Question about Microsoft Windows Media Player
I've already installed windows media player , but
I've already installed windows media player but now i want to uninstall / cancell it . Can you please help me ? mine is a windows xp desktop computer.
rockitman187
  • 2559 Answers
SOURCE: Windows Media Player 10
You can not play WMV or ASF media on a website with Internet Explorer's Media Bar turned on. Internet Explorer has its own player for the Media Bar. To get around the c00d11cd error being generated you need to turn the Media Bar off. To disable Internet Explorer's (version 6) Media Bar click the Media button on the main Toolbar, then click "Media Options" in the new pane that opens. Now select "settings", and then un check "Play web media in the bar".
There is no need to restart your machine as this will take effect immediately.
You have a "playlist" on your PC that you are trying to copy to a CD-R. When you hit the copy button it goes straight to the c00d11cd error!
The most likely cause is DRM. Check the songs on your "playlist" to see if any of the content protected. To do this simply "right click" on each song, then select the "license tab". If any of the songs are protected then you can NOT copy them without the appropriate DRM authority. (DRM = Digital Rights Management) You will need to check with the site you purchased from to see the level of DRM used.
You have a "playlist" on your PC that you are trying to copy to another computer. When you try and play on the new computer it goes straight to the c00d11cd error!
The most likely cause is DRM. (DRM = Digital Rights Management)
It is likely you purchased and downloaded from a site Like Walmart.com Online stores like these set restrictions on what you can do with the .WMA files you download. It is likely that the DRM licence for your download restricts you copying to another PC. You will need to check with the site you purchased from to see the level of DRM used.
You can not copy songs from a CD in the CD drive to your hard disk. Windows Media Player generates the c00d11cd error.
The most likely cause is that something has gone wrong with the special file responsible for the "encoding". The name of the file is: wmadmoe.dll
The first thing we need to do is re-register this file with Windows XP To do this go to the "Start Menu" and select "Run". Now type in the following: regsvr32 wmadmoe.dll
If this does not work then the file itself may be corrupt. To fix this go to the "Start Menu" again and select "Run". Now type in the following: sfc /scannow
This will now scan your XP machine to see if there are any corrupt system files. If there are any then XP will prompt you for the XP CD so it can get a new copy... This may help you resolve the c00d11cd error.
This will get you up and running again, however due to some underlying problems with your installation you may actually need to re-install Windows Media Player.
Please rate this fixya
Posted on Jan 25, 2009
Sea Breeze
  • 4655 Answers
SOURCE: MPEG FILES WHICH USE TO PLAY IN WINDOWS MEDIA
Try updating to windows media player 10. link below.
http://www.microsoft.com/windows/windowsmedia/player/10/default.aspx
Posted on Jun 28, 2009
leecom72
  • 4806 Answers
SOURCE: unable to stream video on classic media player,vlc
You probably need to install divx codecs too.
Download & install divx codecs from here and restart your computer to see if the videos play>>>>>>>>>
http://www.divx.com/en/products/software/windows/divx
Regards.
Posted on Sep 22, 2009
  • 98 Answers
SOURCE: windows media player wont work
this seems to be a codec error yyou could upgrade uoyr wmplayer to11 or look at microsoft.com or www.divx.com has a very good codec package
Posted on Dec 18, 2009
  • 343 Answers
SOURCE: My window media player 9
I would suggest trying to install the latest version of windows media player,but if you are at work it may not be possible. Most companies try to block their employees from doing this at work. Thanks for using FixYa
Posted on May 13, 2011
Windows media player error - "not installed properly and must be reinstalled. Do you want to intall the player from the Microsoft Website?" Media player 11 with Windows XP sp3
you will not be able to upgrade window media only goes to 10 for windows xp. if you are having problems with playback then there are video and audio code packs for windows media that are updated and free.
May 29, 2017 | Microsoft Audio Players & Recorders
I can't my samsung yp-u2j in my pc an i already
You need to upgrade your player’s firmware if you experience any of the following:
  • When your attempt to use the player, the Found New Hardware bubble appears and then flashes between several messages including MTP Connected, Don't Disconnect, MTP Device found, MTP Device may not work properly, or There was a problem during installation.
  • The player constantly appears and disappears in Device Manager or appears in Device Manager with an exclamation point indicating an error.
  • Your computer sounds the connecting and disconnecting chime when you connect the player to the USB port.
  • The player does not appear in My Computer.
  • Uninstalling Windows Media Player 11 and using Windows Media Player 10 corrects the issue.
  • When you use the player on another PC or laptop, it works flawlessly.
  • Your player was working properly with Windows Media Player 10, but you’ve recently upgraded to Windows Media Player 11 and your computer no longer detects it.
