Question about Hitachi 43UWX10B 43" Rear Projection Television
Return resistors Where can I buy these return resistors, how much should they cost?
    Genius:
  • 1,153 Answers
Do you know the size? if so then vancebaldwin.com
Posted on Mar 28, 2008
Is there a way to buypass the passlock on a 98 gmc
You can take a resistance measurement of the ignition key/chip with an ohm meter. When you get the resistance measurement, you can buy a resistor of the same resistance/close resistance ( a bag of resistors cost 5 bucks ) at the source/radio shack and cut the wire from the ignition switch and install the resistor. The passlock system will be fooled into thinking the key is being used. Takes a bit of time but works
Oct 04, 2015 | GMC Cars & Trucks
2004 Pontiac Vibe Air blower work only on high
Replace blower motor ,the motor perhaps is worn and making resistance heating up the resistor
Dec 26, 2014 | 2004 Pontiac Vibe
2004 Chrysler Pacifica Blower won't work
Usally when a blower motor resistor goes bad the fan still runs on high. The resistor lowers the voltage going to the fan to make it run slower. The high setting usually goes straight thru. Resistors are usually easy to get to, under good on the firewall or under dash passenger side. Cost about $24 at parts store. Replace with new if that doesn't work return it.
Aug 29, 2012 | 2004 Chrysler Pacifica
This is one of six CKS3029s I bought five years ago for our retirement community. This one just stopped working, no light, no radio, nada. S/N 40628179PH. What to do?
My suggestion is to buy a new Clock Radio to replace the one that quit, they are cheap and unless you want to take it apart and service it yourself the cost to fix it would buy a new one.
If you do decide to take it apart then you want to look for burnt resistors on the electronic boards inside the unit. A resistor can be lots of sizes and can be many shapes but just look for a burn on or around all electrical components.
6_20_2011_2_42_15_pm.jpgThis image Shows a resistor slightly burnt out but burnt nevertheless
6_20_2011_2_44_19_pm.jpgThis image shows a seriously burnt resistor
Jun 20, 2011 | Emerson CKS3029 Clock Radio
What are the color codes for the iat sensor on a 2008 chevy vortec 5.3
The color codes are tan and a tan/black. There are 2 wires that go into the mass air flow sensor, fyi dont buy or put a resistor in this spot, it tells your engine its getting colder air than it actually is and doesnt help anything. If you buy it you will decide to return it, but then you just lost on shipping cost, and a resistor is about a dime in cost.
Dec 19, 2010 | 2008 Chevrolet Silverado 1500 2WD
Blower motor does not operate at any speed,will not work at all when switch is turned on. Fuses look fine.Thank you
Try replacing the fan resistor they are about $40.00. The resistor is located on the side ( usually the underside ) of the heater box under dash below the glove box.
Dec 29, 2009 | 1993 Nissan Altima
Panasonic 51 " projection big screen.[ May 2001]. Convergence chips have gone. Can this be fixed and if so what would it cost for new chips?
A projection Tv convergence amps can be fixed/replaced and a competent tech will also test the yoke return resistors as well as various other components. The amps themselves are about $20.00 a piece (usually two in the circuit) depending on where they're pruchased. I suggest ACME out of Florida - only because it's real easy to buy fakes. Get only Sanyo originals and to do that you need to make sure they're purchased from a reputable supplier.
Good Luck!
William Rayburn, CET
Premium Technologies
Oct 05, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Schematic (or just R10) for Rampage AMP522A Car Audio Amplifier
2 years later... I just picked one of these up at a yard sale... R10 is actually a diode. The code is buried, but ends in N1.
Hope this helps!
Sep 14, 2008 | Audiovox AMP522A Car Audio Amplifier
Help follow-up
scott737,
There is no kit for your repair.If your original IC's = STK392-110...
quality Sanyo-made will cost you $14.00 - $16.00 each.If you buy Panasonic packaged IC's,the part # is C5AA00000203 and they cost about $30.00 each. Use an ohm meter,your eyes and nose to locate burned resistor(s).Usually one or two 6.8 ohm
1 watt light blue color a total of twelve, I think.....However,your next step is to order / purchase first grade IC's = Panasonic is going to be your best choice.........and some 6.8 ohm 1 watt
resistors.....
Terry.
Aug 12, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Convergence
The 1.2 ohm resistors should have the rating stamped on the resistors themselves. But if you would like the service manual I can post a link where you can buy one and get free unlimited tech support with the manual purchase
Apr 09, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Hitachi 43UWX10B 43" Rear Projection Television Logo
23 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
