Question about Water Heaters
Why do we connect the switch only for live wires?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 221 Answers
I assume you are referring to AC wiring? If so, there is no need to break the circuit for neutral or ground. Only need to break the power (line) to switch the device on or off.
Posted on May 11, 2010
How much is a lid switch for a whirpool washer
Depending on model there not much, I usually hot wire mine..just take the switch off and connect the wires together with a wire nut...
Apr 03, 2014 | Whirlpool Whirpool 3.5cu ft Top Load...
At electrical connection, from 120 ac on, off switch which remote controll connection terminial ...T1 or T2 does the black hot wire and the white neutral wire connect to ???? manuel does not show
On this unit it does not matter because it is a restive load usually I would go black t1 and white t2 it should be L1 and N always unplug before working on it
Dec 01, 2013 | Rinnai 7.5 Gpm Gas Tankless Water Heater -...
How do i install mechanical time switch
There should be 4 connections maybe 5
2 are for motor(phase and neutral) possibly labelled M. 3 other contacts will be C common NC normally closed and NO normally open.Connect your live wire to one M terminal then loop it to the C terminal. Connect wire to load or appliance to NO
Oct 17, 2012 | GE 24-Hour Mechanical Time Switch
Water heater timer not working or bad wiring?
10/15/2012
Hi Liz.
This is a live answer. And you can add a comment after trying following step, and I will comment back..
Replace battery, and then reset the timer using reset button located to left of display screen.
http://waterheatertimer.org/pdf/eh40-english.pdf
Oct 15, 2012 | Intermatic EH40 - Electronic Water Heater...
I have an Atwood G6A-8E (gas only with DSI switch), the DSI light doesn't come on the and the water heater will not ignite.I have checked the battery, changed the gas.what should I do next?
Check for a bad fuse in panel first, then with a 12 volt test light or multimeter, check for power in to switch, as well as out when in on position if it's easy to get to. If not, turn switch on and test for voltage at brown wire to thermostat terminal, that comes from inside at back of water heater from switch inside. If it has cut-out switch in plastic sleeve attached, be sure to check for power on both ends of that cut-out switch. If power only in but not out, replace it. As I said,that brown wire comes from switch, so if no power to it, check at switch. The other brown wire goes back to connector on ignition board. If power is there, turn switch off, take an eraser on end of a pencil and rub contacts on ignition board/module to clean them off, as well as spray electrical cleaner on contacts of connector to make sure you have a good connection. Check all ground connections as well, and if you have 12 volts at brown wire to connector on ignition board but still no spark, replace ignition board/module.
Sep 14, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
I have an Intermatic WH-40 timer set up on swimming pool pump. I am not using any start/stop mechanical pieces on the dial face. Yet my pump does shut off everyday for short time period. Why is this...
Sounds like pump issue or loose wire and not the timer.
Check wiring at pump. Read pump manual. The pump may have overheat cycle that trips off and then comes back on to protect pump without requiring owner to press reset button each time.
If timer turns OFF, then the manual override lever moves to the off position, and when timer turns ON again, the override lever moves to the on position. If override lever is moving without a tripper, then I would like to know more about that. Add a comment with photo posted on Flickr.
Same with the circuit breaker. The circuit breaker switch does not trip and reset once a day.
A loose wire could cause occasional connect-reconnect.
Check terminals inside timer for signs of high heat and burning. Check that insulated part of wire is not under the screw-down-plate.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html#plate
Check circuit breaker for signs of burning and smell of electrical burning and sound of shorting on the busbar.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 31, 2011 | Intermatic WH40 - Water Heater Time Switch...
Circuit breaker trips frequently. It is a double 20 amp switch.
Is this breaker connected to water heater?
1) A double 20 amp breaker is called a 240Volt breaker.
20 amp breaker is actually rated for 16 amps for safety margin.
It is also important that this breaker have 12 gauge wire which is color-coded yellow.
Look at label on side of water heater for wattage of unit.
2) For example 4500 Watt water heater is typical.
4500 watts divided by 240Volts = 18.75 amps which is nearly full capacity for the 20 amp breaker, and is slightly above the safety margin.
http://waterheatertimer.org/B220C.html
3) If breaker is getting old, and it works at full load each time water heater is on, it can wear out.
Open circuit breaker box and replace breaker:
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
4) You can also move circuit breaker wire to another same-size breaker and see if problem continues.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Mar 02, 2011 | RELIANCE ELECTRIC WATER HEATER
I have an intermatic WH40 timer that works great when it is "On". However, once the unit encounters the "Off tripper", it turns the hot water power off, but the timer dial no longer...
If this is new installation, you have Load wires and Breaker wires reversed.
http://waterheatertimer.org/How-to-wire-WH40.html
http://waterheatertimer.org/images/WH40-water-heater-circuit-5.jpg
Hot wires from breaker connect to terminals 1 and 3 ... notice also there are small white wires connected to terminals 1 and 3.
Small white wires go to 240Volt clock motor located on back of mechanism, so these terminals have to be Hot all the time so clock motor is ON all the time >> thus hot wires from breaker connect to same terminals that have small white wires.
Load wires to water heater connect to terminals 2 and 4
Reverse your wires and things should work fine.
Dec 05, 2010 | Intermatic WH40 - Water Heater Time Switch...
Replacing older t86 two wire thermostataà
brown goes to live black to nutral green to earth
Nov 14, 2009 | RTO Home Heating Products 5.5HH240...
Water Heaters Logo
27 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