  • Go to Samsung.com, enter in the model u have in the search area and then go to support, this should fix the problem!
May 28, 2010 | Samsung YP-U2JZW MP3 Player
I've already installed windows media player , but now i want to uninstall / cancell it . can you please help me ? mine is a windows xp desktop computer.
Windows media player is a default utility program that comes with microsft os . it cant be delete nor change..so my adivice is if you dont like it.dont use it.. try kmplayer
Mar 17, 2010 | Computers & Internet
When it the zen is turned on it says firmware
Had the same problem and nearly went nuts trying to fix it. Here's what I did:
1. Uninstall all creative driver & creative software.
2. Uninstalled Windows Media Player 11 (Rolled back to WMP 10) and restarted PC.
3. Uninstalled Windows Media Player 11 Runtime and restarted PC.
4. Downloaded and Installed the latest free version of Winamp from http://www.winamp.com
5. Connected my A/C Power Cord to my Nomad Jukebox then connected my Nomad Jukebox via USB cable to the Computer.
The computer should then recognize the Nomad Jukebox as "Found New Hardware" then "MTP Device" and lastly "Your new hardware is installed and ready to use.
6. If you haven't already, go to the creative website and download the Creative Zen Xtra PlaysForSure Firmware 2.10.03 and save it to your computer.
7. Run the Firmware (Make sure Nomad Jukebox is connected) and at this point the Computer should recognize the Nomad Jukebox and begin the upgrade.
After your upgrade is complete, You can go ahead and re-download Windows Media Player 11 and it will recognize the Nomad Jukebox.Not sure what version of windows you have, but I have two computers, one with windows xp and the other has windows 7 and Im able to transfer music perfectly fine with Windows Media Player and RealPlayer on both computers. I hope this works for you. Good Luck!
Jan 05, 2010 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Windows not not installing music files
To obtain windows media player 10, you will have to uninstall windows media player 11...the only way you can uninstall is if you have windows xp...To uninstall windows media player 11, click on start, control panel, add and remove programs, locate the windows media player 11 application then click uninstall...Once you uninstall the program restart your computer....You should have windows media player 10 now...
I hope that helps
Thank you
Belbwa
Feb 24, 2009 | Philips GoGear HDD6330 MP3 Player
Just installed nero 7 software on my comp. and really messed up all my music files. all my saved files have lost there names & are know numbered tracks of nero media type. Same applys to media i...
hi sir,
by default, you have a music player installed on your system or maybe using windows media player before nero 7 was installed, unluckily, when you did installed your nero 7 it has it's own music player. by the time nero finishes the installation, nero prompts you what media types you are using, by default, nero had selected it's own files types...thats why your music compilation and playlist messed up.
in order to get things back, just right click any music files you have, go to properties, click change for types of file then select the application you want play with your music.
Sep 04, 2008 | Computers & Internet
Actually a HDD6320
The HDD6320 is not compatible with Windows Media Player 11.
You will need to uninstall Media Player 11, to roll back to version 10.
Also, it is not compatible with Windows Vista.
If you haven't already, install the Philips Device Manager from the product CD.
Connect the HDD6320 to the mains and PC.
Select the repair/restore option and follow the on-screen prompts.
If the HDD6320 is still not recognised, let me know if the player shows the connection icon on-screen, and I'll try to help further.
May 06, 2008 | Philips GoGear HDD6330 MP3 Player
Static
If you have recently upgraded to Windows Media Player 11, either manually or via Windows Update, this could be the problem.
In this case, uninstall Windows Media Player 11 from Add or Remove Programs, in Control panel.
Also uninstall Windows Media 11 runtime.
This will roll back to Windows Media Player 10.
If you are already using Media Player 10, this problem could also be caused by corrupt firmware on the player.
make sure you have Philips Device Manager installed, from the product CD.
Run Philips Device Manager, and select the restore or repair option, then follow the on-screen prompts.
This will format the player and re-flash the corrupt firmware. All tracks on the player will be deleted.
Reload a few tracks to test.
Mar 06, 2008 | Philips GoGear HDD1830 MP3 Player
I cant install nextar mp3 to the computor
Did you go into device manager and uninstall the mp3 player off of your compputer and the reinstall it? If not try that go into control panel then go to hardware then go to the button that says view installed hardware the go to uninstall device! Then reinsert the mp3 player back into your computer and try again. Also if you are not already try upgrading to the latest version of windows media player most mp3 players will malfunction if you do not have at least windows(R) media player 10 although 11 is the newest version available.
Jan 02, 2008 | Nextar MA933A MP3 Player
Microsoft Windows Media Player Logo
16 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
