Question about JBL CREATUREIIWHITE Computer Speakers
HELP ! No/limited volume from satellite speakers
Hi guys - I'm hoping you can help me with a sound problem with my speakers. They were working fine until I unplugged my PC (a MAC) to move it and then set it back up again.
The lights on the main unit and both satellite speakers are on but there is no volume at all coming from one speaker, and only faintly from another. I have made sure that all of the leads are 'snapped' securely in. I have also checked the balance levels on my PC. Neither has solved the problem.
I would be really grateful if you could offer any suggestions as to how to cure the problem.
Many thanks!
Catherine
    Genius:
  • 3,422 Answers
HI,
Are the speaker jacks plugged in completely and in the right hole(s)?
Check if
everything is connected properly, power supply, speakers to pc, and all the other wires are connected properly.
Test your speakers on another computer, if they work it's your soundcard.You will need to uninstall the sound drivers and then reinstall them back.
If the power supply gets "hot and smelly" that is already a viscious sign to me.
Like you said everything worked out fine before you moved.
So, something must have got broken down during the move, it's only to find out what.
You could try using another speaker set on your PC if this works then the problem is with the one of the components of the integrated amplifier or the 12V power-supply. don't go try to mess with components inside if you're not familiar with electronics.The only solution will be to buy an new set of speakers and use it or buy a new power supply pack.
Goodluck,
Please don't forget to rate the solution.
Posted on Mar 28, 2008
  • 818 Answers
1. Make sure all wall and power outlet switches are on and that all switches for your speaker system are on. Cycle the power switch.(switch is located on the back of the subwoofer) Check power LED on left and right speakers. Is the LED on? If not, power is not getting to your speaker system. Make sure the power cord is plugged into an electrical outlet. 2. Ensure that the speaker input jack is pushed all the way into the appropriate jack. Check all the connections and secure them. 3. Check the connection to the soundcard. Make sure it is connected to the proper jack. This varies from each soundcard manufacturer. (Please refer to your soundcard manual.) 4. Your volume settings are too low or muted. Increase your volume by pressing the + key located on top of the right satellite. You can also check your volume through the volume control located in the taskbar. To mute and unmute the speakers, press the + and - controls at the same time.
the part that is for your problem
This is an indication that the satellite speakers are not plugged in all the way to the subwoofer. You will hear a slight "snap" sound if they are plugged in all the way. The inputs are color coded and shape coded (triangle and square). Make sure they are aligned properly.
Low to no sound on Media Mate satellite speaker. How to troubleshoot. Powered speaker works fine. Limited volume on accessory speaker. Already tried swapping cables and tried on another system. Same...
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Aug 05, 2011 | Bose MediaMate Computer Speakers
3 out of 4 of my satellite speakers are not working. All the speakers work through the remaining working satellite port when switched. What should I do?
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Feb 04, 2011 | Logitech Z-560 Computer Speakers
About 2 years ago, my computer kept getting the blue screen of death, so i took it to some guy to have him restore it. I had Harmon Kardon HK206 Computer Speakers while this was happening. We got it back...
control panel,administrive tools computer management,device manager,sound video controllers you should see yellow? right click reinstall drivers
hope this helps
Aug 10, 2010 | Harman Kardon HK206 Computer Speakers
Creature III brand new faint sound!
Check out here:http://www.fixya.com/support/t3604714-jbl_creature_speakers
Jan 10, 2010 | JBL CREATURE II Computer Speakers
No sound from Toshiba A200 speakers
check the volume control, bottom right, in the notification area,
double click the icon, and raise it.
Or, Go to,
Start, control panel, sounds, double click on speakers, check it's enabled,
Or,
start, in search box, type run, in run box type DXDIAG,
enter the test area, test your sound in here.
should say no problems,
check connections to speaker are all good, if external.
Hope this helps.
Regards
Apr 08, 2009 | Toshiba Satellite Pro A210-EZ2202X...
Satellite 5205-s505 speakers aren't working, headphones OK.
Start- Control panel- Sounds and Audio Devices- In the device volume section click Advanced- Click Advanced again and check if In the other controls section 1 PC Spk mute is checked if so uncheck it If that does not work please let me know so I can help you further
Dec 09, 2008 | Toshiba Satellite 5205-S503 Notebook
My Toshiba Satellite has a sounds problem
Make sure your volume controls are not muted and levels are midway.
Right Click on Speaker icon in lower right system tray and choose Open Volume Controls.
Nov 24, 2008 | Toshiba Satellite A100-S8111TD Notebook
No sound from Creative Labs Speakers- Please help
to localised your problem, try to plug your speakers to other sound source like mp3 player ,stereo system. if still no sound coming from it,your problem is within the speaker system. perhaps the audio power amplifier ic inside, need to be replaced.
Oct 12, 2008 | Logitech X-530 Computer Speakers
HARMAN/KARDON SOUNDSTICKS 2 NO SOUND
I MISSED THE VOLUME CONTROL ON THE RIGHT SPEAKER. NOT OBVIOUS FROM VOLUME. THE SOLUTION FOR ME. THANKS.
Jan 20, 2007 | Harman Kardon SoundSticks II Computer...
Left speaker not working
Hi Dellhelp, this sounds like a defective volume switch to me. If you're handy with tools and have a soldering iron you can probably pick up a suitable replacement switch for $5 and spend 30 minutes installing it. Or for around $20 on Ebay you could buy another working unit. I wouldn't really recommend spending much time or money trying to fix them and if you do buy another set you can keep your old ones for parts :) http://search.ebay.com/search/search.dll?cgiurl=http%3A%2F%2Fcgi.ebay.com%2Fws%2F&fkr=1&from=R8&satitle=hk395+speakers&category0=&submitSearch=Search Let us know if you need more help and don't forget to rate the posting.
Jan 05, 2007 | Dell HK395 Computer Speakers
JBL CREATUREIIWHITE Computer Speakers Logo
232 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
