Question about Brother HL-2070N Laser Printer
Printer is too dark
Printer print is too dark
My Printer Prints Out Too Dark
go into printer properties and change the setting....you probably are using an after-market cartridge...they are notorious for being too dark....even if that is not the case, go to printer properties and change the setting....if there is no slide bar for heavy to light, then clik on toner saver, it should print lighter than it does now
Apr 27, 2012 | Samsung SCX 4600 multifunction Laser...
How to make print more dark laser printer hp 1005
go to start menu, choose printer & faxes, click the printer icon properties and find the printer resolution to adjust the dark printing capability
Dec 12, 2010 | HP LaserJet 1005w Printer
I have a Zebra s600 that is set to 30 darkness and the head is screwed down fairly tight. I can print this way but if the printing lightens up, I don't have any more adjustment. The barcode reader picks up...
0.print config label (printer off, press Cancel button and tur on printer, wait 5 secunds and relese button)
1.press the last button until the ligth set on Darkness (Darkness on),
2 press the 3rd button 10 times( darkness down from 30 to 20 (3rd button=less 2nd button=more),
3.press 2 times the last button untill the 3 leds flash(save)
4.turn printer off.
5.Press pouse button, turn printer on, still pressing for 8 secunds, and then release te button.
6.The printer go to print the test label, let run 3 or 5 labels, then pause.
If not happy, repeat steps 1 and 2 (less times 2 or 3 times at the time and save)
print configuration label again ans se if you happy.
If the printer still going to darkness 30, chek if you forgot to save or check the driver settings and change.
Last option Resect to Factory Defult (this drop darkness to +10)
Oct 29, 2010 | Zebra Stripe S600 Thermal Label Printer
The printer is printing dark vertical line on the
90% or more of the time on this printer dark lines are coming from your toner/drum cartridge. You can verify this by changing cartridges if you have a spare. If you don't then remove the cartridge and look at the colored cylinder in the cartridge and see if the same "lines" are on the cylinder that are on your prints. This will tell you for sure that the cartridge is bad.
Dec 13, 2009 | Samsung ML2250 Laser Printer
Printer not printing dark enough
go to the print settings select the dark scale
u can get print darker than the previous
May 27, 2009 | Samsung CLX 3160fn All-In-One Printer
Photo prints are very dark and muddy
Hey,
I also have this problem. I even have prints that were made when I first got the printer about 2 years ago, which looked great then and now, and the EXACT same picture from the same program prints incredibly (unusably) dark.
Any help would be greatly appreciated!
Jan 01, 2009 | HP Photosmart C6180 All-In-One InkJet...
My ink prints too dark is there an adjustment on the printer
yes.there is a adjust ment.go to printer properties and there printing preferences and there adjust the print quality to normal which is set on beat mode so the prints are comming extra dark.
Dec 11, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Can't save the printer darkness in the printer
go to printer driver properties.. 1.click printing preferences set it to USE PRINTER CONFIGURATION 2.go to advance click Printing Defaults set it to USE PRINTER CONFIGURATION
you must set this two configuration note: fresh installed driver defaulth to software control
Oct 14, 2008 | Zebra Z4Mplus Label Printer
Dark streaks
Dark streaks are an indication of "burned" or overheated ink. This will occur when the printer sets for a long period of time and nothing is printed. The problem will usually disappear after 50 pages or so, unless the printhead is damaged.
If the print remains dark, the printhead will need replaced.
(Very expensive)
(Dark print can also be caused by using Non-Xerox ink)
Sep 10, 2008 | Xerox Phaser 8400 Laser Printer
Brother HL-2070N Laser Printer Logo
199 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
