removing the back panel for the first time, the locks would be a bit tight!!!
Hope this solution helped...
Dont forget to rate the solution!!!
Fixya!!
Sep 09, 2008 | Nokia 7360 Cellular Phone
Screen Stuck
The Samsung YP-F1 has a reset button located under the black Samsung cover plate. It can be gently removed via a finger nail or mini flat blade screwdriver. Once plate is removed a hole labeled reset will be seen. Use something like a paper clip and press in. MP3 will power down/reset. MP3 data is also retained after reset.
Nov 03, 2007 | Samsung Yepp YP-F1X MP3 Player
Need code or code search proceedure for Advent RC-S11-0A remote
Most Universals work similar for code search, try this on yours. [list] [1] Manually turn on the device (eg TV) [2] Press & hold Code button until indicator light stays on (or blinks on some) release Search button. [3] Press & release device button (eg TV). The indicator should blink off. [4] Point Remote at device (eg TV). [5] Press the Power button on/off down until the device turns off. [6] Press the ENTER button or OK button to save the code as soon as the device shuts off. (Suggest you have a finger on it for fast response.) Hope this works for you.
May 12, 2007 | Recoton Advent Advent RCS110A Remote...
Logitech Harmony 550 Remote Control Logo
395 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
cwradio73
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
