Question about Dryers
It wont heat
My dryer turns but wont produce any heat. Nothing is drying.
  • Dryers Master
  • 43,501 Answers
Hi, If you have a gas dryerit wont heat - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 12, 2010
Dryer won't dry clothes
Heating element faulty not giving as much heat as it should
Nov 14, 2015 | Dryers
Dryer wont heat. we have cleaned out all the lint, replaced the top thermostat and are frustrated. seems like it heats for a couple minutes then nothing.
Sounds like a bad heating element . Many dryers use a dual coil setup ( one coil for low to med, both for high heat). Also check your dryer discharge vent. A blocked vent will not allow the humidity to escape, which will result in your clothes not drying or taking multiple cycles to dry. Turn the dryer on, and find the vent discharge on the outside of your home and just hold your hand there. If you do not feel substantial airflow you have a blocked vent or blocked discharge tube. But from what you described, I would bet on either a bad heating element or failed heating element relay.
Sep 12, 2013 | Maytag Dryers
My Maytag Neptune Dryer works great with no close in it. As soon as you put clothes in it wont stay hot.
Instructions
Things You'll Need:
* Level
1. Ensure that the dryer's door is latched shut and that the power cord is plugged into an electrical outlet. Also check the home's fuse box for a tripped circuit breaker.
2. Make sure that the "Air Fluff" button on the dryer's touchscreen has not been selected if the dryer fails to produce heat. Also clear the lint screen if the dryer fails to heat.
3. Check the exhaust system, which exits from the back of the dryer for clogs, which commonly occur if the lint screen has not been cleaned regularly. Also ensure that only 4-inch metal exhaust tubing is used for the exhaust system. If clogs are present due to an improper exhaust system, the dryer will fail to dry the clothing completely. Also avoid overloading the dryer, which can also cause a drying problem. The amount of clothing equal to a single wash load should not be exceeded.
4. Check for the presence of loose items if the dryer produces noise, such as coins and loose buttons. The dryer will also produce noise if it is not leveled properly. Place a level on top of the dryer and turn the foot located on the bottom of each corner of the dryer until the dryer is level.
Feb 23, 2011 | Maytag Neptune MDG6800 Gas Dryer
Dryer dosent allways produce heat to dry the load
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
heatman101
Aug 16, 2010 | Whirlpool LGQ8000JQ Gas Dryer
My dryer spins and heat just a little but not enough to dry any clothes
Need to change the heater filament. The heater filament has several portions to produce heat. As it ages, some portions are not producing heat anymore hence the total heat produced by an old filament can not put out as much as originally designed.
Jan 08, 2010 | Estate EED4300TQ Electric Dryer
Heating problem with stackable washer/dryer combo
check the duct work going out of the house if it is clogged the clothes wont dry. Birds love to build nest in a open dryer vent and if you have any bends lint will build up get these clean and it should get you drying again
let me know what you find
bill
Jan 08, 2009 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
112 people viewed this question
Top Dryers Experts
