Kicker Amp problem
I have a kicker 400.1 hooked up to 2 10" off name brand subs and every time I power up my car the amp shows a red like for a few seconds then goes off, what needs to be done to solve this?
    Scholar:
  • 105 Answers
Are you sure it is correctly grounded? Double check.
Connect a voltmeter to the power source to check for between 11-13 Volts. Make sure the main 30 AMP fuse on the Kicker is not blown.
Posted on Mar 28, 2008
SOURCE:
I have 2 12 inch kicker rt dual 2 ohm subs. On a kicker cx1200.1 i want to kno how to hook it up to 2ohm to the amp. And if i can add another 10 inch kicker rt 2ohm sub in the future.
Do to the impedance Of your sub u can't run it @2ohms its going to either be @1ohm or 4ohms and your amp isn't 1ohm stable and u will risk damaging your amp. So your only option is to run it @4ohms and on a good note your sub is 100-600 watts RMS and your amp will push 400-500 watts RMS @4ohms. Now if you want to run 2 sub's in the future That amp will work perfect because it pushes 1,200watts RMS @2ohms and to wire your 2 sub's @1ohm just follow the steps in the image below. Hope this helped.25345194-v0hbouy2nvquqteoroa5j5rq-3-0.png
Dec 30, 2014 | Car Audio & Video
I have a kicker dx 500.1 amp and a kicker cvr12 sub. When I first hooked up worked perfect for a few minuted. Adjusted settings ont the side and it went out. Now When I power on it the protection light...
check the fuse on the power wire (+) not the ground wire .. i had a kicker 1500.1 on 2 l7 15\'s and when the bass would hit hard the fuse would vibrate and cause the amp to go into safe mode.. after re wireing the whole truck i then found out it was the 150amp fuse holder
Aug 07, 2011 | Kicker Car Audio & Video
Kicker subs hook up problems
Connect one to each channel, for the best sound.
Jan 05, 2010 | Kicker Solo-Baric L5 Car Subwoofer
I have 1500 kicker amp and 2 15L7 4oh want to hook up
you can't get full power out of it because those subs can be wired series/parrallel to a 1 ohm load or just series to a 4 ohm load and you don't want to put a 1 ohm load on this amp... you need dual 2 ohm subs for this amp... I have the same setup but with dual 2 ohm subs and it is rediculous... you need to buy different subs that are dual 2 ohm or buy an amp that is stable at 1 ohm... you will only get 750 rms out of a kicker 1500.1 at 4 ohms so u will do more harm than good to your subs.
Dec 09, 2009 | Kicker ZX1500.1 Car Audio Amplifier
Kicker zx750.1 Amp in Protection Mode (Red LED)
My kicker amp zx1500.1 keep going in protection mode I unhooked the sub speak wires and put the ACR cords back in and it didn't go in protection mode what next
Mar 18, 2009 | Kicker 06ZX750.1 Car Audio Amplifier
Wiring my 2 L7 with a kicker 1000times1
Run the subs in series then bridge the amp. So run the normal + to - to the one sub then hook up a spare wire (not connected to the amp) to the same + and - connections. Then run the spare wire to the + and - of the other sub. This will tie the 2 together so you can bridge the ampfor more power instead of using 2 seperate channels.
Feb 01, 2009 | Kicker 02S10L74 Car Subwoofer
Price check
that is 2 12 hitting 150 db you got to know what you are doing
Sep 14, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Wiring
provided that the memphis studio series is still 1 ohm stable you would wire each coil of each speaker like this : posive to positive negative to negetive on the speaker using 2 jumper wires then run 1 coil from each subs positive and negative the input on the amp that amp would see a 1 ohm load from both speakers as each speaker would become a 2 ohm load. from experience, memphis does not make an amplifier that is brutal enough on power for L7 15" solos, i have the st 1600 d amp running only 2 dual 4 ohm 10 L5's and it is barely enough power for them. For less money than your 2 subs cost retail I can get you brand new matching 2000 watt true competition rated and proven 1 ohm power and 2 subs that would physically fit in your current box, i would however recommend a very very large box for 2 15" squares. you can email me at [email protected] , my advice and system designs are always free even if you do not buy thru me. I am usually 1/3 to 1/2 what retail is with full warranties and i can drop ship anywhere in the U.S.A.
Jun 25, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Power Protection Circuit (SORT) Engaged
Umm a ohm meter would help you here. Double check the wires from the sub to the amp...make sure its not shorting out. Try starting the amp without the wires on the terminals...if the protection shows up then there is a short inside the unit and it will need to be replaced/repaired.
Feb 17, 2007 | Kicker ZX400.1 Car Audio Amplifier
48 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
