Question about Samsung RS2556 Side by Side Refrigerator
I have a Samsung RS2556WW refriferator. The refrigerator temp is too warm about 50 degrees. Repair man came and replaced the main circuit board DA41-00104M. After 2 days the temperature shows 40 degrees but the actual temp is 50. The freezer is also getting warm at 30.
    Problem Solver:
  • 8 Answers
Which temperature is set the refrigerator and freezer you still have the old pbc (main board)
Posted on Aug 29, 2010
  • piresdivino May 21, 2011
    I have a samsung Refrigerator model No. RS2556ww,water dispenser does not work.
    ,i need help about
GE PTS25LHR refrigerator temp at 50 degrees
You need to replace the mother board located on the outside rear wall
Jul 25, 2012 | GE Refrigerators
I have a samsung model # RS2556WW. AND IT WILL NOT DUMP ICE.
Had a similiar problem with my Samsung side by side. It may be the bracket that holds the ice tray. The back part that holds the tray in place - or - the pivot in the back on mine was broken. If your ice tray has movement in the rear - check this part: http://www.repairclinic.com/SSPartDetail.aspx?s=t-RS2556ww-%3d%3dc10i1467760&PartID=1467760 ... $15 and a few screws ... good luck!
Sep 30, 2010 | Samsung RS2556 Side by Side Refrigerator
Freezer is cold, fridge is warm; replaced main board already
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Apr 25, 2010 | GE 19.5 Cu. Ft. Bottom-Mount Refrigerator...
Ice build up in freezer and temp in fridge section not very cold
just needs to be defrosted ice is blocking the vent for the bottom defrost it and should be good
Aug 28, 2009 | Samsung RF265AA Bottom Freezer French Door...
My light works but the motor won't kick on, Frigidair top freezer
THE CURCUIT BOARD IS NOT SENDING A SIGNAL TO YOUR MOTOR WHICH ENABLES YOUR MOTOR TO KEEP THE VALUBLE CONTENTS IN YOUR FRIDGE COLD...(BEER) EVERY MANS FAVOURITE HOBBY...CHECK YOUR CIRCUIT BOARD FOR CORROSION OR DAMAGE...HOPE THIS HELPS...IF SO SEND ME A COLD ONE
Dec 13, 2008 | Frigidaire FRS3R5EMB Side by Side...
Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
Electonic Temperature Control
Jackie, the only other thing that could be wrong is the thermistor sending the wrong info to the board. Why don't you have the technician come back out and ohm out the thermistor values, they could be off. I have seen some models where the thermistor is pushed too far into the insulation giving a false reading. Catriver..post back
Jan 22, 2007 | Samsung RB1955VQ Bottom Freezer...
Samsung RS2556 Side by Side Refrigerator Logo
430 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
