Question about Panasonic CQ-C1101U CD Player
Fuse blows when I connect to original power source
Turned on my ac (89 Jetta) Deck (CQ-C1101U) went dead (blown fuse). Each time I replace the fuse and hook it up to power the fuse blows immediately. Nothing else in the car is fried and all car fuses are good.
  • 86 Answers
You have a bad ground check the ground on the radio the black wire.write back if you need further help.
Posted on May 11, 2010
Why does Fuse #28 keep blowing
Whatever the fuse is connected to is Hooked up wrong and it is creating a short which blows the fuse! Good luck
May 27, 2013 | 1999 Lincoln Continental
Ignition fuse keep blowing in my 2003 cavalier
u have a dead short on main live wire check for overheated wires
Jul 10, 2012 | 2003 Chevrolet Cavalier
Blown main ac fuse
a FEW ways this happens.
If fuse blows instantly when set plugged into power either a generic fuse (lots of these fuses are special and a generic will pop for no reason) or a dead short on the primary side of the power supply.
If fuse blows instantly when turned on a short either in secondary side of power supply or something it feeds.
First to try is get the exact fuse used (buy a pair) and see what happens.
beyond that if secondary side (when set is turned on) have an expert look at the set.
Apr 29, 2012 | Televison & Video
Black screen no video no audio suddenly now
This set is a 50" plasma. first check the AC power fuse on the filter board then: if it is bad: check the power supply by marking and, removing all the cables; (so you can put them back in the correct spot) except the filter board to power supply cable; that connects to the Power supply board. Then: replace the blown AC fuse and, re-power: If the power supply blows the fuse: again, the power supply is bad and, must be replaced or, repaired. If the fuse does not blow: turn off the set then: on again, reconnecting and, disconnecting each board cable in turn, untill the fuse blows again this cable leads to the bad board; replace or, repair the board that blows the AC fuse every time the bad board is connected, irregardless of which other cable to the power supply may be connected also; or, not.
Jun 05, 2010 | Toshiba 50HP66 50 in. Plasma Television
2002 Jetta Dead radio
Yes it could be a blown fuse most of the time but check the fuse marked radio in the fuse box
Mar 06, 2010 | 2002 Volkswagen Jetta TDI
Replaced battery and then radio went dead.
Plug the radio into an alternative power source? Try another fuse?
Feb 19, 2010 | 2005 Nissan Altima
2000 vw Jetta AC keeps blowing a fuse when
you have a short somewhere, cant help ya there, theres no telling where its at
Jul 02, 2009 | 2001 Volkswagen Jetta TDI
Starter fuse under the hood keeps blowing....the factory deck was replaced by a new deck...every since then the ignition fuse keeps blowing..
the new radio install is causing this if the power was taped into the starter system. rec. removing wires then try to see if you can blow your starter fuse
Jun 01, 2009 | Car Audio & Video
No power to tv when i plug it in. don't know if all the way dead way to check it?
I really need the make and model number to help you.
My understanding of what you have said is that there is no standby light and no clicking sounds when you power on your unit. If this is true regardless of what type of tv it is there is a fair chance that the main ac line fuse is blown.
To determine if the line fuse is blown, remove the rear cover panel and follow the ac power cord to where it connects to the circuit board. The ac fuse is a small glass cylinder, about a half inch long. Replace the fuse with the same amperage and ignore the voltage rating. If the new fuse blows as well, your looking at involved circuit work which should be referred to an experienced repair technician.
Apr 29, 2009 | Televison & Video
No power
1. Check that the AC outlet is working.
2. Check that the AC power cord is ok with no damage.
3. Unplug the unit, remove the cover and check for a blown fuse.
If blown, replace with a value that is the EXACT value as the original.
4. If the fuse blows again or the unit is still dead, you most likely have a problem in the power supply section.
In that case, you'll need to take it to be serviced.
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Mar 19, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Panasonic CQ-C1101U CD Player Logo
102 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
