Question about Zanussi Dryers
Zanussi Tumble Drier TC470 - Inner Timer Knob
Zanussi Tumble Drier TC 470
The inner timer assembly is broken.
I have bought a new one but need to know how to fit it so that the outer knob lines up in the correct place
with the outer dial.
ie The assembly is in the correct place so that the
settings on the outer knob coincide with the settings on the dial
SOURCE:
SOURCE: Removing Timer Knob on Maytag MDE7400AYW dryer
Can anyone help me? I have a Maytag Atlantis that my parents just gave me and my wife. Unfortunately, they accidently removed the model number sticker in the door area. I need to buy a new timer but no one can find which timer to get without the model number. Via the internet, I think I narrowed it down to either the MDE7400AYQ or the MDE7400AYW....but they both look identical to me. Can anyone tell me what the difference between the two is so I can go get the part?
Posted on Jul 21, 2008
SOURCE: Hotpoint tumble drier vtd00
How do you seperate the inner door from the hinge on a Hotpoint VTD00?
Regards, Mark
Posted on Sep 10, 2008
  • 1462 Answers
SOURCE: zanussi jetstream 1250 coin between inner & outer drum
not that easy.
remove top. remove water hoses.remove rear half of cabinet. to do this, undo securing screws along top flange, remove two screws at bottom sides hidden behind plastic plugs and two screws at bottom back. rear half of cabinet will then pull off.
remove heater - this is held with a 10mm nut in the centre which loosen and prise heater out.
you canb then see into the gap between tub and drum ane remove coin or whatever
Posted on Nov 05, 2008
aborcass
  • 2651 Answers
SOURCE: how to remove control knob on maytag mde8400ayw timer
youll need to "pop" the center of the dryer knob off, the outer mos part of the knobin which oyou turn is a false front, that actually locks the knob onto the timer shaft, use a small screw driver to pry it off
Posted on Jan 25, 2009
SOURCE: TIMER KNOB IS BROKEN
I've had the same problem. I checked out the Kitchen Aid website, called the toll-free number listed on the site (800-541-6390), and talked to a very pleasant and helpful customer service representative. She said she would be sending a free replacement knob that would arrive in 7 to 10 days. It may sound ominous, but if ya can't fix ya, ya gotta replaceya!
Posted on Feb 05, 2009
Drier will not shut off . Drier goes from heat fo cool and run all the time, will shut off if door is opened
Most dryers (and washers) have a control knob with settings and also have a timer that ticks like a clock.
I'd say your "clock-timer" is stuck and need replacement.
Most usually, you will have to replace the whole "control" assembly to get a new timer-clock.
God bless your efforts.
Sep 21, 2017 | Dryers
Zanussi tc470
DEFO BEARINGS WHEN YOU SEE THAT DUST A REAL SIGN
Jan 22, 2014 | Dryers
My zanussi TC7103 s dryer , timer dial is very stiff, and now sometimes sticks when on so that the dryer just keeps going and does not automatically switch off.
i think the timer knob will be binding in the facia panel. you could try working some washing up liquid round the knob to free it up (not oil) the timer may still be damaged but freeing the knob is worth a try a new timer varies from around £37
Jul 25, 2010 | Zanussi TC7114W Electric Dryer
How do I replace the inner door of my zanussi ZBQ365X oven?
open the oven door and there are screws around the perimeter of the inner door cover remove these the seal then replace the glass and reverse the procedure make sure the heat seal gets put back right for the heat shield
Apr 30, 2010 | Zanussi ZBQ365 Electric Single Oven
Zanussi tc470 condenser drier Red light is staying on even after the water container is emptied. switch appears to be faulty
excess water seems to be lodged in the drier and was drained out.There is a drain at the rear of the machine. I am concidering connecting a pipe here and draining permently to the outside.
Dec 28, 2009 | Dryers
Needing to take off old timer knob and replace with new one
We found this on another web site:
This was super easy. If you can screw and unscrew a nut from a bolt, its that easy.
The Knob assembaly comes as a whole. So once you remove the old knob (unscrew to the Left).
Then replace the new knob assy (screw to the Right) till its a snug fit. As you will see this knob is designed to be a clockwise rotation only - normal operation - sort of a self tightening screw.
May 18, 2009 | Frigidaire Washing Machine Timer Knob -...
We have a zanussi TC470 tumble dryer, it heats up at first but once we have left the clothes to dry for 70mins, we find that the clothes are still wet & the door has opened on the machine. Can...
The fixed thermostat on the Heater is probbaly faulty. (not the one with the reset button) I believe it is a Normall closed 80degree thermostat. What happens is they open when they get too hot and reset when they cool down. Probably broken. Worth replacing. Could be the one with the reset butti=on but as thye need a manual rest, probably not.
Aug 05, 2008 | Dryers
Ge timer on washer is broken
If it no longer clicks, the timer assembly will need to be replaced. If just the knob broke off, the timer should be good.
Mar 16, 2008 | GE WDSR2080D Top Load Washer
How do you remove the knob off the Timer?
look for a small hole along the side of it that may hold a set screw...turn the screw counterclockwise...the screw may be a hex-head
May 24, 2007 | Amana NAV5805A Top Load Washer
Dryers Logo
75 people viewed this question
Top Zanussi Dryers Experts
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
