Question about First Act Discovery Junior Accordian FA107
It is broken. Someone used it without holding down a button which causes damage. Is it fixable (by me)?
It is fixable by you ..if you are somewhat of a model builder and a craftsmen. Here is what you need to do:
1st. Find out if whats loose is in the bellows part, by stretching it all the way apart. If it is then carefully let it come back together.
2ed. Get an exact o knife and cut the bellows away from the key end TRY and JUST CUT the GLUE. It comes apart slowly don't rush it.
3rd. Examine the loose parts and make any repairs
4th. Replace and affix the loose part in the same manor it was attached ,if glued apply glue and clamp for 12 hours or what ever the glue you use suggests.
5th. Apply a thin but ample line of glue around key end and replace the bellows to original position. Be sure and wipe away any excess glue ASAP now camp or rubber band tightly and let glue dry thoroughly.
That is how I did it and it works fine.
Posted on Sep 28, 2012
2 Suggested Answers
SOURCE: it is broken. someone used it without holding down
licence
Posted on Mar 17, 2010
Machine suddenly shuts off during playback or record - is this fixable?
When something goes wrong during playback etc, all VCR's will shut down to prevent tape damage, or further mechanical damage.
There are two possible causes for this problem. One is there is some sort of damage to the mechanism, possible a plastic part that is broken. The second cause is the mode switch. This tells the electronics what position the mechanism is in. If that goes wrong the electronics might think it is in eject mode when it's in playback, for example, with things going very wrongs as a result. All are fixable if you can get the parts!
May 02, 2016 | Toshiba Televison & Video
I have a Tevion 7.1 amplifier (AVR 2006). Protect overload flashes up and then shuts down. I have only had limited use since I had the unit from new (a few days). Last time using it someone pluged an...
The protect indication is due to a overload on the power amplifier unit. So you need to check the speakers to see that they are not shorted. remove all the speaker lines and switch on.
if there is a processor reset, power off the set and switch on while holding the selector/standy by switch. if not there is damage in the output within the amplifier.
Apr 26, 2011 | Audio Players & Recorders
I can't hear the person talking on the phone earpiece. The volume is on high and the speaker phone works fine?
Sir/Maam,
It can be that the earpiece is broken. Try calling someone without using any earpiece, if that works that proves the earpiece is damaged or broken.
If that doesn't work, then the speaker in your phone must be damaged.
Hope i helped you, thanks.
Feb 27, 2010 | Cell Phones
Clutch clicks into gear but theres no movement
This can be difficult to answer properly without a bit of knowledge on operation. If you can get it into gear with the motor running then clutch should be working.With that said, on to why it doesn't move acn be several things. Axle dislodged from transmission or broken CV joint, input shaft to clutch ana pressure plate damaged in some way,differential damage, shifter broken off internaly or broken cable, < should be able to feel this >. inspect axles to confirm they are not damaged or dislodged, inspect shifter to confirm it is operating like it should, < have someone move shifter and watch arm on transmission to confirm it is operating > at this point if you haven't found anything to have failed then would suggest having it looked at by someone who can tell you what cause is. I am not implying that the clutch has no damage to it,but other reasons can be cause. There is an inspection plate on bottom side of bell housing that can be removed to inspect for damage, < where engine and transmission connect>.
Apr 25, 2009 | 1997 Honda Civic
Technika 7" Portable DVD player
LCD panels are generally not fixable. If it's a deep crack, and leaking pixles, its a problem. If its not, it should continue working. If it's leaking, or not working right If you have some technical skills, check eBay and see if someone is selling a used one or, even better, a replacement screen. If you can't do it yourself, hopefully you know someone who could replace it. Of course, as cheap as these are, it may be easier to trash it and get a new one.
Dec 18, 2008 | Nokia 6288 Cellular Phone
Reseting lamp light
If you are in the service menu (by holding down "Enter" on the TV and "Mute" on the remote simultaneously for about 5 seconds) - use the right arrow on the remote to reset the lamp time, and then hit the round button on the remote - the one between the arrows that has a "bulls eye" on it. That did it for me.
Jun 01, 2008 | Zenith E44W46LCD 44" Rear Projection...
I have a Honeywell oscillating quiet cooling tower fan that was bought two years ago. Loved it, till yesterday it just stopped working. the oscillating feature still moves, but the fan does nothing. the...
Could be fixable but until someone determines the problem there is no way of knowing if it is fixable. Could be a broken wire between the selector switch and the motor or the motor itself could be bad.
When you are trying to operate it does the fan motor get warm or hot? Does the fan turn freely?
May 03, 2008 | Heating & Cooling
Sony Viao, won't power up
Sir,
you remove your Laptop main battery and adaptor for aprox 10 min then fix again battery and adaptor then on power button m/c is on.
Mar 06, 2008 | Sony MBX-49 ASSY Motherboard
Focus
This camera has TTl auto focus so it can't be switched to manual so that idea is quickly stomped on. A silly question, are you half pushing the shoot button down first to activate the auto focus. If you don't and just hit the shoot button you'll definitely get out of focus shots. Have you sat down and read the manual on how to correctly focus. A number of things can crop up which can fool the autofocus into a wrong setting. Have you dropped the camera or has someone else done so? The lens assembly could be damaged. Try pointing the camera at something about three feet away whilst half pushing the shoot button then still holding the button half way point the camera at something a long way off. Can you hear the mechanism trying to focus and does the picture in the LCD change. If it's all quiet and the picture doesn't change then it could be a damaged focus motor or a connection to it is broken. Are you sure the camera isn't switched to Macro. A lot of people get caught with that one. You'll never shoot a focussed picture in macro unless it's less than a foot or so away. BMW
May 31, 2006 | Samsung Digimax A400 Digital Camera
First Act Discovery Junior Accordian FA107 Logo
59 people viewed this question
Top First Act Toys Experts
ray gallant
Are you a First Act Toy Expert? Answer questions, earn points and help others
