Question about Stingpro ST444 1850 Watts Complete Amplifier 4 Gauge Hookup Kit Car Audio Amplifier
I have two amps one for my speakers and the other for my subs it was working fine but recently one of them turned off. I thought was a short circuit and bought a new one but still doesn't work. Its looped with the other on ground power and rem.. The other one works fine. Little help?
  • 86 Answers
When running multiple amps you need a relay most of the time for the remote wire off the radio this is because the radio was built to power one not multiples. one 12 volt relay may help .check local car audio store. also when hooking up relay it has to have a 12 volt power wire connected to it usually the center pin on the relay is your connection for the power wire the you connect your remote wire from the radio to the relay then connect each amp independently to the relay. Hope this helps write back if not . and if so leave feedback
Posted on May 11, 2010
I have a rockford fosgate ounch 325.1 (2004). I recently helped my parents move and took the sub and its sealed enclosure out of my 1994 Ford Explorer. The sub and amp worked until the move. After I...
it sounds like you have a short someplace. also, if you have a multimeter, check the voltage coming out of the speaker terminals of the amplifier. if the voltage is higher than 4 or 5 volts, the amp is probably bad.
Jan 10, 2011 | Car Audio & Video
Shorted Speaker outputs
Its probably in the amp if it is you cant do anything about it unless u know anything about amp circuit boards
Oct 08, 2009 | Metrik Amplifiers MAX-1202 Car Audio...
2 car subwoofers, one doesnt play
Short in amp ? try swiching wire's to speaker's around . if other speaker then work's , speaker's are both fine . if not , then short in amp , or blown channel in amp . get new one or find someone who know's more than i do about amp's
May 24, 2009 | Kicker CVR12 Car Subwoofer
Amp doesn't come on
Hello rheabarb,
You did not say whether or not you checked the wiring going to your subs. Many times, a shorted or grounded speaker wire will cause an amp to fail. And if the amp powers up OK with the subs disconnected, I'd suspect one or more of the wires.
Hope this helps.
May 19, 2009 | Clarion APX1300 Subwoofer Mono Amp - 300W...
SWA1501 Sub blows fuses when turned on...
Shorted amp or blown speaker. Other things could also cause it. But there is a short circuit in it.
Mar 08, 2009 | Mackie SWA1501 Subwoofer
Amp works but no sound from sub
Some older Pioneer radios require you to connect the Subwoofer RCA to the rear output on the back of the radio and then you have to turn on the subwoofer in the menu on the radio. What model Pioneer radio is it? Also, make sure that the RCA plugged into the amp is on the input side, not the output side.
Jul 29, 2008 | Sony XM-2002GTR Car Audio Amplifier
Car amp's stopped working. Putting out a heart beat sound through subs but no bass.
could be low current ,disconnect all power including ground for 20min N.B most amps will seem to be shorted at output but this is normal due to damping ratio.
Jun 11, 2007 | Jl Audio E1200 Car Audio Amplifier
Protect Light On Subwoofer Cuts Out
some type of over-current protect device in sub amp section gone bad..perhaps a board-mounted resettable circuit breaker or fuse has gone bad? these are hard to locate on the board for a novice.
May 30, 2007 | Verge VGA285 Car Audio Amplifier
Sub does not fully work
My guess is that one of your subs has a damaged voice coil, which acts like a short circuit to the speaker outputs. If you put an ohmmeter on the speaker terminals you should measure a resistance of not much less than 2 ohms (assuming you've wired the VC's in parallel). If you measure a significantly lower resistance then you have a damaged subwoofer.
Mar 13, 2007 | DHD NTX-6812 Car Subwoofer
Car Audio & Video Logo
44 people viewed this question
Top Stingpro Car Audio & Video Experts
xxxxxx xxx
Are you a Stingpro Car Audio and Video Expert? Answer questions, earn points and help others
